normis
v5.11 released
Mon Dec 12, 2011 4:35 pm
What's new in 5.11 (2011-Dec-12 11:05):
*) hotspot - fixed https login (broken in v5.9);
*) eoip: swap tunnel id bytes to be compatible with previous versions;
*) eoip,gre: fix setting config
What's new in 5.10 (2011-Dec-09 11:49):
*) snmp - provide extended interface statistics when availabe;
*) dhcpv6 client - use link-scoped multicast address;
*) dhcp client - renew dhcp lease on ethernet link up event;
*) ipv6 gre tunnel added (/interface gre6) supports ip and ipv6 encapsulation;
*) ip gre tunnel supports ipv6 encapsulation;
*) allow setting bigger trafflow cache;
*) improved RB1200 stability when using ether9,ether10;
*) fixed RB1200 stability issues when using crypto hardware acceleration;
http://download2.mikrotik.com/routeros-mipsbe-5.11.npk
http://download2.mikrotik.com/routeros-mipsle-5.11.npk
http://download2.mikrotik.com/routeros-powerpc-5.11.npk
http://download2.mikrotik.com/routeros-x86-5.11.npk
mars
Re: v5.11 released
Mon Dec 12, 2011 4:47 pm
why is the torrent not workig
normis
Re: v5.11 released
Mon Dec 12, 2011 4:48 pm
what is not working exactly? a lot of others are downloading it with no issues, we can see the many transfers in our tracker.
Antixx
Re: v5.11 released
Mon Dec 12, 2011 5:19 pm
I still have problem useing eoip tunnel between 4.17 and 5.11
arturw
Re: v5.11 released
Mon Dec 12, 2011 7:13 pm
RB433 from 5.9 to 5.11 successfully upgraded.
Alessio Garavano
Re: v5.11 released
Mon Dec 12, 2011 7:44 pm
Hi Normis, 2 x86 Core PC/RouterOS with 5.10 are rebooting frequently...
Downgraded to 5.8 and problem solved...
v5.11 do something with that?
Thanks and Regards!
Alessio Garavano
http://www.isparg.com.ar
uldis
Re: v5.11 released
Mon Dec 12, 2011 8:04 pm
What boards you have on both ends?
Could you make a support output file from both of them and send to support@mikrotik.com
lordzar
Re: v5.11 released
Mon Dec 12, 2011 9:44 pm
2 updates in the last week and no fix for the metarouter interface enumeration problem?
Antixx
Re: v5.11 released
Tue Dec 13, 2011 12:21 am
I will send it to support team eoip tunnel is very important to me.
normis
Re: v5.11 released
Tue Dec 13, 2011 7:35 am
Are you sure? Did you test, or are you just commenting the changelog?
MrKimbo
Re: v5.11 released
Tue Dec 13, 2011 9:43 am
I did an upgrade from 4.13 to 5.11, and manually installed the user-manager, reboot, then CPU load is 100% and user-manager not working. I see in the profiler, user-manger taking more than 90% cpu usage. So I've disabled it, and now all wireless/hotspot client can't connect. :(
Any suggestions?
sergejs
Re: v5.11 released
Tue Dec 13, 2011 2:59 pm
MrKimbo
Any suggestions?
Answer depends on package you had before upgrade,
- v4.x usermanager-test, there should not be any problems with upgrade from v4.x to v5.x;
- v4.x usermanager, in some cases there could be problems, and it is easier to start new configuration, if you want to avoid manual reconfiguration of profiles and users.
Please make new post in User Manager section for questions about User Manager!
MrKimbo
Re: v5.11 released
Tue Dec 13, 2011 3:49 pm
Since the user-manager is not installed by default, so I installed it manually using the file "user-manager-4.13-mipsbe.npk" which is extracted from "all_packages-mipsbe-4.13.zip". So, what should I do? Is there any better solution than resetting the ROS to default and reconfigure all again?
When user-manager from 5.11 installed, it's hard to do anything, cpu load is 100% and winbox become very slow respond. Tried to clear the user-manager database also doesn't works, it said timed-out or something.
jcem
Re: v5.11 released
Tue Dec 13, 2011 4:06 pm
Any suggestions?
Did you wait long enough? It takes a while for the database to convert/rebuilt. In the meantime the cpu load will be high. I had trouble upgrading from 5.8 to 5.9. I havn't tried 5.11 yet. Maybe you shuld try 5.8?
Before upgrading - make sure there are no special characters("-+%€öäå" etc) in profile names, router names etc. and the upgrade will be smother
RGDS
MrKimbo
Re: v5.11 released
Tue Dec 13, 2011 4:39 pm
Yes, i thought it so. Have been waiting for more than half an hour but still no different.
I already make sure, there's no non-alphabets char.
jcem
Re: v5.11 released
Tue Dec 13, 2011 5:27 pm
Just some ideas:
1. If you see both "flash" and "userman" in profile with high % - the chance is its still trying to convert. Maybe using an other RB or x86 with more memory will
do it better...
2. What about trying 4.17 with userman test-package. Run, rebuild and then update to ROS 5....
zervan
Re: v5.11 released
Tue Dec 13, 2011 7:12 pm
I've upgraded RB751 from 5.10 to 5.11 and it was strange then - rebooting immediately after connecting any cable (from empty switch too) to any of switched ports 2-5. Counter "Total Sector Writes" was erased. I saved config and supout file, then tried to reset configuration using jumper - it was all right then, after loading configuration as well.
Dusan Zervan from Slovakia
MTCNA, MTCRE
uldis
Re: v5.11 released
Wed Dec 14, 2011 7:41 am
what did you see in the log file after the the reboot?any auto support output file generated?
zervan
Re: v5.11 released
Wed Dec 14, 2011 9:18 am
There was something about not proper shutdown in the log file, but I didn't see any supout file. I have supout before crash - I saved it (using ether1 - only port without problems), then connected cable to other port, router crashed immediately and was not able to boot until cable was removed. I can send the supout if it could help to avoid similar behaviour in the future.
MTCNA, MTCRE
nik247
Re: v5.11 released
Wed Dec 14, 2011 11:48 am
Thanks and Regards!
+1
Upgrade X86 Core router from 5.7 to 5.11 - rebooting frequently...
Downgaded to 5.9 - rebooting frequently...
Downgaded to 5.8 - problem solved
normis
Re: v5.11 released
Wed Dec 14, 2011 11:50 am
nothing was changed in this area, so I can't see why X86 would reboot on v5.11 and not on v5.8
jcem
Re: v5.11 released
Wed Dec 14, 2011 11:58 am
Hi Normis!
I have a simular issue - see Ticket#2011113066000083
RGDS
Jörgen
janisk
Re: v5.11 released
Wed Dec 14, 2011 12:11 pm
metarouter interface naming will be fixed in 5.12.
goobles
Re: v5.11 released
Wed Dec 14, 2011 2:29 pm
Issue since v5.9 on Routerboard 750.
Packets not being recorded for masquerading on a out PPPOE interface.
zervan
Re: v5.11 released
Unfortunately, router crashed again now - I was using it today since morning lightly, then I started to transfer some data at full speed and router rebooted and cannot boot now when the cable is connected :( There is no automatic support output file, I've created one and I am going to send it to support.
