honzam
RB Sextant
Fri Nov 04, 2011 4:21 pm
LAN, FTTx, Wireless. ISP operator
server8
Re: RB Sextant
Sat Nov 05, 2011 10:42 am
Great job :D
Please MT remember to do the radiation pattern in italy is mandatory for the regulatory law
Thank You Giuseppe
HaQs
Re: RB Sextant
Sat Nov 05, 2011 10:31 pm
When 23dbi version ?
Diabolix
Re: RB Sextant
Sun Nov 06, 2011 12:39 am
That is what I am also wondering? and no Gb Ethernet either ?
Is the 2dbi gain on the antenna the only diffrence ?
janisbvp
Re: RB Sextant
Sun Nov 06, 2011 12:25 pm
Now, who was the wise guy, that invented the name?
It will hardly go through spam filters and will cause other problems, I guess... :)
hapi
Re: RB Sextant
Sun Nov 06, 2011 2:20 pm
It will also interfere with each other on the mast as more SXT´s?
normis
Re: RB Sextant
Mon Nov 07, 2011 8:48 am
it contains a RB711, so basically you could swap it for a RB711G version. Or we could make a separate Gigabit kit if people are interested.
historians and people dealing with sea navigation are in bigger trouble then.
mahnet
Long time Member
Long time Member
Re: RB Sextant
Tue Nov 08, 2011 5:21 am
Hi Normis,
Does it mean it is a kind of DIY kit where the board can be changed by user??
I would have much preferred the 23dbi version but please make it a metal shield enclosure.
honzam
Re: RB Sextant
Thu Nov 10, 2011 10:56 am
And warranty is not breached?
normis
Re: RB Sextant
Thu Nov 10, 2011 11:01 am
Warranty is breached, because you are replacing the most important component of the product :)
honzam
Re: RB Sextant
Thu Nov 10, 2011 12:05 pm
:D
And you can insert image of the back of the sextant?
0ldman
Re: RB Sextant
Thu Nov 17, 2011 8:40 am
rotfl
That sounds dirty on so many levels... but yea, I'd like to see a better pic of the sextant as well.
LZiX
Re: RB Sextant
Thu Nov 17, 2011 9:09 am
When sextant will instock at resellers ?
saintofinternet
Forum Veteran
Forum Veteran
Re: RB Sextant
Tue Nov 22, 2011 7:10 pm
ok guys... which all hypens to remove?? --> S-E-X-T-A-N-T :D
anyways back to work.... when is this expected??
I am hitting my head hard on the wall as I really cannot find any good indoor enclosures (METAL) for the RB411 & RB711 (with USB) in India....
any and all help in this matter appreciated....
by professionals, for professionals....
Don't forget to give KARMA!!!
WirelessRudy
Re: RB Sextant
Tue Nov 22, 2011 11:47 pm
Well, I can't download the link, I am beeing denied access to the server?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
WirelessRudy
Re: RB Sextant
Tue Nov 22, 2011 11:52 pm
Ha! Yo no soy marinero, soy capitan, soy capitan. Hence it struck my eyes the moment I saw the unit on my provider's website! So in this case it worked to the good! (Oh, the spanish reflects my previous live! :D )
Rudy R. Puister
WirelessRudy
Re: RB Sextant
Tue Nov 22, 2011 11:55 pm
My favorite polish provider has them already..
Rudy R. Puister
WirelessRudy
Re: RB Sextant
Tue Nov 22, 2011 11:57 pm
And yes, me too was dissapointed in the gain increase. I would like to see an over 20dBm one and they should be metal (metal layered) shielded against interference to get a real good unit...
Rudy R. Puister
honzam
Re: RB Sextant
Wed Nov 23, 2011 9:41 am
back
dingsingo
Re: RB Sextant
Wed Nov 23, 2011 10:32 am
@honzam
can you give up a photo of the Ethernetport ? Is it a better handlink as SXT ?
