gmsmstr
Trainer
Trainer
ROS v6 Suggestions
Wed Nov 30, 2011 11:41 pm
How about updating the P-Throughput field to be more accurate and work in all wireless protocols.
Then we should have this field update every x often (ability to set the x).
Then have that as a $wlan1_pthoughput variable that changes.
Then have the ability to set queue tree and simple queues with simple math expressions =$wlan1_pthoughput * .25 ..
This would allow us to create pthroughput QoS systems dynamic based on the actual link. Also addition of pthroughput options on other types of interfaces including Ethernet etc, so that we can use it as well.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
doush
Long time Member
Long time Member
Re: ROS v6 Suggestions
Thu Dec 01, 2011 11:04 pm
very creative idea. +1
nz_monkey
Fri Dec 02, 2011 12:05 am
Yes, this is a brilliant suggestion.
+1
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
pospanko
Fri Dec 02, 2011 9:47 am
Yes, this would be great to have!
+1
P.S. Add to hotspot profile - "Incoming/Outgoing packet mark" two more mangle rules. Not only packet marks but also a connection mark before them and use that conneciton mark for packet marking. This would make my life easier and my router would finally bread with full loungs beacause I must use this kind of setup, with every client seperate marked.
Internet, Mikrotik & Network solutions
http://www.pro-ping.hr
gustkiller
Tue Dec 06, 2011 1:42 pm
Support for ECMP labels for mpls ( so we can have dual or more paths to the same destination working).
Support BGP BASED LABEL Distribution for mpls
Support L2 MTU settings like Routerboards
littlecake
Thu Dec 08, 2011 9:26 pm
MPLS Fast Reroute - For high speed redundancy of network
tav
Fri Dec 09, 2011 10:45 am
- routing bgp advertisements
change to:
routing bgp peer print [xxx] advertisements
routing bgp peer print [xxx] routes
where [xxx] - name peer or number
mrz
Fri Dec 09, 2011 10:50 am
peer menu is for peer configuration.
advertisement menu is for advertisements and advertisements already can be printed by peer name
/routing bgp advertisements print peerx
savage
Mon Dec 12, 2011 1:53 pm
64-bit counters in the wireless registration table?
Regards,
Chris
Stanislav Hrncir
Tue Dec 13, 2011 9:53 am
Take real-time graphs from webbox to the own page - "realtime graphs" without login on default page
bawolek
Tue Dec 13, 2011 7:26 pm
Hi
i think its will be very usefull to add "local adress list" parameter to User Manager/Users for example in my network I have UM on border router with QoS and limitation based on PCQ and adress lists of clients,
but address lists I use for filtering, redirect to any web pages and many diferent things on this border router. will be great if i can use something to add "remote IP to" address list on the same router with "user menager"
for this moment user menager sent "adress list" to radius client but this client only terminating pppoe sesion
I hope that everyone understands what I mean
cjohnson0692
Thu Jan 26, 2012 1:17 am
It would be very nice for the wirless advanced settings to be able to adjust the SIF, SLOT, and ACK timing by hand and also make it so you can see the values change when setting different distances. As it seems that is a very big part of why there are speed issues and bit erros over the air, especially in 802.11n. Also it would be nice to have the ability to adjust the beacon interval on AP and Bridge mode, this way it can deal with noise better if you can set the beacon from a range of 10ms to standard 100ms. I have helped develope many wireless products and these are a must for performance.
paulwollner
Fri Jan 27, 2012 11:04 pm
I would really like to see LAC / LNS functionality in RouterOS. I am sure that there are others who would find this functionality rather useful.
fuzzbawl
Fri Jan 27, 2012 11:44 pm
I would love to see Winbox support more than just CHAP protocol when authenticating winbox logins to Radius. I would really like to see it support MS-CHAP or PAP specifically. We use encrypted LDAP backend and it only supports PAP or ntlm_auth challenge tokens, which excludes CHAP. Makes it very annoying to try and maintain our login accounts.
docmarius
Tue Jan 31, 2012 1:23 am
I would really like NOS-style point to multipoint IP tunnel support backed up by proper RIP handling.