MTCNA, MTCRE
uldis
Re: v5.11 released
Wed Dec 14, 2011 3:19 pm
what power supply you are using, the same that came with the box?
Do you have some usb device connected?
Do you have different power supply to test out?
zervan
Re: v5.11 released
Wed Dec 14, 2011 4:37 pm
yes
no, but I have external antenna connected
EDIT: I've tried to remove it now, but it is still restarting when the cable is connected
yes, I will try on Friday.. I have two RB751, I may try to load the same configuration to it, too
MTCNA, MTCRE
jandafields
Re: v5.11 released
Wed Dec 14, 2011 7:07 pm
I asked for this 2 years ago, and support basically told me too bad, they said it would be a useless feature and was not needed.
Alessio Garavano
Re: v5.11 released
Wed Dec 14, 2011 7:41 pm
If you do not know, you expect from us? :) but in my experience 5.8 is the most stable x86 version...
In many others PowerPC Core Router and Core Switches the 5.11 is wonderful.
Best regards,
Alessio Garavano
bweyrick
Re: v5.11 released
Wed Dec 14, 2011 9:25 pm
Upgraded a RB1200 running ospf, vlans , pppoe and a few eoip tunnels no known issues at this time traffic usually under 20 Mbps will report back if needed. Previous version was 5.7
rodneal
Re: v5.11 released
Wed Dec 14, 2011 10:56 pm
Hey All,
Reporting having to downgrade to v5.9 - main towers are connected but stop passing traffic after 4-8 hours.
Rod
Alessio Garavano
Re: v5.11 released
Thu Dec 15, 2011 2:54 am
Hey All,
Rod
Hi rodneal, can you explain more your question? type, rb, cards, protocols, voltage, etc...
I have testing at 2 days and not having problems in PtP links with v5.11, NV2, RB4xx and RB333, XR5 and R52Hn in MIMO.
Thx and regards!
Alessio Garavano
daitacv
Re: v5.11 released
Thu Dec 15, 2011 3:39 pm
Update from 4.17 to 5.11 went fine.
User-Manager is still working, old account still here but with a default configuration so I'll have to import some more datas by myself. Not a problem.
Just had a look to the new userman webpage, because I'm using my own application to generate voucher and manage my hotspots.
So you changed the credit part to something called profile, with limitation and profile-limitation to bind them all. Too bad we can't assign to a unique user a specific download limitation without generating a new profile.
Anyway, and because I'm using my own application to generate voucher and manage my hotspots, I need to understand how the new User-Manager is working...
I can't understand how you link Users to Profiles.
tl;dr:
How to bind a user to a profile using console/api in the last UserManager.
Cordialy,
daita.
angboontiong
Re: v5.11 released
Thu Dec 15, 2011 4:30 pm
Is possible the transfer speed can bites the microwave ASAP?
tabu48
Re: v5.11 released
Fri Dec 16, 2011 12:32 am
Hello
I trying to ugrade RouterOS from 5.8 to 5.11 on my RB12000 with no succes . When I copy RouterOS-powerpc-5.11.npk file to file folder of RB1200 then suddenly at size of 31,4Kb transfered file , transfer fail , and Router disconect from port . RB1200 is brand new with 2.37 FW .
Is there anything wrong with this release ?
Chupaka
Re: v5.11 released
Fri Dec 16, 2011 1:30 am
try FTP
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
chrone
Re: v5.11 released
Fri Dec 16, 2011 7:38 am
mikrotik could not achieve maximum bandwidth throughput by accessing Rb450G from LAN if using windows machine (7 pro sp1 64bit) (30KBps to 1Mps range only, mostly below 1MBps).
funny thing, after tested from ubuntu machine (11.10 desktop x86) the thoughput went through 6MBps!
the router eth0 is Gigabit, so is the client (windows and ubuntu). is there known limitation/compatibility for mikrotik and windows bandwidth throughput?
everytime i get ahead, i feel more dead.
normis
Re: v5.11 released
Fri Dec 16, 2011 8:02 am
how did you test? what data was transferred, how, and from where to where?
zzipper
Re: v5.11 released
Fri Dec 16, 2011 9:43 am
Hi! I upgrade from 5.6 my RB450G (mrtg) and RB750 to 5.11 And now I Cant configure ip address and gateway through setup command. (
Entries marked by '+' are already configured.
Entries marked by '-' cannot be used yet.
Entries marked by 'X' cannot be used without installing additional packages.
   r - reset all router configuration
 - a - configure ip address and gateway
 + d - setup dhcp client
 + s - setup dhcp server
   p - setup pppoe client
   t - setup pptp client
 * x - exit menu
Sorry for bad eng.
sergejs
Re: v5.11 released
Fri Dec 16, 2011 10:02 am
zzipper, thank you very much for the report! We will try to fix the problem.
zzipper
Re: v5.11 released
Fri Dec 16, 2011 10:06 am
Glad to help! When approximately will fix?
sergejs
Re: v5.11 released
Fri Dec 16, 2011 10:08 am
zzipper, wait for the upcoming versions (most likely 5.12). Now you need to use /ip address as alternative solution.
MichelePietravalle
Trainer
Trainer
Re: v5.11 released
Fri Dec 16, 2011 10:27 am
Thanks and Regards!
+1
+1 ........ (Ticket#2011121666000143)
X86 with 5.11 (on Vmware) will crash frequently with nothing on the log......
downgrading to 5.8 solves the problem...
chrone
Re: v5.11 released
Fri Dec 16, 2011 10:56 am
Mikrotik RB450G on 4.17 or 5.11 eth0 >> 192.168.1.1
Mikrotik RB450G on 4.17 or 5.11 eth1 >> 10.125.1.1
Ubuntu 11.10 Server 64Bit >> 192.168.1.2
Client Windows 7 Pro SP1 64Bit >> 192.168.1.3
Client Ubuntu 11.10 Desktop 32Bit >> 192.168.1.4
i NAT the public address to port 80 on private address and download a file from web server on LAN using the NAT public address with Firefox. Firefox on Windows only put 1MBps on average, rarely burst to 3MBps. Firefox on Ubuntu put 6MBps on average, sometimes burst over 7MBps.
in torch, there are two connections, 192.168.1.2 to 192.168.1.1, and 192.168.1.3/192.168.1.4 to 10.125.1.1 with both produced almost the same throughput in transfer and receive respectively. the data being downloaded was AMD Catalyst driver 11.12 (104MB).
i tried to FTP to the router uploaded and downloaded the routeros upgrade npk and it only puts 150KBps max.
if i bypassed and downloaded directly from 192.168.1.2, both browser downloaded 26-60MBps. only if the client is set with public DNS who translated the domain into its public ip address than the throughput went down badly like it was being limited by mikrotik and i see the mikrotik cpu usage went up to 100%.
to avoid this kind of situation, i added a static DNS on mikrotik to translate the domain into its own private address in LAN. but if someone is using public DNS (OpenDNS, or GoogleDNS) inside the LAN, than their browsing experience is compromised by bandwidth limitation.
i've tried to turn off all mangle, filter, and queue, except NAT, still the problem exists. i haven't had the time to try on other routerboard though. i guess i have another rb450 (the older brother), will test on it and let you know later next week or two.
sigxcpu
Re: v5.11 released
Fri Dec 16, 2011 11:22 am
Thanks and Regards!
