sawireless
Strang Help Needed on 3 Dial up on 750
Sat Apr 28, 2012 2:26 pm
OK guys
i need some help on this,
OK here it goes, i have a house with 2 clients on the premises the one client wants 1meg PPPoE the other wants a 4 Meg PPPoE and they want to use VOIP also PPPoE..
On the 750 I have..
1: Ethernet 1 links up to a Air Grid M5 in Bridge mode
2: Ethernet 2 setup for client 1 ( DHCP)
3: Ethernet 3 setup for client 2 ( DHCP )
4: Ethernet 4 setup for Voip ( DHCP )
I have setup PPPoE Dial-up
1: PPPoE Dial-up for client 1
2: PPPoE Dial-up for client 2
3: PPPoE Dial-up for Voip
For some reason I can get the Nat and the routing to work, each client must go out on his own PPPoE Dial-up .
we have also set up on Radius Manager 4 that..
client 1 gets a ip address 10.1.0.198
client 2 gets a ip address 10.3.0.188
Voip gets a ip address 10.5.0.120
Can some-one Please help
docmarius
Re: Strang Help Needed on 3 Dial up on 750
Sun Apr 29, 2012 11:00 am
You could try the following setup:
IP->Firewall:
- In the "Mangle" tab add 3 rules to the prerouting chain to mark the outgoing packets based on the incoming interface with 3 different routing marks.
- In the NAT tab add masquerade rules for each PPPoE outgoing interface with the corresponding routing mark set according to the ones in the first step
- In the Filter tab, add 6 forwarding rules, 2 from/to each interface pairs (incoming and outgoing, you don't need to use the marks here)
I use this setup with 2 PPPoE interfaces and it works without problems.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
docmarius
Sun Apr 29, 2012 11:08 am
Of course you must also set up the default routes in the IP->route tab so each connection with the proper routing mark has a different default route.
Users browsing this forum: Baidu [Spider], madwolf27 and 19 guests
