prawira
Trainer
Trainer
RB433UAH / RB751U-2HND with USB hub
Fri Mar 09, 2012 1:09 pm
Hi there,
currently we has RB433UAH and RB751U-2HND.
As the above two products has USB port, is it possible to put USB Hub into it and connect some USB device on it (such as flash disc, usb printer, and usb modem) on the same time ?
if so, can we do printer sharing on the above RBs?
means, from clients print to the printer that connected to (via usb hub) above RBs ?
TIA
Paul
normis
Re: RB433UAH / RB751U-2HND with USB hub
Fri Mar 09, 2012 2:58 pm
Yes, it's possible to use USB hub.
No, USB printer is not supported. You can use 3G modem and flash disk.
omata
Fri Oct 05, 2012 7:13 am
Will be supported printers for this device? a la Airport devices.
Regards,
Oscar.
el berto
Mon Nov 12, 2012 6:27 pm
Hi, I am trying to use USB/serial adapter (chipset PL2303) on RB411GL.
Using stand-alone serial adapter I see "USB2" on port window.
I set remote access, then I can correctly access through HyperTerminal (Winsock TCP/IP) to serial device behind routerboardì (I don't know why, but status of remote access connection "USB2" is "invalid").
If I use an USB hub, I still see "USB2", but this time I can't connect through hyperterminal.
If I try with USB modem MT833UP, it works correctly with or without USB hub....
Any idea?
Thanks.
normis
Tue Nov 13, 2012 12:57 pm
Yes, it's a known issue that some serial adapters have problems working with a hub
el berto
Tue Nov 13, 2012 4:44 pm
So it's a bug with serial adaper? But on supported hardware list, only one available is PL2303 chipset...
Then I'll try with another serial adapter chipset.
Users browsing this forum: Google [Bot], Google Feedfetcher and 103 guests
