mhnpc
How to use the IPSec in Windows 7?
Fri Dec 09, 2011 12:36 pm
I want to use the IPSec protocol in the Windows 7, How to I do it?
Setting of IPSec in the WinBox:
Setting of IPSec in the VPN Connection:
Finally, I get this error:
jandafields
Re: How to use the IPSec in Windows 7?
Thu Dec 22, 2011 11:48 pm
Basically, you have to get it 100% exact on both sides, or it will fail. IPSec is VERY unforgiving. Follow the wiki exactly and it should work.
normis
Fri Dec 23, 2011 10:41 am
Here is a IPsec windows tutorial, maybe some useful info there:
http://wiki.mikrotik.com/wiki/MikroTik_ ... IPSec/L2TP
Andre81
Sun Dec 25, 2011 8:06 pm
@normis,
the guide didn't work on windows 7.
I've followed the guide, but simply didn't work.
Please, can anyone share a working Mk <-> W7 configuration for l2tp/ipsec
thanks
A.
Krusty
Tue Mar 06, 2012 10:37 am
I have same problem, Im trying to configure L2TP/IPSec client (Win7) to server (ROS). Client is behind NAT (in almost all scenarios), server is with public IP.
I have tryied this guide http://wiki.mikrotik.com/wiki/MikroTik_ ... IPSec/L2TP but it didnt work
When I try to connect to server I can see that client touches server, it is wisible in "Remote peers". But in logs I have error "no suitable proposal found" and "failed to get valid proposal".
please anybody for help :)
thank you
Krusty
Tue Mar 06, 2012 12:50 pm
thank you
so for now it started working :/ for some reason I dont understand.
Krusty
Tue Mar 06, 2012 2:52 pm
hello again :)
I think last question about this kind of VPN. For now I have working L2TP/IPSec VPN. Last think I want do do is to set diferent IP range to VPN clients and diferent range to LAN.
Here is what I think about....
My LAN is 192.168.1.0/24
I want VPN client to take address from ROS pool (192.168.222.10-192.168.222.254) so I set VPN profile to give clients this addresses, and also to set address from this pool to the VPN server.
When I connect I will have (on client side) eg. 192.168.222.253 (server) and 192.168.222.252 (client)
My question is, how can client on VPN with address from range 192.168.222.0/24 access LAN range 192.168.1.0/24. I must say I have tryed everything I know. Turned off firewall, add src and dstnat from one network to another, etc etc.
please anybody :)
thank you
Andre81
Wed Mar 14, 2012 11:01 pm
Have you tried to set proxy-arp?
Users browsing this forum: Google [Bot], kakaxa and 46 guests
