MUM Europe 2020
Sigma721
Usermanager not disconnecting clients
Wed Apr 25, 2012 10:40 pm
Hi
I have a rb433 with a hotspot setup, running a radius server connected to UM on the same board.
It works, users gain access to the internet, and it keeps track of the data each user uses. But it doesn't cut them off once they reach their limits(which are set up under limitations/profiles).
Anyone know why this is?
ulikroessin
Re: Usermanager not disconnecting clients
Fri Apr 27, 2012 1:16 am
I had the same problem some time ago and support told me this, what works exactly:
2) Use uptime limit from Profile Limitation to set session time, as I do not see
any session-time left next to active client now (from your print output).
Uptime limit will use fine, HotSpot will disconnect and remove user from active
list once limit is reached.
Regards,
Sergejs
Saludos
Uli
Sigma721
Tue May 01, 2012 1:32 pm
Hi
Thanks for the reply.
Could you please explain that a bit more, I am not too sure what must be done.
I am using data and not time to limit the users.
Regards
ulikroessin
Wed May 02, 2012 2:25 am
That I did not know. I´m using time-limit and this only cuts correct if they use "uptime" in /profiles/limitations/limits. If they only put it in /profiles/validity it does not work exactly. Means, it cut not a established connection, only after logout it is not possible to make a new login.
If it not works with the limits im limitations you should ask Mikrotik-Support.
Saludos
Uli
dunga
Thu Jun 21, 2012 12:25 pm
Hi
The solution to ur problem is simple, in ur usermanager just disable coa port, that will solve the issue. look at this post, http://forum.mikrotik.com/viewtopic.php?f=10&t=59417
Users browsing this forum: No registered users and 3 guests
