MUM Europe 2020
ManUtd
OmniTIK default, new, config ?!
Sat Nov 12, 2011 8:46 pm
just to ask MikroTIK team why the default config of OmniTIK is same as on RB750 (cannot access ROS via ether1 because no neighbor and ip on this port and firewall rules block access) ?!
That's don't make any sense because in RB750 case you have router on the desk and it's easy to put lan cable in any of 5 ports and access ROS. When you install OmniTIK on top of the building and climb down to setup ROS via ether1, you can't do that...?! Sometimes is really hard to setup routers near them, or not ?
In first peaces of OmniTIK (ROS was 5.2) it was "normal" config, just like on other boards, except RB750.
Am I right about this or I missed something ?
Thanks.
normis
Re: OmniTIK default, new, config ?!
Tue Nov 15, 2011 9:19 am
you are right, we will work on a better config
ManUtd
Tue Nov 15, 2011 9:56 am
Nice to hear that. Thanks again.
sadeghrafie
Long time Member
Long time Member
Tue Nov 15, 2011 11:23 am
Hmmm, good news :)
Mikrotik Route My Life
Someone Says: Don't forget to give karma
Lakis
Forum Veteran
Forum Veteran
Tue Feb 28, 2012 1:50 am
Yes about that
Instead reboot by mistake I press reset config....
Users browsing this forum: uldise and 14 guests
