MrDave
Simple setup that I just can't figure out.
Thu Mar 08, 2012 8:32 pm
OK, I am not a total idiot but I feel like one now. I thought this would be a simple configuration but I cannot figure it out.
Client has a 10 meg circuit with a full class c 192.168.1.0/24 they have a remote location that they want to cut off into it's own subnet of the class c 192.168.1.248/29
So I have:
192.168.1.1/24 (ip of mt) going to ether1
192.168.1.248/29 going to ether2
and for routing 0.0.0.0 /0 going to 192.168.1.1
And it does not work. What am I missing?
Thanks,
Dave
cbrown
Trainer
Trainer
Re: Simple setup that I just can't figure out.
Thu Mar 08, 2012 8:52 pm
What part isn't working?
C.Brown
cbrown[at]cbrown.co
Telegram: @chris4brown
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
MrDave
Thu Mar 08, 2012 9:37 pm
I will not route any of it. I can ping 192.168.1.248 from the far side but that is it.
Yes the subnet on the equipment on the far side is correct.
Thanks,
Dave
sja
Fri Mar 09, 2012 8:35 am
Question: have you set up a route to 192.168.1.248/29 on the box that has assigned your MT its 192.168.1.0/24 ?
I had a similar problem involving a Draytek modem which refused to route - it wanted all my subnet IP's to be directly connected to it. In the end to get things to work I needed to set arp=proxy-arp on the MikroTik ether1 ethernet interface.
savage
Fri Mar 09, 2012 8:40 am
So I have:
192.168.1.10/24 (ip of mt) going to ether1
Same network. 192.168.1.10/24 includes 192.168.1.248/29
Machines on the 192.168.1.10/24 network will not communicate to 192.168.1.248/29 through your router.
Regards,
Chris
sja
Fri Mar 09, 2012 9:01 am
But setting arp=proxy-arp on his MT ether1 should allow you to do what you want.
cbrown
Trainer
Trainer
Fri Mar 09, 2012 2:04 pm
You should really separate your networks. Instead of using a /24 you could use a /25 or just change to 192.168.2.0/24 for example. There is about a million ways to do it but you should really separate.
C.Brown
cbrown[at]cbrown.co
MrDave
Sat Mar 10, 2012 12:25 am
I can't separate it :( I don't need anything at the far side to see anything at the other site except 192.168.1.1 the far gateway.
-Dave
cbrown
Trainer
Trainer
Sat Mar 10, 2012 3:11 am
Then separate. You don't need to use the gateway of that network for this to work. Can you provide a drawing and exactly what you are trying to achieve?
C.Brown
cbrown[at]cbrown.co
MrDave
Sat Mar 10, 2012 4:00 am
I just made some changes and it STILL does not work. I am starting to doubt my ability to use networking components.
These are all live IPs part of a larger network that I have NO CONTROL OVER that is the issue. Although I am using this example with 192.168.x.x they are all live IPs in the real world.
Gateway = 192.168.1.1 part of a /22
MikroTik Router 192.168.1.40 I used /22 /24 neither worked in this setup this is port 1 of the router
Remote site 192.168.3.1 /29 (port 2 of the router and the gateway for the machines at the remote site)
All I need to do is have the MikroTik route from 192.168.3.1 to 192.168.1.1 so those machines can see the world.
The other small issue is there is a sticker on the fiber converter that says DO NOT USE PROXY-ARP. So if there is a way around using it that would be great, but as of now arp or no arp does not matter nothing routes anyway.
Dave
Users browsing this forum: Hjr, Rikjaard and 51 guests