This would give backwards compatibility with current implementations and add great flexibility:
-usual endpoint setup -> works the same as now
-setup without target address (anonymous target address) -> allow adding multiple targets via add route commands (so that the added gateway represents a tunnel endpoint for that IP address or network via the IPIP interface)
-accept RIP broadcasts via the IPIP interface to setup these endpoints dynamically (RIP containing address/mask and gateway which will be the endpoint for that interface - this also needs a network and gateway ignore list option for own network segments on other interfaces)
-send out the interface routing via RIP (address/mask with endpoint as gateway)
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
chris84
Thu Feb 02, 2012 2:58 pm
+1
w0lt
Long time Member
Long time Member
Thu Feb 02, 2012 7:16 pm
I would like to see Winbox support a "skin" type of environment.
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
aysan
Thu Feb 02, 2012 9:34 pm
Please back to UM CLI commands as v4.x. Especially assign profile to user is not useful on new version.
For me, credit system was much better then profile. I couldn't use properly.
But caller id good feature v5.x.
lionspy
Mon Feb 06, 2012 8:51 pm
I would like to see a new linux kernel with built-in accel-ppp driver.
keefe007
Wed Feb 29, 2012 11:06 pm
samsung172
Wed Feb 29, 2012 11:24 pm
dont change syntax, so old scrips still working.
nz_monkey
Thu Mar 01, 2012 4:21 am
+1 !!!!!! :)
cearnshaw
Thu Mar 01, 2012 7:25 am
How about we just let them make V5 stable before they start on another major release?
rmichael
Forum Veteran
Forum Veteran
New Winbox Suggestion
Tue Mar 06, 2012 2:55 pm
Include packet flow diagram within winbox for easy reference. I find myself time and time again looking for it when things go not as expected :lol:
mrz
Re: New Winbox Suggestion
Tue Mar 06, 2012 3:08 pm
Manual Is accessible from winbox, so you can easily open packet flow diagram in winbox.
rmichael
Forum Veteran
Forum Veteran
Tue Mar 06, 2012 3:57 pm
Hi mrz
Currently the diagram is not accessible when internet is down (perhaps due to misconfiguration) or blocked.
CyberT
Mon Mar 12, 2012 9:07 am
3 things i would love to see
1) Notes. <- A simple manual entry log by admins that go , ##date time $user, "disbaled wilan2 - Grid removed for maintenance" <- or something like that just so that if you login to a router you can see what someone else has done,
2) "Better flow tracking in winbox" oftine i can see a ip that's using a lot of bandwidth on the "pppoe-out" but finding that on the inside network takes a little bit of time, and geussing. would be nice to have the option to see actual source and actual dest as well, or like in the firewall with connection tracing, have the ability to see the Throughput there.
3) "wireless snapshot" - After configuring a link be able to take a snapshot that will store the tx-db rx-db and ccq for the link, then at a later stage you could click compare, and you will be able to see what the link quality is compared to what it used to be. its helpful when you do maintenance on many many sites, then you can off the bat check if the link has changed. Could even be used to bring notify you if your link changes by more than 9db @ speed, or whatever...
If this helped you then please slam that Karma button :-)
normis
Mon Mar 12, 2012 9:10 am
1. there is echo log, there is comment feature, etc
2. there is Torch
samsung172
Mon Mar 12, 2012 6:50 pm
record data from an interface over time. xml, cvs, txt or something. just make a file with desired values.
eg:
/interface wireless *get=some of the values" "duration = some time" "time = 1s"
and a file that would be something like:
wlan1
CCQ,TX,RX etc etc etc
xxx,xxx,xxx,xxx,xxx <- from 1s
yyy,yyy,yyy,yyy,yyy <- from 2s
zzz,zzz,zzz,zzzz,zzz <- from 3s
I know there are possible getting this in other way, (eg SNMP, still limited) but to get values over a period of time, or during some kind of test to a file would be a nice feture.
a lot of use.... signal strengt/rates over a time... etc etc etc. i changed a rate. what does signal do? have this in a format that is possible to use. maybe in exel, import to a sql etc.
honzam
Mon Mar 19, 2012 11:25 am
From MUM Poland. When public testing?
LAN, FTTx, Wireless. ISP operator
Chupaka
Mon Mar 19, 2012 12:32 pm
superchannel license was cancelled in v4. is it back in v6?.. %)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
simnet
Mon Mar 19, 2012 1:32 pm
where from it is possible to take 5.15 beta versions or 6 alpha01?
normis
Mon Mar 19, 2012 1:47 pm
nowhere :(
Chupaka
Mon Mar 19, 2012 2:06 pm
nowhere :(
... just because they are product of your imagination... xD
andressis2k
Tue Mar 20, 2012 1:15 am
nowhere :(
My RB751G and Groove doesn't says the same :D
napismizpravu
Tue Mar 20, 2012 1:48 am
Nevím co to tu na nás zkouší.
