THG
Convert one byte data to hex
Sat Dec 31, 2011 3:21 am
I need some ideas to convert a static route from RouterOS to hex.
Example: A route to the network 192.168.2.0/24 using gateway 192.168.1.1
The string to convert: [Network Bitmask][Network Address][IP Address]
Final hex string: 0x18c0a802c0a80101
dasiu
Trainer
Trainer
Re: Convert one byte data to hex
Sat Dec 31, 2011 12:59 pm
My first suggestion - it should be 0x18c0a80200c0a80101. What if the mask if more specific than /24? ;)
dasiu
Trainer
Trainer
Sat Dec 31, 2011 3:18 pm
1. I'm just learning to write scripts - and I think that was quite easy :).
2. That's my first script to be put on MikroTik wiki
3. THG - if you are planning to go to the MUM - you owe me a beer :) (wait... they give beer for free... ok, let it be a big chocolate :P)
# Script converting network and gateway from routing table to hexadecimal string
# dst-address=192.168.2.0/24 gateway=192.168.1.1 => result=0x18c0a80200c0a80101
# (c) Daniel Starnowski 2011
:foreach route in=[/ip route find] do={
 :local dst [/ip route get $route dst-address];
 :local gateway [/ip route get $route gateway];
 :if ($gateway=[:toip $gateway]) do={
  :local total ($dst . "." . $gateway);
  :local result "0x";
  :local hextable [:toarray "0,1,2,3,4,5,6,7,8,9,a,b,c,d,e,f"];
  :local total2 "";
  :local decimal;
  :local division;
  :local i;
  :local j;
  :for i from=1 to=[:len $total] step=1 do={
   :set j [:pick $total ($i-1) $i];
   :if (($j=".") or ($j="/")) do={:set j ","};
   :set total2 ($total2 . $j);
  :set total2 [:toarray $total2];
  :for i from=0 to=8 step=1 do={
   :set j $i;
   :if ($j<5) do={if ($j=0) do={:set j 4;} else={:set j ($j-1);};};
   :set decimal [:pick $total2 $j ($j+1)]
   :set division ($decimal / 16);
   :set result ($result . [:pick $hextable $division]);
   :set result ($result . [:pick $hextable ($decimal - (16 * $division))]);
  :put $result;
 } else={:put ("Gateway is not a single IP address for ".$dst);}
THG
Sat Dec 31, 2011 3:23 pm
This will generate an error on the dhcp client (the data is invalid).
If I set the network bits to "/25", then the CIDR bit usage changes.
The string would be:
24 bits = 18c0a802c0a80101
25 bits = 19c0a80200c0a80101
dasiu
Trainer
Trainer
Sat Dec 31, 2011 3:31 pm
Then how should it look like for:
192.168.0.0/16
10.0.0.0/8
10.0.0.0/16
10.0.0.0/20
10.0.0.0/24
10.0.0.0/28
THG
Sat Dec 31, 2011 3:34 pm
Thank you!
I'm trying to learn to write scripts in RouterOS, I must say that it's quite easier to write scripts in a Unix machine.
You like chocolate, I'll remeber that if I attend to the next MUM in Warsaw.
THG
Sat Dec 31, 2011 3:41 pm
192.168.0.0/16
10.0.0.0/8
10.0.0.0/16
10.0.0.0/20
10.0.0.0/24
10.0.0.0/28
If the gateway address is the same (192.168.1.1).
192.168.0.0/16 = 0x10c0a8c0a80101
10.0.0.0/8 = 0x080ac0a80101
10.0.0.0/16 = 0x100a00c0a80101
10.0.0.0/20 = 0x140a0000c0a80101
10.0.0.0/24 = 0x180a0000c0a80101
10.0.0.0/28 = 0x1c0a000000c0a80101
If you have a computer with perl or ruby, try these scripts.
http://forum.mikrotik.com/viewtopic.php ... 30#p245030
In your script above, did you forget to add a closing bracket to the end of it?
dasiu
Trainer
Trainer
Sat Dec 31, 2011 4:04 pm
Ok, this modification was quick :).
And the perl script you gave me as example - gives invalid result for /0 mask. In that RFC (see the examples in the RFC) - should be no octets, but the perl script gives one ;).
# Second script converting network and gateway from routing table to hexadecimal string
# according to RFC 3442
# result=0x<prefix><network><gateway>
# example: dst-address=192.168.2.0/24 gateway=192.168.1.1 => result=0x18c0a802c0a80101
#        Width of subnet mask     Number of significant octets
#                     0                     0
#                  1- 8                     1
#                  9-16                     2
#                 17-24                     3
#                 25-32                     4
  :local result "0x";
  :local total2 "";
  :local decimal;
  :local division;
  :local i;
  :local j;
  :set decimal [:pick $total2 4]
  :local omit ((32-[:pick $total2 4]) / 8);
  :for i from=($omit+1) to=8 step=1 do={
   :set j $i;
   :if ($j<5) do={:set j ($j-1-$omit);};
   :set decimal [:pick $total2 $j]
  :put ($result . " for " . $dst);
THG
Sat Dec 31, 2011 4:10 pm
Can you give me an example, thanks.
dasiu
Trainer
Trainer
Sat Dec 31, 2011 4:13 pm
dasiu@admin:~/Dokumenty/Mikrotik/Skrypty$ ./dhcp.perl 16.32.64.128 0.0.0.0/0
DHCP option 121 (249) hex string: 000010204080
- should be 0010204080, and is 000010204080. RFC says, that for subnet mask /0 - there should be 0 octets of the network, and the perl script still gives 1 octet in the result :).
From the RFC 3442 - see the first example:
                     0                     0
                  1- 8                     1
                  9-16                     2
                 17-24                     3
                 25-32                     4
   The following table contains some examples of how various subnet
   number/mask combinations can be encoded:
   Subnet number   Subnet mask      Destination descriptor
   0               0                0
   10.0.0.0        255.0.0.0        8.10
   10.0.0.0        255.255.255.0    24.10.0.0
   10.17.0.0       255.255.0.0      16.10.17
   10.27.129.0     255.255.255.0    24.10.27.129
   10.229.0.128    255.255.255.128  25.10.229.0.128
   10.198.122.47   255.255.255.255  32.10.198.122.47
So then - line 16 of the perl script given by you:
$string .= sprintf('%02x', $b0);
should be:
$string .= sprintf('%02x', $b0) if($mask > 0);
THG
Sat Dec 31, 2011 5:23 pm
You are right, I must have forgotten to add "if($mask > 0)" to the perl script (it's corrected now).
Another karma granted for this one. :)
Users browsing this forum: viragoskis and 11 guests
