neticted
Feature request: NS in static DNS
Fri Feb 17, 2012 10:10 am
It would be good to have an option to set NS, not just A records as static entries in Mikrotik DNS. That would be really helpful for managing internal DNS for larger networks.
janisk
Re: Feature request: NS in static DNS
Fri Feb 17, 2012 2:21 pm
for larger networks you can opt for bind server and use routers as DNS cachers, as what they are.
For example, run BIND server in virtual machine with 256MB of ram and some storage space (enough to install os and store some config)
Sob
Sat Feb 18, 2012 6:09 am
What about not so large networks where dedicated machine would be overkill? It would be really cool feature there.
E.g. small company with one internal Windows SBS server and MikroTik router as internet gateway. There's internal company.lan domain and you want to use it to give various other devices DNS names, because it can save few headaches in the future, compared to using numeric addresses. But you don't want to use the server as DNS resolver for client computers, because in unfortunate case when something happens to it, they would lose internet access (there's not much joy without DNS). So you need MikroTik router to be resolver for clients, but you also want it to be able to resolve names under company.lan.
It's possible to solve it using L7 trick, but it in fact sucks, because in most cases it means redirecting queries from client computers, not the queries sent by router (router's regular DNS servers are reachable through WAN and the outgoing DNS packets are decided to go there from the beginning, while the internal server is on LAN and it's too late to redirect the packets there). And generally there are enough ugly NAT rules in firewall already, even without this.
Per domain forwarding in ROS DNS cache would be real nice and clean solution. It can't be so hard to implement. And IMHO it's much less crazy than static entries using regular expressions that are already supported. ;)
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
neticted
Sat Feb 18, 2012 5:33 pm
Strange, allowing NS records is just matter of good will, and it requires almost no efforts to be implemented.
elgo
Thu Feb 23, 2012 1:08 pm
Oh well, SMB features are so higher level priority than DNS features for a router, you know... ahem.
RB450G - OpenWrt (so much more stable than with routerOS)
-> now: UBNT EdgeRouter Lite
(very unlikely to be MT customer again in the future)
neticted
Fri Feb 24, 2012 3:00 pm
You've got the point. SMB requires lots of resources so it is likely to be run on separate hardware scaled to provide what is needed. Local DNS does not require much resources and it is unlikely one will install separate server with too complex BIND or something else just to get basic DNS functionality.
I never understood why static DNS in Mikrotik is limited to only A records. I guess Mikrotik stuff decided that is not money making option as they decided that SMB is.
normis
Fri Feb 24, 2012 3:03 pm
For a home router like the RB751, SMB actually does make more sense. Plug in your USB drive and share movies between computers.
janisk
Fri Feb 24, 2012 3:21 pm
not the same person works on all these things, you know.
and __bind__ as it is does not require a lot of resources to work exceptionally well.
I am running one that is heavily used with 256MB RAM 1GB hdd as a virtual guest.
Sob
Fri Feb 24, 2012 6:10 pm
there were few older threads about the subject. But now when you know it for sure, maybe you could do something about it, given how easy to implement it should be? It's exactly the same mechanism as you already have in place for static A records. Just instead of returning fixed answer, you'd forward query to other resolver.
For this simple use, bind would be overkill even in smallest Metarouter on slowest RB. But fine, sometimes I'd gladly do it that way, unfortunately I'm one of those people who didn't see a stable MR yet. :(
slech
Long time Member
Long time Member
Tue Apr 03, 2012 11:39 pm
sorry for my english
neticted
Thu Apr 12, 2012 11:32 pm
I do not need full featured NS. A, NS and maybe CNAME will do.
Sob
Fri Apr 13, 2012 5:00 am
Fully featured DNS server would be too much work for too small target audience, so there's no chance to get it in ROS, I guess. Unless MikroTik decided to include e.g. BIND, but I don't think so. Not that I would protest against optional package with this functionality.
But they could at least add these simple features:
1) Allow to add more types of static records. Now they allow A records, so the required ground for adding more is there. It's simply a matter of adding user interface for few other common types.
2) Add support for per-domain forwarding to external resolvers, so user could say that e.g. everything under company.local should be forwarded to resolver 192.168.1.10, instead of to default resolvers configured under /ip dns.