Thx
Dingsingo
normis
Re: RB Sextant
Wed Nov 23, 2011 10:35 am
@honzam
Thx
Dingsingo
inside is a standard RB711
honzam
Re: RB Sextant
Wed Nov 23, 2011 10:49 am
normis
Re: RB Sextant
Wed Nov 23, 2011 11:00 am
honzam
Re: RB Sextant
Wed Nov 23, 2011 11:04 am
Normis: fits inside the RB433 with one card?
mahnet
Long time Member
Long time Member
Re: RB Sextant
Thu Nov 24, 2011 6:44 pm
metallic casing and 23 dbi antenna please MIKROTIK. 20$ is too much for just 2 dbi antenna gain.
another thing 55$ for 711-5hnd and another 55$ for 18dbi antenna, plastic casing, poe and adapter??
Caci99
Re: RB Sextant
Thu Nov 24, 2011 8:56 pm
Hmm, sextant cute name.
I can already picture some of my stuttering customers asking for these.
-Toni-
Don't crash the ambulance, whatever you do
normis
Re: RB Sextant
Fri Nov 25, 2011 8:57 am
yes
yes, a good price!
ste
Re: RB Sextant
Fri Nov 25, 2011 12:26 pm
Does a cable with kink protection fit?
For SXT we ordered cables without (not easy to find).
normis
Re: RB Sextant
Fri Nov 25, 2011 12:53 pm
give a picture example of such cable? distance from the connector to the door is not so big, you will need to bend the cable slightly
ste
Re: RB Sextant
Fri Nov 25, 2011 1:32 pm
These do not fit in SXT. May be the space between socket and door of the Sextant is bigger?
normis
Re: RB Sextant
Fri Nov 25, 2011 1:38 pm
usually you can't buy these in lengths for running up a tower. when you make your own cable, then it works fine.
pre-made cable as in the image - it will bend very much, or you can modify the cable hole a little.
ste
Re: RB Sextant
Fri Nov 25, 2011 1:58 pm
As we use SXT for our private customers they need 10-15 meters to reach the top of their building.
We give them preconfigured cables as most of them do not like to crimp. So it would be handsome if
preconfigured cables fit.
normis
Re: RB Sextant
Fri Nov 25, 2011 2:04 pm
new SXT models have this issue solved, and have the Ethernet at a different angle!
For current SXT and SEXTANT you can try shorter ones like this:
http://www.startech.com/media/products/ ... Blarge.jpg
or even something like this :)
http://www.networktechinc.com/cgi-bin/k ... -gray.html
but yes, of course you are right, we will see how to improve this issue.
syadnom
Re: RB Sextant
Sun Nov 27, 2011 2:28 am
I agree that the +2dB gain is just not enough for the price difference. I specifically need a nanoBridgeM5 alternative. I currently build out an SXT on a DSS dish to get up to about 25dB.
Also, how about a more narrow beamwidth? I know it makes it harder to aim but can help mitigate interference some.
InoX
Re: RB Sextant
Sun Nov 27, 2011 1:53 pm
a 23dbi version and 25dbm will be a very nice product :D
Trisc
Re: RB Sextant
Tue Dec 06, 2011 8:26 pm
Second that. Agree absolutely. This looks nasty and plasticky.
Ciambot
Re: RB Sextant
Tue Dec 06, 2011 11:44 pm
+1
Matess
Re: RB Sextant
Sat Dec 17, 2011 11:16 am
+1
+1
DiabolixZA
Re: RB Sextant
Mon Dec 19, 2011 12:58 pm
+1
+1
+1
mahnet
Long time Member
Long time Member
Re: RB Sextant
Tue Dec 20, 2011 7:27 pm
+1
+1
i would say 23 dbi and metallic enclosure
honzam
Re: RB Sextant
Wed Dec 21, 2011 10:10 am
+1
saintofinternet
Forum Veteran
Forum Veteran
Re: RB Sextant
Wed Dec 21, 2011 12:12 pm
+1 raised to 'n' :)
normis
Re: RB Sextant
Wed Dec 21, 2011 12:23 pm
just buy from our MFM partners, they already have metal enclosure mounted on a directional panel: http://mum.mikrotik.com/gallery/v/HU11/ ... 9.jpg.html
mahnet
Long time Member
Long time Member
Re: RB Sextant
Wed Dec 21, 2011 4:07 pm
Where is this product available in India?