Stanislav Hrncir
Tue Mar 20, 2012 10:12 am
napismizpravu: we are on ENGLISH forum only!
honzam
Tue Mar 20, 2012 10:42 am
Where to download? Why MikroTik is silent?
Presence would be good to provide a download for a limited number of users to be able to report bugs
normis
Tue Mar 20, 2012 10:51 am
RouterOS v6 doesn't exist yet. NOWHERE to download at the moment.
honzam
Tue Mar 20, 2012 11:10 am
Normis and what is v6.0alpha1 on x86 and on rb800 (the picture above)
Alessio Garavano
Tue Mar 20, 2012 7:16 pm
Yeah! share share! :)
Alessio Garavano
http://www.isparg.com.ar
napismizpravu
Tue Mar 20, 2012 7:34 pm
Alessio Garavano
Tue Mar 20, 2012 8:56 pm
thx bro! :)
Alessio Garavano
daan99
Tue Mar 20, 2012 9:25 pm
How about option for HA router
http://conntrack-tools.netfilter.org/manual.html#sync
connection table synchronization....
bambangs2komputer
Thu Mar 29, 2012 11:46 am
Done test in my RB450
My toplogy
Modem ADSL (Mode brige)>>>>(RB450 ether 1 PPPOE>>>>ether 2 to ether 4 bridge config hotspot,ether 5 DHCP without hotspot)>>>ether 2 to ether 4 conect access point, ether 5 test cable&access point)
Problem is in ether 5 show web login like in ether 2-4
Why? :lol:
napismizpravu
6.0alpha1 problém
Fri Mar 30, 2012 10:14 am
update 5.15rc1 (29.03.2012) >>> 6.0alpha1 (29.03.2012) = routerboard RB433UAH DHCP server deleted (restore backup OK)
CPU 100% 6.0alpha1 problém >>> downgrade 5.15rc1 OK :lol: :D
edit: update 5.15rc1 >>> 6.0alpha1 (30.03.2012) RB433UAH DHCP server and CPU OK
edit: 6.0alpha1 (30.03.2012) CPU - DHCP problém
I'd like to reset button (reload) of the USB Flash disk. After the updates, the disks used interchangeably, the correct sort order to shutdown and turn on the routerboardu. (bing translator)
Chtěl bych tlačítko reset (znovunačtení) USB Flash disků. Po aktualizacích se disky zaměňují, správný řazení až po vypnutí a zapnutí routerboardu. (czech)
omidkosari
Trainer
Trainer
Fri Apr 13, 2012 2:38 pm
PPPoE option 82
With this featue you may understand that a pppoe user connected from where (eg. which port of switch , dslam )
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
nz_monkey
Re: Re: ROS v6 Suggestions
Fri Apr 13, 2012 11:41 pm
PPPoE option 82
+1
slech
Long time Member
Long time Member
Sun Apr 15, 2012 9:09 am
Charts option - 1min
EMOziko
Sun Apr 15, 2012 4:33 pm
Some IPS/IDS functions will be great.
We want new versions of The Dude!!!!!!!
NetworkPro
Mon Apr 16, 2012 1:02 am
I agree.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
proggams2
Thu Apr 19, 2012 12:01 am
A good feature will be:
Remote site scan (survey) (maybe it could be applicable in webfix)
anajavi
Sat Apr 21, 2012 1:51 am
A way to configure which protocols are bridged. Like a BROUTING chain on bridge firewall.
I would like to bridge only IPv6 on one interface and route IPv4.
Chupaka
Sat Apr 21, 2012 3:55 am
just use 'redirect' action in bridge nat for everything you need to route
hajde
Wed Apr 25, 2012 2:30 pm
PPPoE option 82
Yes, +1.
ranpha
Wed Apr 25, 2012 8:07 pm
I hope that when v6 goes final, it has a fully working DHCPv6 support in it.
ochyst
Wed Apr 25, 2012 9:31 pm
I hope too, that dhcpv6 will have a full support!
hel
Mon May 07, 2012 9:01 am
I'll be happy, if there will be LLQ (Low Latency Queueing).
