MUM Europe 2020
sgb32
> 254 IPs
Thu Jan 05, 2012 3:05 pm
I’m going to need more than 254 IP addresses so I guess I'll need to configure an RB750 to lease class B IP addresses.
I assume that I configure a Pool of 192.168.0.1 – 192.168.1.254 on the 192.168.0.0/23 network for example and have DHCP use it.
I’ve never needed this number of IPs before and wondered which is the best way to go about it?
Many thanks.
dasiu
Trainer
Trainer
Re: > 254 IPs
Fri Jan 06, 2012 4:21 am
192.168.0.0/23 will work normally, id doesn't differ from 192.168.0.0/24 - you will have 512 normal addresses :).
karlos
Re: > 254 IPs
Wed Jan 11, 2012 5:06 pm
/30 = 4IP
/29 = 8IP
/28 = 16IP
/27 = 32IP
/26 = 64IP
/25 = 128IP
/24 = 256IP
/23 = 512IP
/22 = 1024IP
/21 = 2048IP
/20 = 4096IP
but you cant use the borders so 0 and 255 are not ussable.
so always minus 2
so 192.168.0.1/23 will give you space for clients from 192.168.0.2 to 192.168.1.254 (192.168.0.0 border, 192.168.0.1 Gateway, 192.168.1.255 border)
Or you can also use 2 or more pools so you can use for your DHCP pool1 = 192.168.0.0/24 and second pool2 = 192.168.1.0/24 as the "next pool" and the DPHS will give at the first all adresses from pool1 and than from pool2.
If it helps you please give me carma
CCDKP
Re: > 254 IPs
Wed Jan 11, 2012 7:07 pm
Depending on how / what you are setting up, I would typically set:
add address=192.168.0.1/23 disabled=no interface=<INTERFACE> network=192.168.0.0
add name=DHCP2 ranges=192.168.1.6-192.168.1.249
add name=DHCP1 next-pool=DHCP2 ranges=192.168.0.6-192.168.0.249
add address-pool=DHCP1 authoritative=yes bootp-support=static disabled=no interface=<INTERFACE> lease-time=1d name=DHCP
add address=192.168.0.0/23 dns-server=192.168.0.1 gateway=192.168.0.1 netmask=23
While you could use a single large DHCP pool, I typically use multiple for two reasons:
1) I have run into some issues from time to time with poorly written clients choking on the .255 and .0 addresses in the middle, so I just avoid handing them out, even if they are technically valid.
2) I like to leave a 5 IP buffer on both sides of a pool, so I have static IP's reserved if I ever need them, and if for some reason I need to split them back into /24's, i don't have to rebuild as much, and keep things consistent. (i always know 1-5 and 250-254 are reserved)
Is it overkill? Probably. Has it worked great for me? Absolutely. Another thought, if this is for a network where you have a lot of turnover (public hotspots, schools, etc), try turning down the lease time to 6-8h and you will find you can stretch an address pool a lot further.
CC_DKP: MTCNA, MTCRE, MTCWE, MTCTCE, part-time packet wrangler
Users browsing this forum: Google [Bot] and 126 guests
