pudjo
Openwrt metarouter with httpd, named, and squid
Wed Oct 26, 2011 4:59 pm
is there anyone here working with stable openwrt in metarouter ppc?
my goals is to build stable openwrt with httpd, named, and squid
the purpose is for enhanced url filtering, content replacing, and custom dns forwarding
it will be helpfull if someone can tell me what to do to make my goals
https://thenetpurifier.com - The internet is like raw water, must be purified before consumed
liquidcz
Re: Openwrt metarouter with httpd, named, and squid
Fri Jan 27, 2012 4:33 pm
Lets try to use my OpenWrt image fo PPC platform http://openwrt.wk.cz/trunk/mr-ppc/, install needed packes (Apache, nginx or Lighttpd, Bind, Squid) from my repos http://openwrt.wk.cz/trunk/mr-ppc/packages/ and configure it for your needs.
barkas
Sun Jan 29, 2012 5:18 pm
Be aware that stability of metarouters seems dubious.
janisk
Mon Jan 30, 2012 9:11 am
experience may wary, but yes, set up some monitoring (like Dude) to see what is happening with the virtual host and the host router itself.
bjorncmtec
Thu Dec 13, 2012 4:39 pm
Hi
I am trying to setup the same squid on openwrt to allow HTTPS proxying on-site.
Has anybody gotten this working?
I have gotten squid installed with basic squid.conf but when I try to start the squid process i receive the following error below relating to libpthread which I have no idea what it means or how to fix it
Assistance would be GREATLY appreciated
root@OpenWrt:/usr/sbin# squid start
squid: can't handle reloc type 'errno'
squid: symbol 'errno': can't handle reloc type 0x49 in lib '/lib/libpthread.so.0'
Certified
* MTCNA
* MTCRE
* MTCTCE
* MTCINE
South Africa
janisk
Fri Dec 14, 2012 10:57 am
you might have better results on OpenWRT forums. However, check if you have compiled quid package correctly (with correct libraries etc.0
bjorncmtec
Fri Dec 14, 2012 2:04 pm
I'll see if I have any luck on the openwrt forums T_T and their IRC channel
Certified
* MTCNA
* MTCRE
* MTCTCE
* MTCINE
South Africa
bjorncmtec
Mon Dec 24, 2012 3:59 pm
Anyone else had luck getting squid up and running?
The guys on the forum just say "its a mikrotik openwrt image go to the mikrotik forum"
Certified
* MTCNA
* MTCRE
* MTCTCE
* MTCINE
South Africa
janisk
Thu Dec 27, 2012 12:43 pm
if you need specific software for OpenWRT, you can check tutorials on their page on how to build packages or compile software for this flavor of OpenWRT. Here on forums you can get working image file that can be used to run your custom software, or you could talk someone who builds images to build these packages for you. Unfortunately i cannot help you with that.
Users browsing this forum: No registered users and 4 guests