+1
+1 here for X86, too. It does not reboot, it just hangs. Needs hard reset. Didn't test 5.9 and 5.10, jumped from 5.8 to 5.11
normis
Re: v5.11 released
Fri Dec 16, 2011 11:27 am
sigxcpu, MichelePietravalle, nik247, Alessio
looks like there is something in common between all your routers. none of our test devices has crashed, we even have some running in our live network.
it's possible you all four use the same feature or function. can you all describe your configured settings in a few words? what did you all configure? do you have queues, tunnels, some specific feature?
MichelePietravalle
Trainer
Trainer
Re: v5.11 released
Fri Dec 16, 2011 11:34 am
You have the supout for my configuration, that is:
- 13 EoIP tunnel to centralize hotspot system
- 5 bridges collecting 5 groups of eoip tunnel
- 5 hotspot servers listening on the 5 bridges
- PPTP + OVPN server with 5-6 active connections
- mangle based on addess lists
- quee tree with pcq queue for hotspot users
- radius client for hotspot auth
- OSPF with only 1 neighbour
- dude server (4.0beta3) used as agent for another dude server
thanks,
Michele Pietravalle
normis
Re: v5.11 released
Fri Dec 16, 2011 11:45 am
perfect! can the others with crashing x86 post a list like that please?
karlos1973
Re: v5.11 released
Fri Dec 16, 2011 2:30 pm
x86 reboot when use multi CPU (V5.9 y V5.10) (server hp proliant dl360 g3)
700 user simple queue
1x LAN (dhcp)
1XWAN 256 public IP (50M upload / 50M download)
QoS using Queue Tree
chrone
Re: v5.11 released
Fri Dec 16, 2011 3:46 pm
Hey Normis,
after tweaking and testing around, it seems on my windows machine, the ipv6 is enabled, while on ubuntu the ipv6 is disabled on purpose.
i can confirm that login to winbox and torch to see the throughput really hurts own machine LAN performance to the the Mikrotik.
by exiting winbox and do the test again on windows, finally i am able to achieve 400KB-600KBps, and 1.14MBps (9Mbps! woohoo!) by using downthemall plugin :D
just my two cents,
chrone
Alessio Garavano
Re: v5.11 released
Fri Dec 16, 2011 4:58 pm
Hi Normis, i have reboots in 2 IBM Servers with Intel Xeon and Core 2 Duo and 4Gb RAM each...
1) Core Router balancing manually by subnetting and routing 8 WANs in 1 Trunk Ethernet by VLANs generated by a RB1100 like Core switch, with around 120Mb of Internet.
_Simple Mangle rules and QoS in Queue Tree
_Little firewall protection doing forward limits of Netbios traffic, TCP connections, AntiSPAM, etc
2) Similar PC with similar configuration by in the other side, at 120km with the same Switch doing the VLANs and controlling around 3000 users with pppoe.
Regards!
Alessio Garavano
Lakis
Forum Veteran
Forum Veteran
Re: v5.11 released
Fri Dec 16, 2011 5:29 pm
Mt 5.11 anyone have problem with high ping 5-20mls on RB1200 on eth9 and eth10
chrone
Re: v5.11 released
Fri Dec 16, 2011 7:33 pm
forget what i said earlier, i know the culprit is the cpu was somehow set to 100mhz after upgrading from 4.17 to 5.10 and then 5.11. that's why it took down throughput when running winbox.
i just tested download a file from a private server through a nat public ip on rb450g, the download speeded up to 10MBps ~ 100Mbps. now that's a huge bump! woohoo! :D
himmi
Re: v5.11 released
Fri Dec 16, 2011 9:28 pm
I have 2 Routerboard 1100AH upgrade to v.5.11 and every day crash
MTCNA MTCTCE
astefan
Re: v5.11 released
Fri Dec 16, 2011 9:45 pm
x86 reboot when use multi CPU (V5.9 )
Intel Core 2 duo 2,6GHz
2x Intel 82576 Gigabit Network Connection
1x Intel 82572EI Gigabit Ethernet Controller
1x Marvell 88E8053 PCI-E Gigabit Ethernet Controller
1x RTL8111/8168B PCI Express Gigabit Ethernet controller
Chipset 82801I (ICH9 Family)
Hard drive SATA 80GB WD
500 user simple queue
2x LAN, one use DHCP
3x WAN, 512 public IP 2x WAN using BGP
logging traffic on port 80
sigxcpu
Re: v5.11 released
Fri Dec 16, 2011 9:54 pm
- queue trees (8 in queues, 8 out queues)
- 2 BGP sessions (same AS number "internet" and "national" traffic)
- 2 VLANs
- 1 IPIP Tunnel (that seldom has traffic)
- DNS forwarding active
- DHCP server
- 2 X Marvell Gigabit (skge driver) - was RTL8169, same behaviour
- Core2Duo E6300 downclocked to 1.4GHz, 1GB RAM
I cannot provide a supout for the crash because it just hangs.
WirelessRudy
Re: v5.11 released
Sat Dec 17, 2011 4:13 am
What does this mean? The dhcp-client request new IP etc. after ethernet link up event?
Or dhcp-server reset "Expires After" time of client?
Either way, if you have an issue with the Ethernet port (port flap! Either virtual or real...) the dhcp-client is re-requesting or the dhcp-server is resetting timer every time again?
I don't know if I am so happy with that, and I don't know if the router is happy with all that extra work....... can I switch this off?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
karlos
Re: v5.11 released
Sat Dec 17, 2011 9:36 pm
And i found new feature!
After kernel panic reboot has the RB decided to change CPUs frequency from 680MHz to 100MHz ........... very nice
It takes 6mins to reboot it to correct 680MHz frequency :?
TerAnYu
Re: v5.11 released
Sat Dec 17, 2011 10:26 pm
Hello!
Faced with the device RB450G that after you upgrade from version 4.17 to any version 5.8-5.11 is the performance drop by 2-3 times (at the 4.17 rate was about 200 megabits, but now more than 50 does not rise, due to the 100% CPU usage)
It is also sometimes result in an error of the kernel.
What can follow any responses to advise, if I had to re-create all the rules, after resetting all settings.
Здравствуйте!
Столкнулся с проблемой в устройстве RB450G что после обновления с версии 4.17 на любую из версий 5.9-5.11 происходит падение производительности в 2-3 раза (на 4.17 скорость была около 200 мегабит, теперь же выше 50 не поднимается, в связи со 100% загрузкой процессора).
Так же иногда появляются ошибки ядра.
Что можите посоветовать, если я уже заново создавал все правила, после сброса всех настроек.
ROS: 6.[latest]
chrone
Re: v5.11 released
Sat Dec 17, 2011 10:29 pm
Hello!
