phmax
Changing UBNT Bullet -> Groove
Wed Nov 09, 2011 11:23 am
i am currently using UBNT BUllet Accesspoint on the one side, and on the other STATION WDS mode. Both are BULLTET from UBNT.
Now i want to change on the one side. i configured the Groove with AP bridge and added a wds to the ap bridge with the mac from the bullet.
it connect on the wlan, but not on wds. i dont use airmax.
anyone can help?
thx max
DarthLodis
Re: Changing UBNT Bullet -> Groove
Wed Nov 09, 2011 2:15 pm
Have you tried to put it on Dynamic WDS?
normis
Wed Nov 09, 2011 2:32 pm
it won't work as they use a different WDS implementation
DarthLodis
Wed Nov 09, 2011 2:37 pm
yes, it works! i have something like this using a NanoStation5 + Mikrotik with WDS.
normis
Wed Nov 09, 2011 2:46 pm
are you sure that it's station-wds?
DarthLodis
Wed Nov 09, 2011 3:06 pm
Completely sure! we just can't enable Nstreme or Airmax, for obvious reason.
normis
Wed Nov 09, 2011 3:09 pm
OK then, could be another reason ...
phmax
Thu Nov 10, 2011 11:59 pm
hello,
thanks for your answers. yes i already tried to change them to dynamic wds but without success.
so i had to chance both sides at the same time to groove, i didn't find another solution yet.
thanks!
max
WirelessRudy
Fri Nov 11, 2011 12:44 am
Can you give us the configs of both sides? Because WDS is for both manufacturers a proprietary extension which is not compatible with the other. You probably have done something so WDS is not really working. But if state it is you have to show us your configs so we all can learn....
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
dejanb
Fri Nov 11, 2011 6:53 pm
Hello!
I'm using NS5 in station-wds mode with Mikrotik as ap bridge + Dynamic WDS, and it works very well for me too...
Nanostation5 loco, not M5 series and ROS 4.17 at Routerboard 333.
Regards!
WirelessRudy
Sat Nov 12, 2011 12:49 am
Hello!
Regards!
Well, any brand station will connect to Mikrotik AP-bridge. The fact Dynamic/Static WDS is enabled in AP does not necessarily mean the station is accept as station-wds.
The only way to see if the station-wds indeed is bridged as wds station is to see if node 'behind´ the bridge station-wds can be reached from AP in the same domain/network.
Only if you can show me this I (and MT!) will believe you...
Rudy R. Puister
dejanb
Sat Nov 12, 2011 3:15 pm
Hello!
Why don't you just try it and see be yourself?
It works for me, i have several clients with PPPoE connections and small base station attached behind that NS5...
Best Regards!
Hello!
Regards!
Users browsing this forum: Znevna and 157 guests
