rufus
[RB750UP] Huawei E398 connection problem
Thu Mar 29, 2012 3:29 pm
I have brand new Huawei E398 modem which is on the "Supported Hardware" list. My mikrotik is RB750UP with 5.14 OS.
I have some problems with connection. On this forum I found topic about problems with K3520 and I have same looking log after configuration.
initializing...
reseting link...
initializing modem...
dialing out...
authenticated
terminating... - modem hunged up
disconnected
I try diffrent init comands ( modem respoding on AT, ATI, ATZ comands from terminal ), check PIN, check Phone but nothing work still same log loop.
What can I check next ?
sebus504
Re: [RB750UP] Huawei E398 connection problem
Fri Mar 30, 2012 8:54 am
Hi, sorry for my english. First disable pin (not in mikrotik but in software of huawei)
I have this same problem.
Solution:
connect modem to windows, login modem, then quickly switch to mikrotik. This is "half solution" but in my mikrotik (rb433)working. When I want s to connect by mikrotik get this same log.
Max speed modem connected to mikrotik is 12Mbit. When I plug to windows (windows7) max speed is 30-40Mbit (modem is connected to this same station).
Anyone have an idea why?
rufus
Fri Mar 30, 2012 10:23 am
Thanks for replay.
I disable PIN using phone and sitll not working . Same log.
sebus504
Sun Jul 29, 2012 1:50 pm
Hello, you must turn off auto cd. I found command AT AT^SETPORT="A1,A2;1,2,3,7" and this working with my e398.I have problem only with speed, perhaps when I plug usb hub then speed will go up. My routerboard is rb433uah.
kostek
Thu Aug 09, 2012 11:27 am
Hello, I have the same problem. Modem uses 3G not LTE. Signal strength -65 dBm. Speedtest shows ~15 mbit/s. After pluging to laptop with original driver speedtest shows ~50 mbit/s.
sebus504
Mon Oct 07, 2013 2:19 pm
Hi, this is answer from Mikrotik:
there is nothing we could do as we use ppp type connection for 3g/4g for those
modems and not ethernet type connections as it requires a separate driver and
currently we are not planning to add support for it.
Regards,
Uldis
Users browsing this forum: No registered users and 22 guests