Our clients often calls to a support angrily, because their online games latencies goes to a non-playable 300-1000 ms, or social networks loads really slowly, that's because of hidden windows update, forgot torrents, antivirus updates, etc.
With LLQ we can force packets with higher priority to take over other traffic. With current QoS implementations we can't.
Chupaka
Mon May 07, 2012 11:41 am
yeah, prioritizing packets in queue (by means of reordering) is my long-standing dream... %)
chojrak11
Mon May 07, 2012 1:01 pm
1) VRRP watching other VRRP interface. If I have 2 VRRPs - one on LAN side and one on WAN side, sometimes I want to switch both interfaces if one of them fails. This was discussed a few times.
2) Reverse Path Filtering - loose and strict mode - long wanted feature
3) Ability to run scripts on interface up / down
4) Ability to run scripts on route up / down (route watch mechanism where I specify particular route and do things when it becomes unreachable, and when it's brought online again)
5) Warning window after login - for example I'd like to warn other users: DO NOT REBOOT THIS ROUTER (because it hangs when rebooting). And sometimes I'm unable to email them. And I know they don't read logs
6) More granular permissions - as you have in logging (by topic) - for example I want to delegate DHCP administration to my fellow, with no access (or read access) to other subsystems of the router
7) (That's fancy, I know) ability to run scripts on firewall rule match
8) Stability stability stability...
That's for now, thanks.
janisk
Mon May 07, 2012 2:19 pm
should be scriptable, check wiki about VRRP
no answer to that yet.
hmm. it is doable, but requires a lot of resources now
have you tried netwatch for this?
/system note set show-at-login="<the text>"
this will show note when someone logs in.
that will put router under even heavier load when DoS'ed
working on that always.
Chupaka
Mon May 07, 2012 3:12 pm
but only in CLI, not in WinBox
'limit' matcher rules ;)
karlos
Thu Jun 07, 2012 10:15 am
May be this is not all about ros 6.xx wishes , may be its also about new winbox but still please read it.
Queue rates:
I think its time to update the queue speeds for todays needs. I can put it manualy, but it will be faster if its in the list box may be.
Prefered views:
We have some preffered views something like we like to view
in queue list:
Rx/TxMax Limit, Rx/Tx Avg. rate and Total Rx/Tx Bytes
in Wirelless Table:
Radio name, Mac, Ros Version, Rx/Tx signal, CCQ
etc...
So we would like the have possibility set this as default view in each RB.
Upgrades:
We would like to be able upgrade RB firmware remotly in whole network (all steps from 2.9.xx to 2.9.51->3.30->4.17->5.17)
We would like to be able upgrade RB ros remotly in whole network
Licence:
We would like to be able download and archive all licences in whole network
We would like to be able update licence in ros 3.30 automaticly in whole network before upgrading to 4.17
Another bash:
We would like to see possibility to set some parameter using some bash on whole network (RBs and ros) like wirelless neighborow discover = yes or Datarates = advanced
So most of our wishes are about using many RBs and make it easyer manageable to save time.
slech
Long time Member
Long time Member
Fri Jun 08, 2012 7:46 am
Maybe like Cisco ASA ?
Role:
DHCP-Admin
Permitted Commands:
ip dhcp-server config
ip dhcp-server add
ip dhcp-server print
chojrak11
Fri Jun 08, 2012 11:33 am
Upgrades:
Possible today, just use Dude, it's a matter of one right-click in Dude. How you imagine doing upgrade for multiple devices without central management server? I've never seen such a technology ;-)
As for boot firmware, it's a matter of writing a really simple script that would do the upgrade.
karlos
Fri Jun 08, 2012 10:03 pm
Upgrades:
you are not right at all
you cant just upgrade from 2.9.40 to 5.17 in one click
yout need to upgrade to 2.9.51, 3.30, update bootloader, update licence, upgrade to 4.17, upgrade bootloader, upgrade to 5.17, upgrade bootloader better again, and than set all the parameters what was not implemented in 2.9xx version, like disable MPLS package, set datarates to advanced, set protocol to all or nv2 or what do you want etc...
So no easy upgrade possible
chojrak11
Fri Jun 08, 2012 10:17 pm
Upgrades:
Yeah but you can upgrade all devices to 2.9.51 in one click using Dude.