Neither requires any big changes, the basic framework is there already. And once it's done, it doesn't need to be touched again for years. It's so simple there's not even any place for bugs. :)
herschel
Fri Apr 13, 2012 2:25 pm
I kind of want to be in the Mikrotik meeting where they decided to add Samba server and not fully functional NS. Just to hear how that conversation went.
elgo
Mon Apr 16, 2012 12:32 pm
:lol:
+1000000
normis
Mon Apr 16, 2012 12:57 pm
Such meetings never take place (where one feature is put against another). The reason is simple - our home routerboard models, such as RB751G are ideal for using as home file sharing servers. You keep your files there, for everyone else in the home to be able to use. Many other brand routers in this class also have such features, some even include built in HDD drives.
ayufan
Mon Apr 16, 2012 1:00 pm
The rest of missing home features includes DLNA (miniDLNA for ex.) and printer sharing (p910nd for ex.). For now only choice is OpenWRT.
Yes, I know is offtopic :)
hAP AC, TP-Link Archer C7 v2, RB951G, RB450G, RPI2, RPI zero
normis
Mon Apr 16, 2012 1:09 pm
this is off topic (see title) but RouterOS v6 already includes USB feature where you will be able to connect printers too.
elgo
Mon Apr 16, 2012 2:35 pm
Keeping it off topic in happyness and love of everyone :)
Shouldn't buyers/customers decide if a router is supposed to be a "home router" or... a "networking router"? I mean, is there some distinction that should be made based upon the price the customer paid? If he paid too much, it's not a "home router" anymore? Not enough, and he has no valuable opinion and should keep it shut?
That said, if both "home routers" and "really serious networking routers" are running the very same software... isn't it even more stupid to make such a distinction?
So please, don't tell me what I need and I don't need, I'm pretty sure I know that better than you.
Still, all repect due to support crew here :)
normis
Mon Apr 16, 2012 2:50 pm
that's the beauty of RouterOS. it can be whatever you want. It has MPLS and it has SMB. choose which features you will use. Nobody forced SMB on you. You can ignore it, and use it as a networking router for an ISP.
savage
Mon Apr 16, 2012 3:11 pm
Slowly but surely RoS is becoming more and more of an consumer / SOHO device, rather than an enterprise device...
Given what was posted above already, I seriously think that when v6 reaches the masses, it's going to be time to investigate alternatives for enterprise services. How more bloatware is added, how more overhead is added, how more potential problems is created. -sigh-
Either split RoS into two version trees, or provide specific NPK packages which can be installed / uninstalled at will. Whether active or not, I'm -definately- not happy about having services 'forced' on to me in RoS that is not used.
Regards,
Chris
normis
Mon Apr 16, 2012 3:19 pm
Can you give me an approximate list of features which would have to be separated in a "soho" package and how we could call it? I understand that each company has their own set of features they use, but we can't separate each small service into a separate package. And if we would make a "soho" package with all those "unnecessary" functions (from your point of view), what would happen if you needed just one of the, say, 10 features.
herschel
Mon Apr 16, 2012 4:13 pm
The SMB server in v6 was only pointed out (partly in jest) to highlight MikroTik's absurd priorities. Doesn't look like it even installs SMB server unless the device has USB. And I assume it's disabled by default even if USB is present, in which case it's not really bloatware. In and of itself, I don't even care that RouterOS is getting new features for home users, since it doesn't appear to have effected any existing functions within RouterOS.
janisk
Tue Apr 17, 2012 2:52 pm
well, if that gives you all any peace - addition of SMB as a feature did not impact speed of development of so called "serious" features you see in RouterOS v6 change-log. And definitely sped up addition of full NS functionality if that is someday added to RouterOS.
ayufan
Wed Apr 18, 2012 8:18 pm
Howerver, using firewall rules you can simulate behavior of different zones:
/ip firewall layer7-protocol
add name=home.local regexp="\\x04home\\x05local"
add action=dst-nat chain=dstnat comment=home.local disabled=no dst-port=53 \
    layer7-protocol=home.local protocol=udp to-addresses=192.168.10.8
Sob
Thu Apr 19, 2012 11:46 pm
It does work, but:
1) it redirects queries from clients directly to target nameserver, so it bypasses cache on ROS (ok, it's probably not such a big deal)
2) for the same reason, redirected domain can't be resolved by router itself
3) if target server is on the same subnet as client, you need another srcnat rule (hairpin)
4) if target server is on separate subnet which is not supposed to be able to communicate directly with client's subnet, you need another exception (probably rare, but still..)
Simply put, it's not nice nor admin friendly. But better than nothing of course.
miharoot
Sun Feb 02, 2014 9:39 pm
+1000 to allow NS record in dns static cache.
