MUM Europe 2020
bbs2web
802.11n - Bandwidth usage favors AP to station, make fair?
Sun Apr 22, 2012 11:25 pm
I can transfer data at the limit of the ethernet port, on a 50 meter 802.11n link. Testing transfers in either direction has 'scp' reporting speeds of '10MB/s' between two linux systems.
If it however run transfers concurrently, the transfer rate heavily favors the direction from the AP to station:
AP --> station: 6.2MB/s
station --> AP: 1.2MB/s
Total also drops to 7.4 MB/s, I get 10 MB/s perfectly when transferring only station to AP or AP to station.
Simply switching modes around (making the 'ap-bridge' a 'station' and vice-versa) reverses the transfer speeds when full duplex.
Q1: Is this normal?
Q2: Would this be solved by adding two additional R52Hn cards and another set of parabolic dishes to run nstream-dual in 802.11n (chained) configuration?
Q3: Could this at least be made fair with traffic queues and still retain the full single way transfers?
sten
Forum Veteran
Forum Veteran
Re: 802.11n - Bandwidth usage favors AP to station, make fai
Wed May 02, 2012 7:35 am
If you consider how the protocols operate, there will probably always be a slight favor for the AP in terms of bandwidth.
However, signal quality can make it look like the opposite is true.
Move along. Nothing to see here.
Users browsing this forum: Safi and 26 guests