Faced with the device RB450G that after you upgrade from version 4.17 to any version 5.9-5.11 is the performance drop by 2-3 times (at the 4.17 rate was about 200 megabits, but now more than 50 does not rise, due to the 100% CPU usage)
i guess you are experiencing the same symptom with me. take a look at system resource, check the cpu frequency, i hope it's not 100Mhz.
you could set the frequency back to its normal value via command line if it happens to be set 100Mhz after the upgrade. or through the gui in winbox on the routeros 5.x version. don't forget to upgrade your firmware too.
mjoksimovic
Re: v5.11 released
Sat Dec 17, 2011 10:46 pm
The same thing, x86 platform - router was rebooted without proper shutdown, at least two times in 24h. It was working perfectly until ver. 5.8. After upgrade to 5.9 - 5.10 - 5.11, rebooting continue constantly... Supout.rif file sent to the support.
"Your chances of success in any undertaking can always be measured by your belief in yourself". - Robert Collier
goranst
Trainer
Trainer
Re: v5.11 released
Sun Dec 18, 2011 12:08 am
Problem with my x86 - After 4 days of the upgrade to v5.11 my HP Proliant ML110 G6 core server is stopped and frozen as well as with earlier version v5.7. Just press on the reset has helped to start server again..
uncleVALERA
Re: v5.11 released
Sun Dec 18, 2011 12:25 am
crash on x86 platform
hardware:
GIGABYTE GA-H61M-S2V-B3
Core i5 2500 @ 3.3Ghz
Transcend JetFlash 500 2GB
Intel® PRO/1000 CT Gigabit Desktop Adapter * 3ps
int. RTL8111/8168B PCI Express Gigabit Ethernet controller
4 Ethernet adapters
4 EoIP
4 IPIP
19 VLAN
350 online pptp whith RADIUS
DNS (32 statics, allow remote requests, 131072 cache)
Firewall (filter, src-nat and masq, mangle, 8 adress-list)
OSPF (4 area)
Queues Tree (2 tree global-out 0f 20 records (pcq))
happy give more information
TerAnYu
Re: v5.11 released
Sun Dec 18, 2011 10:33 am
No, like the frequency has not changed.
ROS: 6.[latest]
chrone
Re: v5.11 released
Sun Dec 18, 2011 10:40 am
oh okay, so the cpu frequency has nothing to do with your lower throughput. ever tried to disable all firewall rules and test it out temporarily?
TerAnYu
Re: v5.11 released
Sun Dec 18, 2011 10:46 am
Yes, tried on the number of rules does not.
Load is increased if a NAT is ~ 4900 packets per second.
Or activated via IPTV IGMP Proxy (flow rate of ~ 3,7-7Mbit / sec).
ROS: 6.[latest]
tornadohome
Re: v5.11 released
Sun Dec 18, 2011 10:40 pm
After Upgrade From 4.11 To 5.11
Route Reboot Every 1 Hours, Or Stop Working
Installed X86 Version On PC With Dual Core CPU
janisk
Re: v5.11 released
Mon Dec 19, 2011 11:06 am
clear the configuration and recreate it step by step. after all that is mayor version upgrade that is not done to initial version of major release.
nik247
Re: v5.11 released
Mon Dec 19, 2011 4:05 pm
Hi Normis.
1) No BGP
2) PPtP server + 8 PPPoE servers
3) online up to 580 users (pptp and pppoe)
4) Only simple queues - no QueueTree
5) No bridge
6) 59 VLANs
HW - Dell 1950 (2CPU*2CORE=4CORE) + LAN Pci-E Intel 82576 (2 ports)
Upgrade to 5.11 was in 2:00 of night and server worked about 10 hours without reboots, but when load was increase (pptp and pppoe active) server start to reboot every 20-30 minutes. One core CORE was 100%|100%.
This left on disconnected winbox.
#sys resource cpu print interval=1
CPU LOAD IRQ DISK
0 100% 100% 0%
1 3% 3% 0%
2 3% 3% 0%
3 5% 5% 0%
-- [Q quit|D dump|C-z pause]
After downgrade from 5.11 to 5.8 uptime now - 5d 22h (no any reboot)
I think it's problem with ppp and multi-core.
Thanks.
Nikolay.
MichelePietravalle
Trainer
Trainer
Re: v5.11 released
Mon Dec 19, 2011 4:54 pm
:shock: :shock: :shock:
an export and a new import can be good or i really need to recreate the conf????
sorry Janisk, but a reconfiguration of the routre after an upgrad is crazy in a real enviroment!
Neovr
Re: v5.11 released
Mon Dec 19, 2011 5:58 pm
I have same problem with reboot and stop working...
ros 5.11 x86, mpls, pptp server, dhcp server, ospf, vlans, wireless
system- Asus p5gc, dual core 2,7ghz, 512ram, cf1gb>sata
problem started at version 5.9
My other system have problem too ... ros 5.11 on vmware esxi, 1cpu pptp server... v5.8 working well
omidkosari
Trainer
Trainer
Re: v5.11 released
Mon Dec 19, 2011 6:17 pm
it seems the problem is related to vlans . right ?
Mikrotik Certified Trainer
MichelePietravalle
Trainer
Trainer
Re: v5.11 released
Mon Dec 19, 2011 6:20 pm
i have not vlan!
Last edited by MichelePietravalle on Tue Dec 20, 2011 12:45 pm, edited 1 time in total.
bradsystem
Re: v5.11 released
Tue Dec 20, 2011 3:54 am
hi,
i have problem with RB600 and latest fw (5.9, 5.11)
after RB600 update winbox shows all available routerboards (clients) with same IP as RB600 (dhcp server)
ohh not all, clients connected thru lan ports shows with correct ip,
but clients connected thru wifi shows same ip as RB600 server. (and these clients have probs with connection then)
when downgraded RB600 to 5.8 all ok..
do i have some wrong setting which are not sensible in fw 5.8 and eralier ?
thanxx brad
Karcsi
Re: v5.11 released
Tue Dec 20, 2011 9:29 am
I updated two RB 411A:
First: 4.17 to 5.11
Second: 5.4 to 5.11
All two RBs never started after update :(((
ethernet
Re: v5.11 released
Tue Dec 20, 2011 10:25 am
X86 on vmware with 5.11 hangs only on our multicore machine (3 cpu). Works for about 8 hours then just hangs. I reset it in vmware, and i am good to go for 8 hours. Downgraded to 5.8 to see if it will help.
On two others with 1 core and 2 core it works fine.
cybercoder
Re: v5.11 released
Tue Dec 20, 2011 10:38 am
I used hotspot on 750G with ros 5.11 in a workshop for a ISP engineers, I assigned Router IP(v4) address in walled garden and walled garden IP as (allow), but when openning the userman page the '411 page not found error' was appeared, by disabling Hotspot the userman page opened successfully. downgrade to 5.10 fixed this issue. :?
Any sufficiently advanced technology is indistinguishable from magic. ( Arthur C Clarke )
Mikrotik certified consultant
Microsoft Certified Technology Specialist, Microsoft Certified IT Proffessional
http://www.netd.ir
crazytemper
Re: v5.11 released
Tue Dec 20, 2011 3:11 pm
My RB750 upgraded successfully,It works well till now.
But I found a warnning message in the system logs.
"System rebooted because of kernel failure"
Every time I start or reboot the router,It's always in the first line of the logs.