LinFor
Mon Feb 03, 2014 9:49 pm
+1 for native zone forwarding with caching (without layer7)!
Ferrograph
Thu Aug 27, 2015 2:37 pm
+1000 this for me too.
Use case:
I install Mikrotik and Ubiquity Unifi combination for medium to large (but simple) networks with off site Unifi Controller. The Unifi access points do a lookup on "unifi" to find the controller for adoption with is in the cloud with an IP address that occasionally changes.
Yes I can SSH into each AP to assign the location of the controller, which is ok when there are a handful, but when there are 30+ its a long tedious process.
Would be very useful to have "unifi" = unifi.controller.com. Then all the AP's will appear for adoption without sitting for long periods assigning.
add address=unifi.mycontroller.com name=unifi
or maybe even
add alias=unifi.mycontroller.com name=unifi
Im sure this cant be a hard? Seems like a minor but very useful feature to me.
neticted
Mon Feb 20, 2017 10:21 am
Two years later and I still need NS in DNS and NEVER EVER needed SMB.
I guess I am not professional enough when I need DNS and do not need SMB.
Funny thing is this is so simply to add and it s just matter of somoene's good will.
Gaston
Tue May 30, 2017 9:54 am
I would like to sign this request as well, but depending on the local network setup NS entries are not sufficient so I would like to add the option (as an option for the NS record) for the NS entry to behave as forwarder as well.
This means that if I add an NS entry for "local.mydomain.net" into the static list without this option, any NS record request for local.mydomain.net would return the given entry as expected. With the "forwarder" option enabled however, any request for *.local.mydomain.net for any record type (including NS,MX,...) where there is no matching static entry (currently only for A record) would be directed to the given name server instead of normal processing.
My scenario is for medium networks with quite some IP devices requiring a DNS setup but with only one dedicated server being able to be the DNS server and where internert access is the primary DNS use. In this configuration setting the DNS to the internal DNS server is at risk iof that one is down. Even with a secondary DNS entry at the client level (not available in all cases) this is not really practiable as tests did confirm.
Since internet access is the primary use and the router is required for it it is preferebale to have the router being the primary DNS server for my clients. Previously I did set the internal DNS as primary DNS and the router as secondary but this showed as a bad solution as many clients seem to stick with th epriomary DNS when it fails requiring a timeout at each (or each other) non-cached request.
So I came back to a configuration where most of my clients arte configured for using the router as primary DNS and written a script on my Linux DNS server that parses the DNS configuration and uploads static entries to the router.
bluecrow76
Thu Oct 05, 2017 11:59 pm
Just so everyone knows, this was a feature request long before this thread. We asked for this back when we were using RoS v2. They were able to add RegEx capabilities to the DNS proxy, but nothing yet in over 10 years about being able to specify the record type...
I'm working on an issue for a customer right now in China where we need to do queries across a VPN for some domains and locally for others. Even though we have a big bad Cloud Core Router over there, we're having to setup a virtual machine so we can run dnsmasq... unneeded infrastructure because our favorite router vendor won't add a simple feature to an already amazing router platform. :-(
I will throw out some huge kudos for all the other amazing features that have come out over the years... Mikrotik is still the best!!! :-)
neticted
Fri May 24, 2019 11:36 am
Another two years later and I still need NS in DNS.
I guess I am stil not professional enough when I need simple DNS.
Another argument:
Imagine small company that has three offices, so small that each deals fine with single Mikrotik in each office. Office are connected via VPN. Each office has some static DNS entries for local services. But they also need to access services in other offices via VPN using human readable addresses instead of IP's. For this to work now whole set of static DNS entries must be copied and synchronized among offices.
Simple option to set NS records to point to other offices would be tremendous.
Sob
Fri May 24, 2019 3:13 pm
To think I responded to this in 2012, and probably sooner in other threads, ... oh the memories. And I still need it all the time. Maybe we should get more radical, do a leaflet campaign or something. :)
muetzekoeln
Fri May 24, 2019 3:29 pm
+1 for NS records in DNS static cache, but also I would like to have SVR records there.
Sob
Fri May 24, 2019 5:12 pm
It's two things:
1) Most people don't want ability to add actual NS records but conditional DNS forwarding (nicely summed up in this thread)
2) Adding records of various types could be useful too. With that, I understand that MikroTik might not want to specifically support all of them, but they could easily add support for generic syntax (raw bytes) and you could enter any record that way. They have the same thing for DHCP options. It's not the most user friendly way, but allows people to do anything they want.
Users browsing this forum: MSN [Bot] and 64 guests
