MUM Europe 2020
lcrhea25
NV2
Thu Jan 05, 2012 4:21 pm
I have noticed to things about NV2 that I hope can be changed. First the band of the client and ap have to match. You can't have the client on b/g and the ap on b or g. It has to be on b/g as well. Also there is not throughput that shows up on the wireless connections anymore. Does anybody know if this is how it will be or if that is going to be fixed.
Larry
uldis
Re: NV2
Fri Jan 06, 2012 3:27 pm
Nv2 wireless protocol isn't using B rates, so you can't run Nv2 wireless in B wireless mode.
Check the log file for troubleshooting your wireless connection.
lcrhea25
Re: NV2
Wed Jan 11, 2012 4:40 pm
Ok thanks for the info.....what about the throughput?? Will that ever show up in NV2?
CCDKP
Re: NV2
Wed Jan 11, 2012 6:42 pm
Throughput varies based on the traffic demand. Put some traffic on the line and it should level out.
CC_DKP: MTCNA, MTCRE, MTCWE, MTCTCE, part-time packet wrangler
lcrhea25
Re: NV2
Thu Jan 12, 2012 7:32 pm
No....what I mean is when I looked at a wireless signal with NV2 turned on the throughput field is blank....it doesn't show a throughput.
ve2wat
Re: NV2
Mon Jan 16, 2012 5:49 pm
Agreed lcrhea25,
I used to look at it and adjust a customer connection accordingly.
Now its blank, would be nice to have that feature back.
Unless there is a way around I havent found yet.
Users browsing this forum: No registered users and 23 guests
