MUM Europe 2020
harisagars
how to use public ip routing on lan interface
Fri Feb 17, 2012 8:44 pm
O I AM USING 450G WITH SIMPLE QUEUES . ROUTER O/S VERSION 5.13 AND I NEEED SOLUTION THAT ALL LOCAL LAN PORTS SHOULD ACCESS PUBLIC WHICH ARE FREE ON WAN IS IT POSSIBLE IF SO PLS GIVE SOLUTION I AM BIGINER
sorry for my poor explanation
PLZ CHECK THE JPEG FILE ATTACHED BELOW
Ibersystems
Re: how to use public ip routing on lan interface
Sat Feb 18, 2012 12:18 am
You can make this with NAT. set all IPs to wan port (ether1) and create nat rules to the priate networks.
Read about NAT in the wiki.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
harisagars
Sat Feb 18, 2012 5:20 am
Can u pls explai clearly i have added to wan interface and what should be done next what nat rule should be ritten ther pls help me
vik1988
Sat Feb 18, 2012 7:04 am
you can try this,
/ip firewall nat add chain=srcnat src-address=2.2.2.0/24 action=src-nat to-addresses=202.153.47.34
/ip firewall nat add chain=srcnat src-address=1.1.1.0/24 action=src-nat to-addresses=202.153.47.35
/ip firewall nat add chain=srcnat src-address=30.30.246.0/24 action=src-nat to-addresses=202.153.47.36
Vikas Kumar Gupta
If you Like my post then add KARMA
skype- kumarvikas_gupta
harisagars
Sat Feb 18, 2012 7:05 pm
hello vik thanks for your reply i have done which u written but it is not working
Ibersystems
Sat Feb 18, 2012 7:34 pm
Do you have a route to 0.0.0.0? With the correct gateway?
Martín
harisagars
Sat Feb 18, 2012 7:50 pm
yes i did
vik1988
Sun Feb 19, 2012 7:39 am
Hello Hari,
have you checked internet on 2.2.2.0/24 pool.
or you can post your "export" data here....
Vikas Kumar Gupta
harisagars
Sun Feb 19, 2012 1:34 pm
yes i have checked net its comming. i should keep gateway as router ip
vik1988
Mon Feb 20, 2012 1:39 pm
:lol:
Vikas Kumar Gupta
Users browsing this forum: Bing [Bot], MSN [Bot] and 48 guests
