rviteri
Is my Web Proxy working?
Mon Feb 13, 2012 6:24 pm
Hello all,
I enabled my proxy for transparent use (port 80 to 8080 redirection) I have internet access but the status lists as everything as Zero.
I have a RB450G and I have anabled up to 200 mbyte of ram to use as a cache as I don't have any usb drives connected.
Thanks for the advise,
Status
Uptime
4d 17:25:39
Requests
0
Hits
0
Cache Used
0 KiB
Total RAM Used
0 KiB
Received From Servers
0 KiB
Sent To Clients
0 KiB
Hits Sent To Clients
0 KiB
Lookups
Successes
4 794
Not Found
53 039
Non Cachable
14 743
Denied
0
Expired
224
No Expiration Info
191
Inserts
Successes
10 858
Denied
0
Too Large
0
No Memory
0
Errors
2 352
Refreshes
URL Requests
266
Request Max. Age
1 261
Expired
120
Response Max. Age
190
Config Max. Fresh
6
Heuristic
70
Other
23
luismanson
Re: Is my Web Proxy working?
Mon Feb 20, 2012 5:01 am
did you setup te firewall rules?
rviteri
Mon Feb 20, 2012 5:24 am
Yes, redirected port 80 to 8080.
luismanson
Mon Feb 20, 2012 5:57 am
check with somewthing you know its cacheable, like:
http://img.routerboard.com/pricelist/261_l.png
that is on my mk proxy right now, load that pic and press reload a few time to see what happens
also you can go to loggin and ad a web-proxy debug rule so you can see the headers
mardawe
Wed Mar 14, 2012 11:36 pm
dear..
if you want to make sure that you web proxy cache server is working ,just do as the following:
1-open winbox
2-ip
3-firewall
4-mangle
5-add
6-chain=postrouting
Dst.address=(the computer that you are working on-write its ip address-)
Advanced//DSCP (TOS)=4 (as in your web-proxy setting)
Action=Passthrough
7-OK
now watch the Bytes meter;if it counts then the cache is working.
MahmouD KhuffasH
PALESTINE
share your experience
Users browsing this forum: anav and 77 guests