Is this a prompt bug or a serious proplem?
cybercoder
Re: v5.11 released
Tue Dec 20, 2011 11:45 pm
Are you sure the routerOS will up in first try?
isn't there any auto reboot when you turn the router on?
http://www.netd.ir
yogii
Re: v5.11 released
Wed Dec 21, 2011 1:32 pm
My RB750. ROS version 5.11. firmware 2.37.
NO issue. all works very well.
ditonet
Forum Veteran
Forum Veteran
Re: v5.11 released
Wed Dec 21, 2011 3:49 pm
Check your 'System/Logging' settings.
For critical error like 'System rebooted because of kernel failure' two actions are defined: 'memory' and 'echo'.
By default 'echo' action has 'Save' option turned on, so even old critical errors are displayed after every reboot.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE, MTCSWE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
routerboarda
Re: v5.11 released
Thu Dec 22, 2011 12:23 pm
i have a 2 ogmaconnect router now running on 5.8, both have x86 multicore (quad and dual).
is th 5.11 now multicore compatible?
I just have the live-system and can not risk longer outages..
thanks for info.
br Daniel
Chupaka
Re: v5.11 released
Thu Dec 22, 2011 2:50 pm
the main question: what's not working in 5.8 for you?..
routerboarda
Re: v5.11 released
Thu Dec 22, 2011 3:18 pm
good question!
I am quite happy with the 5.8 but nevertheless there are a few bugfixes especially for eoip an ppp, which are important topics to me.
br
asus
Re: v5.11 released
Fri Dec 23, 2011 6:17 am
5.9, 5.10 rebooting frequently...or sometimes its get's hang
shifted back to 5.8 :/
8core processor with 4gb ram x86
pppoe
firewall
DNS
queues
radius
UM
graphing
5 packages installed
advanced-tools
ppp
security
system
user-manager
sorellano
Re: v5.11 released
Fri Dec 23, 2011 8:56 pm
I have two PC Intel 4 core with V5.11 and same configuration:
firewall
DNS
queues
OSPF
BGP
API
and 60Mb Wan
Periodically reboot
If I disable queues, all OK
If install V5.8 with queues enable, all OK
Zebble
Re: v5.11 released
Sat Dec 24, 2011 4:34 am
Had 5.11 lock up on an esxi VM after about 2 days. A reset brought it back up, and its been up for just over 6 days. ONLY change made was for all logs to go to disk instead of memory or console, so I could catch what was in the logs before the next lock up.
Config:
2 vCPU's (xeon e5420)
1GB vRAM
80GB vDisk thin provisioned
2 legacy network interfaces (e1000) for WAN and LAN
Fairly basic firewall rules (approx 50)
Blacklist chain added that inspects against an address-list with approximately 400 ip's/address spaces - dynamically updated nightly
Packet mangling (approx 30)
Queue tree with approx 10 branches
3 continuous SSTP connections to 3 remote RB750gl's (have issue with SSTP stop passing traffic, which I'll post in another topic - a net watch script works around this)
No dhcp client or server
Combination of dstnat/srcnat and simple routing of 1 private space and 2 public spaces on LAN
SNMP enabled and monitored using a Mikrotik template through a Cacti server every 5 minutes
Other than the SSTP issue, everything has been stable.
engineertote
Re: v5.11 released
Sun Dec 25, 2011 11:13 pm
i have upgrade my X86 from 5.7 to 5.11 but the problem that its keep hang up and stop running untill i reboot it , i have downgrade it to 5.7 and its back stable ,, please be noted to fix it in 5.12
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
rottie
Re: v5.11 released
Mon Dec 26, 2011 12:01 pm
Also downgraded back to 5.9 on a RB-800 as the PPPoE server and client options in the interface disappeared. (firmware 2.24 - did not try with 2.30)
On the other RB-400s and RB-600s 5.11 is fine.
msugata2011
Re: v5.11 released
Wed Dec 28, 2011 9:43 am
After upgrade the v4.16 to 5.11 one of our router get hanged two times within 3days.
Which is used for only queueing in bridge mode with 150Mb bandwidth & having near 100 no queue.
Router is 2282 Model.
msugata2011
Re: v5.11 released
Wed Dec 28, 2011 9:47 am
Could you give me stable version 5.X(npk file) so I coul downgrade...
Chupaka
Re: v5.11 released
Wed Dec 28, 2011 10:55 am
magnet:?xt=urn:btih:BED4005315D9DFB36D4D7CDC267F5CE90DACCDCD&dn=routeros-5.8&tr=http%3a//tracker.mikrotik.com/
magnet:?xt=urn:btih:79B0BE7AABBDA58CF23A2455C558391C4CDE8E5D&dn=routeros-5.9&tr=http%3a//tracker.mikrotik.com/
bsdu
Re: v5.11 released
Wed Dec 28, 2011 11:32 am
L2tp VPN inbound on multiple ISPs issue exist still in v5.11 ?
Any ideas?
Thanks!
asus
Re: v5.11 released
Wed Dec 28, 2011 6:46 pm
mihaimikrotik
Re: v5.11 released
Fri Dec 30, 2011 2:50 am
Same reboot problem on two different systems for 5.11:
Quad AMD vs Intel I7 2600
Both have same set of features:
Most important: VRRP, BGP, QoS, VLANS, Queue Management, Firewall, Bridging, Bonding, Multi-CPU on.
I7 is primary, AMD is backup so it is not used as much. I7 was rebooting every 2 minutes, AMD rebooted twice in 24h.
Also, on AMD when upgraded from 5.8 to 5.11 one of the VLANS switched the attached interface to another disabled interface which had nothing to do with the original interface the VLAN was attached to.
Also, as a side note, will there be any support for more than 2GB of RAM in the system and more than 200 networks available in /routing bgp network ? These two features I belive are very important, as we're currently running 12 BGP full table peers and are planning on a lot more for multi-cpu systems.
Thanks,
I haven't lost my mind, I have a tape back-up somewhere.
MTCNA, MTCRE, MTCTCE, MTCWE, MTCUME, MTCINE, MikroTik Trainer
rwilkins
Re: v5.11 released
Fri Dec 30, 2011 7:16 am
I've run into an issue tonight where I couldn't log in to my x86 v5.11 router with my configured username and password. I had deleted the "admin" user at initial setup but the router sometime in the last 24 hours decided to remove my username from the users list and reactivate the default admin user. This had the unfortunate side effect of letting someone unknown to me log in to my router early this morning via SSH which was configured to allow logins from anywhere, unlike every other service which is locked down. Fortunately, this person didn't appear to have changed anything. After setting things back (with a new password just in case my password was compromised) the system returned back to only having the default admin user in it within minutes of me changing the config several times. Also, looking at the license of the router shows no license. /sys lic print literally just prints a couple returns and back to a prompt. The loaded license was a level 5.
Motherboard: SuperMicro X9SCL
CPU: Intel Xeon E1220 quad-core no hyperthreading
Memory: 8 GB
onboard NIC 1: Intel 82579LM (not supported yet by ROS)
onboard NIC 2: Intel 82574L
PCI-E NIC 1: Intel 82574L
Boot disk: USB flash drive - 8GB
Just FYI.
Ryan Wilkins
timberwolf
Re: v5.11 released
Fri Dec 30, 2011 5:19 pm
@rwilkins
This really sounds like someone hacked into the system and installed a backdoor.
