MUM Europe 2020
danielchisholm
Gigabit PoE wiring (e.g RBGPOE)
Tue Nov 01, 2011 2:03 pm
Can somebody show me how a Gigabit PoE injector is wired? Is the wiring of an RBGPOE different from an RBPOE?
I am a bit confused because I thought I understood that Gigabit uses all four pairs for data and yet the wording in the brochure for the RBGPOE injector http://routerboard.com/pricelist/downlo ... ile_id=309 suggests that the wiring is exactly the same as a 10/100 PoE injector (i.e. pairs 4,5 and 7,8 are unused, and power/ground are supplied over them).
If pair 4,5 is used for "+", does this mean that the PoE injector ties wire 4 and wire 5 together? (in which case they would be shorted out, and differential-mode data could not be sent over this pair) Or does it insert "+" power via a diode onto each of them (and a complementary arrangement on 7,8)?
FWIW my motivation in asking this is to know how I should manually field-modify devices (such as RB250GS, RB750G) to provide field-expedient PoE.
normis
Re: Gigabit PoE wiring (e.g RBGPOE)
Tue Nov 01, 2011 2:24 pm
those devices already support PoE with the gigabit PoE injector, why do you need to modify them?
changeip
Tue Nov 01, 2011 5:10 pm
normis, is that poe only allow 100mbps? you cant get gigabit without all 8 wires and thus the reason they came up with the 802.3af power supplies - is this yet another standard?
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
danielchisholm
Tue Nov 01, 2011 10:11 pm
True. I am interested in knowing if/how I can do this without using external PoE injectors. Not so much for cost reasons, but for parts count / clutter reasons. BTW the devices I am attaching need very little power (currently about 150ma each but in the next generation of our hardware they will be about 50ma each) so there is a certain minimum-parts-appeal to having the power connections simply bridged inside the the switch.
jandafields
Wed Nov 02, 2011 5:07 am
Yes, gigabit uses all 8 wires. The power is phantom power, similiar to the technique used with 802.3af, but it appears to be modified to be mikrotik proprietary.
normis
Wed Nov 02, 2011 7:41 am
If you want to make PoE output on the other ports, sorry but for these products it's not easily possible. You need to wait for our RB750UP and Omnitik UPA
bigguns
Wed Nov 02, 2011 7:33 pm
Normis
Is there any plans for a 450GUP or something with 5+ ports and spec like/better than the 450G?
normis
Thu Nov 03, 2011 9:33 am
We will start with two products, and we will see where we go next with this feature.
brandonrossl
Fri Jan 20, 2012 5:12 pm
So if I use a RBGPOE to eth1 on a RB450G it *will* or *will not* be gigabit?
normis
Mon Jan 23, 2012 9:24 am
yes, if you use Gigabit PoE injector on a Gigabit RouterBORD, connection will be Gigabit
Beone
Tue Jan 24, 2012 9:19 pm
Normis
THAT would be a great device! +1 for sure!
blue
Fri Jun 15, 2012 8:47 am
Any idea how to make home-made gigabit poe? Schematics?
Thanks...
karlos
Fri Jun 15, 2012 12:52 pm
Whitepaper from Texas Instruments will help you to understand.
Basicly you just need magnetics for seaparatinf the DC (power supply) from AC current (data transfer). So other capacitors, and resistors for make it clean.
Users browsing this forum: No registered users and 27 guests
