MUM Europe 2020
saintofinternet
Forum Veteran
Forum Veteran
3G problems
Mon Nov 28, 2011 2:29 pm
hi,
ip route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 10.112.112.118 1
1 ADC 10.0.0.0/8 10.10.1.201 ether1 0
2 ADC 10.112.112.118/32 112.110.184.231 ppp-out1 0
ip address print
# ADDRESS NETWORK INTERFACE
0 D 112.110.184.231/32 10.112.112.118 ppp-out1
1 10.10.1.201/8 10.0.0.0 ether1
above i have given print out of the status of my routeros after connecting to the internet over a 3G HSPDA stick.
i can ping the internet website from terminal window in Winbox. but when i try to access the internet over laptop connected via ethernet i just cannot.
help appreciated....
by professionals, for professionals....
Don't forget to give KARMA!!!
saintofinternet
Forum Veteran
Forum Veteran
Re: 3G problems
Mon Nov 28, 2011 6:11 pm
anyone out there who can help me??
dasiu
Trainer
Trainer
Re: 3G problems
Mon Nov 28, 2011 6:23 pm
1. Is it ether1 or another? You need IP config on the ether interface :). Can the computer ping MikroTik? Is MikroTik the default gateway for the computer? Does tracert from computer show first step as MikroTik - and then (steps 2 and following) nothing?
2. You need to have masquerading (/ip firewall nat) on out-interface=ppp-out1
3. Maybe you need to modify each forwarded IP packet adding +1 to TTL (in /ip firewall mangle) :).
That should be it :).
saintofinternet
Forum Veteran
Forum Veteran
Re: 3G problems
Mon Nov 28, 2011 7:05 pm
will NAT help or Static Routes help?
anywhere on forum where i can read about this 3G USB data forwarding to Ether1 and WLAN1 ??
dasiu
Trainer
Trainer
Re: 3G problems
Mon Nov 28, 2011 9:16 pm
Have you read my last post? Well, I will try to put it in simple words. Just add:
/ip firewall nat add chain=srcnat action=masquerade out-interface=ppp-out1
saintofinternet
Forum Veteran
Forum Veteran
Re: 3G problems
Tue Nov 29, 2011 5:28 am
tried it but still not working... :(
following are my settings....
saintofinternet
Forum Veteran
Forum Veteran
Re: 3G problems
Tue Nov 29, 2011 11:44 am
normis.... yelp!!!
saintofinternet
Forum Veteran
Forum Veteran
Re: 3G problems
Tue Nov 29, 2011 1:32 pm
these are my settings below....
[admin@MikroTik] > ip route print
0 ADS 0.0.0.0/0 10.112.112.123 1
1 ADC 10.112.112.123/32 27.97.194.251 ppp-out1 0
2 ADC 192.0.0.0/8 192.168.1.10 ether1 0
[admin@MikroTik] > ip address print
0 192.168.1.10/8 192.0.0.0 ether1
1 D 27.97.194.251/32 10.112.112.123 ppp-out1
[admin@MikroTik] > ip firewall nat print
0 chain=srcnat action=masquerade out-interface=ppp-out1
still not working :(
although i can ping any website from the Winbox Terminal window.... i cannot browse or ping from the laptop connected to this Routerboard on Ether1.
Laptop IP Config
IP: 192.168.1.1
Subnet: 255.0.0.0
Gateway: 192.168.1.10
DNS: 192.168.1.10
[flash=]HELP!!!!![/flash]
Users browsing this forum: No registered users and 4 guests
