MUM Europe 2020
ergismilo
RB 1200 PPPoE Sessions
Fri Dec 09, 2011 3:08 pm
Please,
Have anyone tested RB1200 as a pppoe server (BRAS)?
How many sessions does it support? With previous routers we couldn't go higher than 500 session.
Because the router gets loaded.
Thank you
sadeghrafie
Long time Member
Long time Member
Re: RB 1200 PPPoE Sessions
Sat Dec 10, 2011 1:45 pm
As RB1200 has level 6 license, it must accept more than this (Unlimited) >> http://wiki.mikrotik.com/wiki/Manual:License
Mikrotik Route My Life
Someone Says: Don't forget to give karma
JorgeAmaral
Trainer
Trainer
Sun Dec 11, 2011 3:20 am
Level 6 has no limits.
But from what i understand, you concern is how much clients it supports while running bellow 100%.
Well, this is a very tricky answer, it depends on the config of the RB1200 and the BW that you give to each customer.
Router performance normally is measured in packets per second, and if you go to the RouterBOARD page you can see that for router it does about 117.000 pps for big downloads (MTU=1518), and this is quite allot for it´s price.
For a simple iperf tcp test between to linux machines with RB1200 in the middle, with routing and simple firewall rules (connection state evaluation), it does about 680Mbits of throughput.
But for a small difference in price, you have RB1100AH that almost doubles the performance of RB1200 (208.500 pps)
oeyre
Mon Dec 12, 2011 5:39 am
How many sessions?
Average throughput per session?
Do you have complex firewall rules?
Are you running any other features? (NAT, QoS, proxy)
etc etc
maxstel
Trainer
Trainer
Mon Dec 12, 2011 4:42 pm
We use a RB1200 as PPPoE server.
ROS version: 5.8
About 70/80 simple queue simultaneously
No traffic shaping
External radius
A few filter rules
CPU: 30-50%
I don't think it will manage 500 users...
Bye
Massimo Passerini
STEL S.r.l.
Ferrara - Italy
MikroTik Certified Trainer
rodolfo
Long time Member
Long time Member
Mon Dec 12, 2011 5:23 pm
consider a RB 1000 could authenticate 600 pppoe users without any other service
rodolfo
IZ0UQV
Users browsing this forum: No registered users and 88 guests
