MUM Europe 2020
wildbill442
RB/800 - System rebooted because of kernel failure
Tue Nov 29, 2011 6:55 pm
I'm having problems with a RB800 rebooted every ~24hrs.
The RB800 is running RouterOS v5.7, and has 4 x R52Hn-m cards.
The error message is written in the log file after reboot. Contents of the autosupout.rif file include the following:
routerboard: yes
model: 800
serial-number: 24D301AFE4E1
current-firmware:
upgrade-firmware: 2.30
BIOS
bad command name bios (line 3 column 18)
SETTINGS
baud-rate: 115200
boot-delay: 5s
enter-setup-on: any-key
boot-device: nand-if-fail-then-ethernet
cpu-frequency: 800MHz
memory-data-rate: 400DDR
boot-protocol: bootp
enable-jumper-reset: yes
silent-boot: no
In bold are the items I've found to be odd....
I'm going to upgrade to 5.9 and upgrade the routerboard's firmware as well.. Hopefully this will resolve the problem. Just wanted to check to see if any others were experiencing similar issues and found a resolution.
I'll be opening a support ticket with Mikrotik shortly.
The board is fairly new and has been in service for about 3 months. I can't tell when the problem first happened as the routerboard reboots before the monitoring software can poll the device and detect a problem.
William Burnett
Network Engineer
honzam
Re: RB/800 - System rebooted because of kernel failure
Tue Nov 29, 2011 7:11 pm
I have the same problem with 5.7 and no current BIOS. Try upgrade and mainly bios
/ system routerboard upgrade
LAN, FTTx, Wireless. ISP operator
wildbill442
Wed Nov 30, 2011 6:56 pm
I upgraded to 5.9 and upgraded the firmware about 20hrs ago.. Only time will tell if it holds..
William Burnett
Network Engineer
wildbill442
Thu Dec 01, 2011 7:09 pm
Well that didn't resolve it. Same problem, "kernel failure" error in the logs a "/system routerboard pr" shows a null field under current-firmware.
I have an open ticket with mikrotik support hopefully a fix will come soon.
William Burnett
Network Engineer
uldis
Fri Dec 02, 2011 6:42 pm
what power supply you are using and how many Amps/Volts does it provide and are you using POE? if yes, how long is the cable?
wildbill442
Wed Dec 07, 2011 1:01 am
Uldis - I'm using a Passive POE with a solar setup.
48VDC system
8 x 6VDC AGM 150Ahr Batteries
8 x 175Watt 12 VDC Panels (2 x 48VDC arrays in parallel)
Charge controller
Not sure on amperage, its just drawing whatever is needed. There's more than enough power at this site its completely overkill as it was designed for a much larger scale setup. The ethernet run is about 50-60' total.
I have two other RB800 boards, three total, at this site and this one with the R52Hn cards is the only one exhibiting the symptoms.
As you suggested I'll be replacing the R52Hn cards with another brand, either the F52N-Pro's from UBII or SR71-15 from Ubiquiti. I have my technicians scheduled to do the swap this Friday.
William Burnett
Network Engineer
i-netp
Trainer
Trainer
Tue Jan 03, 2012 1:50 pm
was this problem solved? I'm asking because i have the same. The current-firmware-version (bios) won't be displayed and the router reboots many times with exactly the same message "kernel failure". I have currently version 5.5 running on the board. The board is connected to 24POW. Do i need to install a 48V power-supply? Is this recommended?
Regards
Hans-Peter Straub
Hans-Peter Straub
Network Administrator mainly based on MikroTik Routerboard and RouterOS
honzam
Tue Jan 03, 2012 3:38 pm
upgrade bios to 2.30 http://routerboard.com/fwf/91/mpc8544-2.30.fwf
then in new terminal
/system routerboard upgrade
and then upgrade ROS to version 5.11
http://download2.mikrotik.com/routeros-powerpc-5.11.npk
i-netp
Trainer
Trainer
Thu Jan 05, 2012 12:20 pm
I've updated the bios to 2.30 and the RouterOS to 5.11. The Board now runs a works a little longer, but do also a "System reboot because of kernel failure".
And in the Routerboard there is again no current-firmware visible.
[admin@AP] > system routerboard print
routerboard: yes
model: 800
serial-number: 24D301AE1B31
current-firmware:
Does someone have any idea?
Hans-Peter Straub
Hans-Peter Straub
honzam
Thu Jan 05, 2012 2:31 pm
deadyou12
Sat Jan 07, 2012 6:16 am
Hello, i need help. i have RB1100AH x2, and i use for router bgp and qos. on first day, the router working good, and uptime 28 hours. suddenly, my router reboot and the logging show : system rebooted because of kernel failure. i bought a new for the router. this is my router health and my routerboard status :
[ade@aline] > system routerboard print
routerboard: yes
model: 1100AHx2
serial-number: 319E02529E5F
current-firmware:
upgrade-firmware: 2.38
[ade@aline] > system health print
fan-mode: manual
use-fan: auxiliary
active-fan: auxiliary
voltage: 12V
current: 945mA
temperature: 36C
cpu-temperature: 41C
power-consumption: 11.3W
What i should have to do for the problem. Thx.
honzam
Sat Jan 07, 2012 11:11 am
There is NO current-firmware. Contact support. I have the same problem with rb711G-5HnD
tarekomari
Tue Jul 17, 2012 1:30 pm
I have the same problem, but the router reset it self each 1 min.
not solved yet???????????
batot
Sun Aug 11, 2013 3:26 pm
I was RB435G AP/bridge1/TX=10dBm <------> station bridge 1 RB433
AP/bridge2/TX=10dBm <------> station bridge 2 RB433
All wersion Router OS 5.20 and 6 time per hour disconnect.
Was change all to 5.25 and no dissconect. Uptime 2days ;)
Version Router OS 5.20 was BAD.
Good luck.
Users browsing this forum: Majestic-12 [Bot], marisv, MSN [Bot] and 98 guests
