rviteri
RB751u-2HnD reboot on Skype and FaceTime
Tue May 01, 2012 6:06 am
Hello I have a RB751u-2HnD with version 5.14. The device always restarts after I initiate a Skype or FaceTime video call. Then when I reconnect it works fine. How can I fix this? This is extremely annoying.
Thanks,
estdata
Re: RB751u-2HnD reboot on Skype and FaceTime
Tue May 01, 2012 9:59 am
Thanks,
The way to reset your router or do an upgrade to the next version -> 5.15
don't forget to give me karma if got help
normis
Wed May 02, 2012 12:42 pm
Test with v5.15 where some issues were addressed already
rviteri
Sat May 05, 2012 7:10 pm
Normis, this thing doesn't work. Now it just reboots randomly. Who can fix this?
machitza
Sun May 06, 2012 8:35 pm
mine resets when downloading with flashget (5 or more threads). 1 is ok...so far... ghhh
rviteri
Mon May 07, 2012 1:41 am
Very uncool
normis
Mon May 07, 2012 8:10 am
Guys, if you did what I asked (upgrade to v5.15) then please send us more info, Attach supout.rif file and email to support. We can only fix the issue, if you give us information.
rviteri
Mon May 07, 2012 11:52 am
Yes, I did it and I already sent a support file.
runic
Sun May 13, 2012 9:27 am
My RB751u-2HnD reboots 1- 2 times per week. I just performed upgrade to Router OS 5.16, let's see what's will happen.
But it's unfortunate that it has this behavior - we plan rather large rollout of 16 RB751u-2HnD devices, it should be solved before.
estdata
Sun May 13, 2012 3:32 pm
You will then restart, the device itself? If so you may have a thing wachdog settings
rviteri
Mon May 14, 2012 11:21 am
@runic keep us posted on your results. I will update my device however I am not using it as part of my network anymore...
Users browsing this forum: hexma, Majestic-12 [Bot] and 132 guests