After all ROS on x86(and all other plattforms) is Linux based and so exploits might work like on any other Linux based system.
pokeman
Re: v5.11 released
Fri Dec 30, 2011 9:54 pm
Un-stable version 5-11.
We are facing issue with Mikrotik with PPTP tunnels. We have core-2-duo machine but they could not handle more than 800 pptp tunnels, even we replaced xeon machine 8 core processor. finally We requested MT support to help us. As per their recomendedation we upgrade 5-11 to core-2-duo machine. After upgrading machine cpu was very high...
SULTAN
Re: v5.11 released
Sat Dec 31, 2011 12:40 pm
What About Userman ...
Its Still Have Problems .. :(
pokeman
Re: v5.11 released
Sat Dec 31, 2011 7:42 pm
5-11 reboot after 12 hours, See the performance difference between 4.17 with 5.11
bambangs2komputer
Re: v5.11 released
Mon Jan 02, 2012 2:06 pm
I'm sorry mikrotik support, I wrote "internal server error" for my android. but with browser opera version 11.50 build ADR-1111101157 work fine anytime :-). by the way in usermanager "userman - show overall totals, show user totals if user has more than one entry" like changelog 5.7 did'nt work;
that's just info, thx
deltainternet
Re: v5.11 released
Mon Jan 02, 2012 5:41 pm
ok
ok
drb
Re: v5.11 released
Tue Jan 03, 2012 7:58 am
I am seeing a similar problem and error messages ("system rebooted because of kernel failure"). I have a new RB450G which came with 5.2 installed. I upgraded to 5.11 and entered my configuration which is relatively simple. It has rebooted twice in the four days that I have had it. I also have a new RB493G with 5.11, albeit with a different configuration which has been fine so far. It appeared to generate a supout file so I'll send that to Mikrotik support.
Other observations:
1) Using winbox, my CPU frequency was showing as 100MHz although it didn't seem like the router was running slowly (I reset to 680MHz).
2) Using winbox, it listed nothing for current firmware, and 2.38 for upgrade firmware (I had already upgraded to 2.38). If I printed the firmware versions using CLI, the current firmware version correctly displayed.
It seems like others have been seeing similar symptoms on various RB versions. Any feedback yet from Mikrotik?
Chupaka
Re: v5.11 released
Tue Jan 03, 2012 9:52 am
it looks like RouterOS looses HDD (in my case, it's USB Flash, 8G too :) ) - either now, or a bit later you will find out that Files window is empty, and Terminal window hangs after opening. the only thing that will fix it is reboot; and the only problem - it should be hardware reboot, because on rebooting remotely (via WinBox) router will just hang :(
aries
Re: v5.11 released
Tue Jan 03, 2012 6:15 pm
Is it so diffilcult for Microtik to write down release notes. For example that it is necesarry to update x86 pc's firmware before using new 5.x versions.
As support informed hdd of usb loses is due to old x86 pc's firmware.
timberwolf
Re: v5.11 released
Tue Jan 03, 2012 6:39 pm
But why should accounts(/etc/passwd?) revert to old values? I would expect that all accounts would be rendered unusable in that case.
normis
Re: v5.11 released
Wed Jan 04, 2012 8:31 am
why would it be in the release notes? this is a specific suggestion, just for your situation.
aries
Re: v5.11 released
Wed Jan 04, 2012 9:03 am
Please check "Re: v5.11 released" there are a lot of complains about misteriuos x86 craches and hangs. I had the same problem with three x86 routers - old firmware.
It would be a great help for admins to see release notes, because you can spot problems much faster then us.
Your operating router system is great, but using it becomes tricky because of unknown problems. And nobody comunicates it.
timberwolf
Re: v5.11 released
Wed Jan 04, 2012 1:50 pm
You can't blame MikroTik for buggy x86 BIOS and Firmware implementations!
And yes there are a lot of them.
normis
Re: v5.11 released
Wed Jan 04, 2012 2:05 pm
aries, you are basically asking us to add information about problems in x86 system BIOS releases? Shouldn't you be looking at the BIOS release notes instead?
aries
Re: v5.11 released
Wed Jan 04, 2012 5:42 pm
The problem is not in bios, problem is that you don't know what to expect installing new ros version. And it is called "stable".
Problems that affected me last lew months was problems with eoip, ssh, snmp, and x86 router hangings because of bios. The strange thing is that it was working well in previos versions like 4.17. Hangings started from 5.7 version or so.
And maybe there are over issuses that I don't know. Another problem is that after some bug fix you install new version, and it has new bugs, that don't have to do anything that is stated in change log like last eoip problem.
Best regards.
siprox
Re: v5.11 released
Thu Jan 05, 2012 9:07 am
hi normis, when this problem crashes on x86 will be fixed?, im still waiting. maybe next 5.12?
mihaimikrotik
Re: v5.11 released
Fri Jan 06, 2012 7:12 am
I belive that the reboot problem lies in the support for multi-core/multi-cpu. We have downgraded from 5.11 to 5.8 and we always got "system,info,critical CRIT_: Disabled multi-cpu setting, new value will take effect after the reboot." messages in the console after the downgrade. Even days after the downgrade. Indeed, as someone else suggested in a previous reply, the system could not be rebooted remotely as it hanged.
What we did was we disabled multi-cpu, re-enabled it immediately after, we got "system,info,critical CRIT_: Enabled multi-cpu setting, new value will take effect after the reboot." in the logs, and then rebooted. That mysteriously fixed the problem and the after hangs.
pckt
Re: v5.11 released
Fri Jan 06, 2012 8:15 pm
I'm also having x86 latching up problems but on 5.7 (the device still works, but no interface is accessible until reboot). Actually I've got two systems, one running 5.7 and the other running 5.8 that will not update to 5.11 - perhaps I am doing something wrong or missed reading something somewhere.
winet
Re: v5.11 released
Mon Jan 09, 2012 5:15 am
my RouterOS x86 had 2 kernel panic crash this morning after upgraded to v5.11
so i decided to downgrade to v5.8 :(
omidkosari
Trainer
Trainer
Re: v5.11 released
Mon Jan 09, 2012 8:10 am
I want to upgrade from 5.7 to new version but it has serious crash/reset problems .
When a new stable version for x86 will be released ?
borow
Re: v5.11 released
Mon Jan 09, 2012 10:52 am
After upgrading our 2 RB800 routerboards to v5.11,they started to reboot occasionally with error message System rebooted because of kernel failure,or they just hanged,so we needed to reboot them manually from power switch.
After downgrading the ROS to v5.9,the problem is solved 1d 14h. uptime with no errors.
*We never had other problems with these 2 RBs,untill now,the issue is probablly connected with the ROS.
winet
Re: v5.11 released
Mon Jan 09, 2012 1:10 pm
so i'm not alone on this :lol:
anyway, before i upgraded to v5.11 on the main router, i had it tested on an unused RB750. suprisingly it doesn't crash at all, i keep it running for 24 hours. it has no any firewall rules added, it is on a clean default setting.
Zebble
Re: v5.11 released
Mon Jan 09, 2012 4:27 pm
Quick update that we've had our x86 5.11 VM running flawlessly except for an SSTP problem for almost 2 weeks now.