How do you imagine an automated protocol that will disable MPLS and set datarates to advanced and so on and do "or what do you want" automatically inbetween the specific upgrades for the whole network? And maybe for my network I would want MPLS enabled? Still not getting that the idea is insane? The easiest part that you want is to read your mind.
I'd handle all that you want with scripts.
napismizpravu
Sat Jun 16, 2012 4:12 am
Proxy:
add redirection proxy server output interface (two WAN -internet input)
block not to show info about blocking ads on the page-I have to deal with by redirecting to the empty page in metarouter
5.18rc1 (RB433UAH) error NAT statistic (statistic Filter Rules and Mangle OK)
janisk
Mon Jun 18, 2012 1:47 pm
please send supout.rif file to the support.
Takv2011
Thu Jul 05, 2012 3:47 am
+1 +1 +1 +1 +1 +1 +1 +1 +1 +1 SUSCRIBE!!!!!!!!!!!!!!!!!!!! This would be the best RouterOS implementation ever!
Always having problems with latency on games when using RouterOS QoS system (pcq, fifo, bfifo, etc) when there's a high load on the network.
This would be the better implementation ever!
NetworkPro
Thu Jul 05, 2012 8:05 am
I disagree with the above post and what it quotes. Currently it is possible to make a good QoS config. But it is not easy.
hel
Sun Jul 08, 2012 3:34 pm
Low latency QoS? I don't see any possibility of how to do it with current functionality.
NetworkPro
Sun Jul 08, 2012 7:46 pm
RouterOS does "selective drop" with recommended small queue sizes.
P.S. upgrade to gigabit ethernet and you should not need LLQ
hel
Mon Jul 09, 2012 2:42 am
But higher priority on the traffic let to drop high priority packets. It's absolutely unacceptable that low priority packets gets over higher ones.
Are you serious? Look at peoples configs over the forum, their internet speed commonly isn't wider than 40mbit. What they can do with voip and games that requires low latencies on hard line load?
NetworkPro
Mon Jul 09, 2012 8:32 am
I am Sorry. Gigabit ethernet is the truth. You can have 40 meg service but the ethernet rate needs to be gigabit so that when you transfer 39 megs/FD - your latency would be great for games and VoIP. Right? :)
Use a switch facing the ISP and feed priority packets on one ifs port. Cheaper switches support sending frames the way LLQ jumps the queue for priority packets.
Be careful not to jump the queue for different packets of one TCP connection.
tact1982
Fri Aug 31, 2012 7:14 am
I suggest support text messages in user manager 6 by bulk sms services
Like
http://www.bulksms.com
http://www.smsglobal.com
http://www.clickatell.com
http://www.infobip.com
So that I can send sms messages automatically ..
For example
Send auto sms an alert two days before the end time
Send auto sms new end time upon renewal or add new profile
Send auto sms promotional ads for all users
Send auto sms reminder daily or every 3 day when you do not pay the fees
NetworkPro
Wed Sep 19, 2012 9:12 am
I have read your comment on Mikrotik Forum about LLQ
Which Hardware do you need for this ?
best regards
My comment above to use a switch to jump a packet queue is very far from optimal for solving anyone's QoS problems :D
Often the problem is that the upstream connection (even expensive ones) is not good. For example - it can not handle many packets per second or full duplex load.
This is often the case and a reason why I want to use smart Auto-QoS solution and why I was suggesting such software to be made for the routers.
Until we have such solution that is practical to use, manual QoS config needs to be made for each specific case. And if we need to give priority to a lot of VoIP and gaming packets - the TCP download speeds will be much lower.
The solutions sometimes includes balancing multiple connections to increase the total number of PPS.
If someone needs such problem solved - they can contact me with a commercial request to implement the configurations on RouterOS for this.
But better yet - get better upstream connections - connect via GigabitEthernet . If your local providers are dummies and lazy - push them more aggressively. "The packet rate to their router must be very high and full duplex - on top of that - have your specific shaped service. The latency for different size packets must be less than 2ms under load optimally under 1ms." paste this quote to whoever you are buying the service from. Demand the quality and compete OR if not - be a masochist and pay high prices.
So far history shows that ISPs take the load-balancing route and after few months/years - cheaper Ethernet/Ge is available and the switch is made. And I make a few PayPal bucks along the way, helping with the config.
Users browsing this forum: Bing [Bot], dvdhngs, dzo, MWComms and 91 guests
