411ah
How to log Wireless Registration table information locally
Fri Mar 09, 2012 4:56 pm
Hello all,
I wanted to log Tx/Rx signal strenght, Tx/Rx CCQ, Signal to Noise and some other parameter from Wireless Registration Table in a log file stored locally. I would like to log the paramaters on a periodic interval. If anyone could guide me on how to go about proceeding with this it would be very helpful.
Ibersystems
Re: How to log Wireless Registration table information local
Fri Mar 09, 2012 6:06 pm
I don't have too much time, but I had a script that logged the signals of a wifi-N link and show it to /log. I hope you can modify it to get it working as you need:
:local valor1;
:local valor2;
:local valor3;
:local tx;
:local rx;
:local total;
:set valor1 [/interface wireless registration-table get number=0 signal-strength]
:set valor2 [/interface wireless registration-table get number=0 signal-strength-ch0]
:set valor3 [/interface wireless registration-table get number=0 signal-strength-ch1]
:set tx [/interface wireless registration-table get number=0 tx-rate]
:set rx [/interface wireless registration-table get number=0 rx-rate]
:set total ([$valor1]."                                  CH0 es ".[$valor2]." y CH1 es  ".[$valor3]."  Rates teoricos  tx ".[$tx]." y rx ".[$rx])
:log info [$total]
Picture here: http://screencast.com/t/Bie8yaMx
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
411ah
Fri Mar 09, 2012 9:07 pm
Thank you very much! That was very helpful.
I just had one more question; how would I make it log the results more frequently?
Ibersystems
Fri Mar 09, 2012 9:39 pm
This is a script. To run a script, you have to add a scheduler in system/scheduler. Then, there you can configure the time you want to run the script. 1x hour, 1 per minute.. etc..
Martín
411ah
Fri Mar 09, 2012 10:00 pm
Sorry to bother again, I had another question. Is there a way to put the log file on the C drive for example and have it write over there?
Ibersystems
Fri Mar 09, 2012 10:06 pm
In system logging, set "info" write to disk.
But this will log ALL.
Better use a syslog server.
Martín
411ah
Fri Mar 09, 2012 10:26 pm
Thank you for your help thus far. I change the settings so it would write on the disk but when I open the file using notepad its a mess. Is there a way to force every new log entry to start at the next line?
411ah
Fri Mar 09, 2012 10:35 pm
Nevermind Notepad++ displays the logs much better. But now there is another issue:
Once the log file reaches 16.5KiB it overwrites itself. Is there a way to allow it to continue logging?
411ah
Fri Mar 09, 2012 10:50 pm
Okay I figured it out. For anyone interested you can change the number of lines each log contains, default is set to 100.
plisken
Sun Aug 23, 2015 1:03 pm
:local valor1;
:local valor2;
:local valor3;
:local tx;
:local rx;
:local total;
:log info [$total]
How to use this script with email tool?
Ibersystems
Re: How to log Wireless Registration table information locally
Mon Aug 24, 2015 2:31 pm
emailing the [$total] parameter.
/tool e-mail send to=you@yourdomain.com subject="test" body=[$total] something like that
Martín
Users browsing this forum: No registered users and 9 guests