The ONLY change made was to have ALL logs go to disk instead if memory. Could memory-based logging or overall memory allocation be the source of the problem?
borow
Re: v5.11 released
Mon Jan 09, 2012 4:53 pm
that's right. i forgot to mention,we are also running v5.11 on RB433AH with two R52Hn cards - no problems at all.
This problem is probablly common on powerpc models.
ManyX
Re: v5.11 released
Mon Jan 09, 2012 10:31 pm
I have problem with 5.11 on x86 router with one CPU. router hung up 4 time. (CPU worked on 100% - VM statistic)
solution to the problems was:
disable "multi CPU"
I would like to mention the second router with 5.11 and two CPU works perfectly with enable "multi CPU"
reg.
amisharma132
Re: v5.11 released
Tue Jan 10, 2012 4:21 pm
Hi , can you explain more your question? type, rb, cards, protocols, voltage, etc...
Thx and regards!
http://updatesdaddy.com
mangust
Re: v5.11 released
Wed Jan 11, 2012 1:05 pm
I'm experiencing some issue with ssh/ssl traffic via SNAT/MASQ on my x86 5.11.
Cannot connect via ssh and all ssl pages opened with huge delay ...
Traffic which has no nat goes as it is expected.
Have anyone the same issue?
I'm disabling IpV6 package. Is that safety or that's not recommended?
Cheers.
emersonmill
Re: v5.11 released
Wed Jan 11, 2012 3:27 pm
mangust,
Mikrotik is having serious problems in the routing table.
If you use only to control the MikroTik PPPoE connections have no problems.
If you use the MikroTik with DNAT / SNAT - Firewall - ARP will have various problems of freezing or rebooting the system.
RB1000 use to control the PPPoE clients without problems.
I use Intel x86 PC to control the PPPoE clients without problems.
I use to control RB1200 routed customers have a lot of freezing and rebooting problems.
The team is aware of these problems with MikroTik routing but failed to solve.
Maybe the new kernel with version 6 ?
normis
Re: v5.11 released
Wed Jan 11, 2012 3:47 pm
this may be unrelated to routing at all. RB1200 used to have some problems that were fixed in RouterBOOT and RouterOS upgrades. So, please upgrade RouterOS to v5.11 and then issue command :"/system routerboard upgrade" and reboot. After this, your problems will be gone.
mangust
Re: v5.11 released
Wed Jan 11, 2012 4:10 pm
Well, Is it safety to use 5.8 instead of 5.11 or it should not be any problem in NAT/Routing (BGP) in 5.11?
normis
Re: v5.11 released
Wed Jan 11, 2012 4:11 pm
there are no known routing issues like that in v5.11
RB1200 issues are only fixed in v5.11 (+ latest bootloader) so you must upgrade anyway.
Zebble
Re: v5.11 released
Wed Jan 11, 2012 5:27 pm
I can personally confirm that the latest RB1200 firmware included with 5.11 (2.37) resolved the rebooting issue.
emersonmill
Re: v5.11 released
Wed Jan 11, 2012 7:19 pm
Thank you,
I'd rather wait for a solution for all platforms
x86 routed still presents problems of freezing and rebooting
My equipment - RB1000 - RB1200 - RB600 - RB333 - RB433AH and several MikroTik x86 we are using version 5.7
When everything is right on all platforms exchanged for the most current version
Thanks again.
normis
Re: v5.11 released
Thu Jan 12, 2012 9:24 am
there is zero benefit in waiting for all platforms to be the same version. upgrade the ones where problems are fixed, or better yet - simply upgrade them all.
karentom
Re: v5.11 released
Fri Jan 13, 2012 1:16 am
can you please update http://wiki.mikrotik.com/wiki/RouterBOOT_changelog
for example RB433 now has RouterBoot v2.39 and on the web page there is still 2.37 as the last one described.
Thank you in advance!!
normis
Re: v5.11 released
Fri Jan 13, 2012 9:02 am
there are no public changes. added support for unannounced products.
elgo
Re: v5.11 released
Fri Jan 13, 2012 12:18 pm
"No public changes" means "changes"... useless changes for actual users but still potentially dangerous changes by definition.
So why release it in the first place?
I can't understand MT release policy at all.
RB450G - OpenWrt (so much more stable than with routerOS)
-> now: UBNT EdgeRouter Lite
(very unlikely to be MT customer again in the future)
normis
Re: v5.11 released
Fri Jan 13, 2012 12:21 pm
whats unclear about this sentence? you wanted us to publish the names of future products in a changelog?
mangust
Re: v5.11 released
Fri Jan 13, 2012 12:28 pm
x86, ROS5.11.
Am I only the one who cant use packet sniffer?
I mean packet sniffer shows nothing for me than i am tring to start it :(
Chupaka
Re: v5.11 released
Fri Jan 13, 2012 2:06 pm
I think, he wanted to say "Why do you release firmware for unreleased hardware?" :)
PastuhMedvedey
Re: v5.11 released
Fri Jan 13, 2012 3:02 pm
When using RB751U-2HnD with software 5.11 are frequent hangs and reboot the device for downloading torrents at speeds above 40 Mbps.
I use two uplink pppoe (5 Mbps) and pptp (100 Mbps), masquerading, load balancing using PCC.
At version 5.8, this configuration is stable.
RB751U-2HnD, RB2011LS, RB1100AH, RB433, RB411GL, RBSXT, CCR1016
normis
Re: v5.11 released
Fri Jan 13, 2012 3:53 pm
If anyone is experiencing crashes with X86 systems, please email us a photo of the crash (on the monitor) and the supout.rif file. This applies especially to those of you who said that downgrade helps!
karentom
Re: v5.11 released
Sat Jan 14, 2012 2:53 am
Thank you normis on your fast reply!!
May I ask, why then, for example, for RB4XX last version is 2.39 and for RB7XX last one is 2.38 and both are mipsbe?
winet
Re: v5.11 released
Sun Jan 15, 2012 7:35 pm
i wish i had taken a photo of it, but i didn't. i can't help you at this moment too, as my clients are gonna kill me if i have another crash again. i had too much crashes + electrical problem + wireless signal interference + cable replacements on BTS + firmware upgrading / downgrading, and all these happened on this january :( . they had too much problem from me :?
Zebble
Re: v5.11 released
Sun Jan 15, 2012 9:24 pm
When we last had our x86 box crash, it was responding to pings but not forwarding any traffic. Console was completely black. Pressing any keys didn't change that, so can't help with a screenshot.
Been up just fine for over 2 weeks now.
wbhampton
Re: v5.11 released
Sun Jan 15, 2012 11:17 pm
Have problems with X86 crashing on VMware 4.1 I have several of these running on exactly the same hareware platform the ones running 5.8 or earlier have no problems 5.11 is crashing at random I did not have any problem for 2 weeks then I added some mangle rules and pcq queing and a few days later it starts crashing at random intervals.
Walter B. Hampton
McCookNet Internet Service
308-350-1419
dimabar
Re: v5.11 released
Mon Jan 16, 2012 11:16 am
Experiencing random reboots on x86 with 5.11. We have several PPPoE B-RAS`es based on MT... Planning to downgrade to 5.10 maybe earlier.
