Hello. Can somebody help me with choosing proper mikrotik hardware and license for my requirements:
- built-in radius server to store approx. 100 users
- hotspot
- two wan (i'm planning to load-balancing two 20 Mbits channels)
10x
Even RB493G will handle your setup just fine, but if in the future you plan to increase customer base, and upgrade your WAN speed, you can go with the RB1100 seriesthis is a new project with the look into the future
now i'm looking at rb1100ah or rb1100ahx2
ok then, i'll stop at rb1100Even RB493G will handle your setup just fine, but if in the future you plan to increase customer base, and upgrade your WAN speed, you can go with the RB1100 series
And hotspot authorization will work in both AP's? I mean with 802.1x and just with WPAyou can do either, RouterOS supports WPA/2 EAP