normis
Re: RB Sextant
Wed Dec 21, 2011 4:08 pm
no idea, email these companies:
http://www.mikrotik.com/mfm
saintofinternet
Forum Veteran
Forum Veteran
Re: RB Sextant
Wed Dec 21, 2011 7:12 pm
i make my own range of products in india using mikrotik inside.
horpe
Re: RB Sextant
Fri Dec 30, 2011 9:58 am
RB433 in the sextant is a good idea but bad execution.
normis
Re: RB Sextant
Fri Dec 30, 2011 9:59 am
why bad? works fine
horpe
Re: RB Sextant
Fri Dec 30, 2011 10:12 am
Pigtail is a short and not reach the miniPCI
midnightman
Re: RB Sextant
Fri Dec 30, 2011 4:08 pm
hups :lol:
honzam
Re: RB Sextant
Sun Jan 08, 2012 11:27 pm
How to solve this problem? You say so 433 is good for sextant
LZiX
Re: RB Sextant
Sun Jan 15, 2012 12:48 pm
+1
+1
+1
+1
honzam
Re: RB Sextant
Sat Jan 21, 2012 11:25 pm
Chain 0 is horizontal on antena? I can not find info anywhere
http://routerboard.com/RBSEXTANT5HnD
janisk
Re: RB Sextant
Mon Jan 23, 2012 2:00 pm
0-chain horizontal pol
1-chain vertical pol
manual will be updated to include this information.
honzam
Re: RB Sextant
Mon Jan 23, 2012 2:52 pm
Thanks.
What about install rb433 into sextant? Pigtail is too short. See picture above
winet
Re: RB Sextant
Wed Jan 25, 2012 6:31 pm
when will this be ready on my country? the local authorized distributor don't have this supply. i want OmniTik UPA-5HnD too. which nearest distributor that i could buy from for these items? i believe normis can answer this. thank you.
Bomber67
Re: RB Sextant
Mon Feb 06, 2012 12:46 pm
Exactly.
The Sextant would be a nice and affordable basis for a small base station with backhaul via integrated panel antenna and 2 sectors. As can be seen there are 2 knockouts for N-F Bhd connectors in the case. But this is of no use as the pigtails cannot reach the MiniPCI.....
What about suppying the Sextant with 20cm pigtails?
Bomber67
Re: RB Sextant
Tue Feb 07, 2012 1:24 pm
I guess you guys at MT surely have an impact on how products evolve!
It is obvious that the designers of the Sextant did have the RB433 with MiniPCIs in mind when designing it, because the trunk is big enough for one. They also made knockouts for NF Bhd, :) but for some reason they picked the 10cm pigtails from the shelf.... :shock:
That's what I call kinda stumbling on the finish line ;-)
honzam
Re: RB Sextant
Sat Mar 31, 2012 6:44 pm
Because the unit Sextant and SXT have a problem with interference, was on the Czech forum idea how to make a metal shield.
The shield will be grounded through the metal legs.
Now we see what will be interest, then the price will be determined
taduikis
Re: RB Sextant
Sat Mar 31, 2012 11:45 pm
Any performance improvements reported after applying that RB shield cover?
server8
Re: RB Sextant
Sun Apr 01, 2012 10:13 am
On a busy must the noise generated in adiacent channles by a trasmitting unit not shielded may be higher than the radio signal received by the other units, shielding generally prevents bad RX performance.
Giuseppe
taduikis
Re: RB Sextant
Sat May 05, 2012 2:19 pm
I've also made metal RB shielding cover, but it didn't do much good for me, so I'm now thinking to try something like this :)
dingsingo
Re: RB Sextant
Sat May 05, 2012 3:11 pm
or do you use this one:
Mars 19dB Dual incl. Case: MA-WA56-DP19SMES
Shop:
http://shop.meconet.de/Antennen-Zubehoe ... 15498.html
And in the Case a RB/711GA.
dingsingo
n21roadie
Re: RB Sextant
Sun May 06, 2012 6:48 pm
@taduikis
Can you give more information not on the Sextant but the parabolic antenna mounted above the sextant in the picture.
N21roadie,
Network 100% MT for Now?
taduikis
RB Sextant
Sun May 06, 2012 7:31 pm
It ain't my picture. Nor the antenna. Found it by accident in Internet.. So nope, I cannot.
Users browsing this forum: mixig and 26 guests