Does the Mikrotik support team localize the problem in 5.11 yet?
elgo
Re: v5.11 released
Mon Jan 16, 2012 11:44 am
Exactly.
normis
Re: v5.11 released
Mon Jan 16, 2012 11:48 am
same CPU family, same firmware. maybe you haven't noticed, but firmware is not divided by model, but by CPU
dimabar
Re: v5.11 released
Mon Jan 16, 2012 2:38 pm
Sorry for bothering... But does support have any update on problem with 5.11 running x86 system?
normis
Re: v5.11 released
Mon Jan 16, 2012 2:40 pm
we have no reports in support. only complaints in forum. please make photo of crash, and send to support with supout.rif file. also tell us last version where it worked fine.
siprox
Re: v5.11 released
Mon Jan 16, 2012 3:35 pm
come on, to be honest, the mikrotik staff cannot reproduce the problem of crash v.5.11 on x86? i had reported and then send suppout file, from v.5.9, v.5.10, and then last 5.11. still have the same problem, back to the v.5.8 and run flawlessly.
please check my ticket. Ticket#2011120766000133. Dec 7, 2011 17:42
normis
Re: v5.11 released
Mon Jan 16, 2012 3:38 pm
siprox in your ticket you don't give us any information. we need at least photo of the crash output on the monitor
dimabar
Re: v5.11 released
Mon Jan 16, 2012 4:05 pm
We have only remote devices, no monitors or anything... But we have console connections to our mikrotik B-RASes. On consoles we have nothing. Like common reboot... How to get any debug output, kernel oops...or anything? Maybe some kind of netconsole?
siprox
Re: v5.11 released
Tue Jan 17, 2012 3:05 am
i didn't photo on that condition, just see black screen, keyboard not working.
winet
Re: v5.11 released
Tue Jan 17, 2012 3:36 am
i can tell you that mine is not just black screen. there's a lot of error message on the screen, and somewhat i clearly remember that the last words are "kernel panic".
nzlme
Re: v5.11 released
Tue Jan 17, 2012 2:52 pm
After upgrading RB1100AH from 5.8 to 5.11 I have large latency spikes 5-20 ms across bridged VLAN's on port 11/12, previously latency was 0-1 ms.
I am using the RouterBoard as a transparent firewall at my network edge, bridging 4 VLAN's through 4 bridges on port 11/12.
Attached is an screenshot of the latency spikes before and after the upgrade from our network monitoring.
dimabar
Re: v5.11 released
Tue Jan 17, 2012 3:29 pm
Dear friends!
Kernel panics or black screens... No matter. All that things are very bad. Double trouble is that developers do nothing for now and we have no any debug output or anything. I think that photos of the monitor output is not a professional way.
We need some patch or something like patch to troubleshoot the problem.
cbonet
Re: v5.11 released
Tue Jan 17, 2012 3:56 pm
Hello Guys... Im new here...I started to work in a School and they have Mikrotik 4.11....
So i want to upgrade.. but when I do it??? It will reset all the configuration??
Thank you :D Any help will be aprreciated
winxp2000
Re: v5.11 released
Tue Jan 17, 2012 4:43 pm
This release may be still got some bug.
After I upgrade from 5.7, my company found the network delay change to so big.
The traffic show very big.
dimabar
Re: v5.11 released
Wed Jan 18, 2012 10:34 am
On wire or radio? And do you facing reboots?
dimabar
Re: v5.11 released
Wed Jan 18, 2012 10:35 am
Wow! Weird... Do you have strange reboots or hangs?
neticted
Re: v5.11 released
Wed Jan 18, 2012 11:54 am
If it works, do not upgrade. If zou reallz want to upgrade go to 4.17. If zoy really need something in 5.xx upgrade to 5.4, but only if you really must.
Upgrade will usually keep configuration intact but in newere versions there is increased probability that config will be messed up, so beackup both binary and command mode before upgrade.
dimabar
Re: v5.11 released
Wed Jan 18, 2012 2:20 pm
Thanks for the info. But we have big troubles with bras`es on x86 with 5.11 software. Spontaneous reboots. Nothing helps... I wonder, does this problem exists on 5.10 or 5.9?
ros001
Re: v5.11 released
Thu Jan 19, 2012 2:46 am
来自中国ros001 我现在用3.30 挺稳定的,满足了日常运用 不过考虑升级 不知道 升了之后还稳定吗 ?
siprox
Re: v5.11 released
Thu Jan 19, 2012 5:52 am
i had experiencing randomly reboots on version 5.9, 5.10, 5.11 to. all that same. back to 5.8 and then normal again.
wbhampton
Re: v5.11 released
Thu Jan 19, 2012 7:18 am
I have sent 2 e-mail's with the supout.rif and no reply there is nothing to screen shot the console is black
Walter B. Hampton
308-350-1419
omidkosari
Trainer
Trainer
Re: v5.11 released
Thu Jan 19, 2012 9:25 am
Are you using PPP or PCQ on those problematic routers ?
normis
Re: v5.11 released
Thu Jan 19, 2012 11:01 am
we have made a pre-release version with a potential fix for x86 reboots. email support to gėt it.
MichelePietravalle
Trainer
Trainer
Re: v5.11 released
Thu Jan 19, 2012 4:08 pm
after 5 hours form the update seems to be ok! but i will wait 24h before enjoy me :)
nzlme
Re: v5.11 released
Thu Jan 19, 2012 4:22 pm
So whats up with the latency issue, and why havent you pulled the release, as clearly it is not stable?
normis
Re: v5.11 released
Fri Jan 20, 2012 7:59 am
what latency issue? the x86 issue that I mentioned, affects only specific configurations. we only have received 3-4 complaints to support, and maybe 5-6 in the forums (clearly 2-3 people have no interest in reporting the issue to support)
nzlme
Re: v5.11 released
Fri Jan 20, 2012 8:10 am
This one http://forum.mikrotik.com/viewtopic.php ... 22#p299214
(Also there are about two other posts in this thread talking about high latency after upgrading).
What info do you want me to send to support?
normis
Re: v5.11 released
Fri Jan 20, 2012 8:11 am
problem description, supout.rif file, screenshot of issue
bawolek
Re: v5.11 released
Fri Jan 20, 2012 2:20 pm
I have a few RB1200 with 5.7 after I update to 5.11 I have strange lost packet, ping for this machine is not stable and sometimes RB is freeze,
on this machines I use pppoe (client) and very simple quee tree with quee type = pfifo
maesca
Re: v5.11 released
Sun Jan 22, 2012 10:36 pm
hola, heactualizado una SXT 5HnD a la version 5.12 y despues de reiniciar no puedo acceder por winbox de ninguna manera no me aparece la mac
EMOziko
Re: v5.11 released
Mon Jan 23, 2012 9:28 am
anyone tested v5.12? on x86?
We want new versions of The Dude!!!!!!!
babbage
Trainer
Trainer
Re: v5.11 released
Sat Mar 31, 2012 7:57 pm
Guys,
Anybody found his x86 v5.xx crashes fixed?
Users browsing this forum: afahmytik, Bing [Bot], CyberDaeng and 127 guests
