Raid0
Omnitik and SXT low speed
Wed May 09, 2012 11:52 am
Im having troubles with SXT speeds with Omnitik. The distance between two links is only 200M with nothing between them.
I have 3 cameras behind the SXT. Im having some trouble with the PTZ camera. When I tested the speeds from Omnitik
i got ~4Mbps receive and ~80Mbps for send from Omnitik. Same speeds from SXT sent to Omnitik is ~4Mbps and receive ~70Mbps.
Im using Nv2 protocol. Tried 802.11 to. Got the same speeds but speed test connecting took longer and PTZ camera was even slower.
Is the ~4Mbps normal speed for receiving info from SXT to Omnitik? What could be causing this?
cbrown
Trainer
Trainer
Re: Omnitik and SXT low speed
Wed May 09, 2012 10:54 pm
Can you post some details about the wireless. What is the signal strength and CCQ?
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
Raid0
Thu May 10, 2012 1:32 pm
Signal strenght is -63/-62 dBm and CCQ is 73/84%. Tried to realign the antennas but nothing.
cbrown
Trainer
Trainer
Thu May 10, 2012 3:40 pm
Can you post /interface wireless export
C.Brown
Raid0
Thu May 17, 2012 11:36 am
I attatched the wireless export images from the Omnitik and one of the SXT
ddd
Fri May 18, 2012 1:20 am
Do a spectrum scan on the Omnitik and find the best channel with no usage.
/interface wireless spectral-scan wlan1 range=5ghz
Raid0
Tue May 22, 2012 11:38 am
I did that scan, it didnt find anything.
brosky
Tue May 22, 2012 11:56 pm
i have the same problem here, i have 2 sxt connected to a omnitik, distance is 300m and 1km.
Signal is -59 to -65, i'm alone on the 5180 freq. (i got a pair of loco's on 5500mhz)
This is my second setup with omnitik with no 'luck' finding a good and working configuration, and i'm starting to think
that it's the device that's defective, or the software. And yes, i have 5.16 installed. And no, quickset does not work at all.
08:28:28 wireless,info 00:0C:42:DC:88:D7@wlan1 established connection on 5180, SSID ap-codor
08:54:24 wireless,info 00:0C:42:DC:88:D7@wlan1: lost connection, no beacons received
08:54:27 wireless,info 00:0C:42:DC:88:D7@wlan1 established connection on 5180, SSID ap-codor
08:55:17 wireless,info 00:0C:42:DC:88:D7@wlan1: lost connection, no beacons received
08:55:21 wireless,info 00:0C:42:DC:88:D7@wlan1 established connection on 5180, SSID ap-codor
this happents when i try to do some traffic.
ddd
Wed May 23, 2012 3:33 am
Now thats out of the way, try switching the wireless protocol the nstreme and see if that improves the speeds.
Also try another frequency. I think I remember reading that the SXTs preform best around 5400-5600ghz
davidw
Wed May 23, 2012 1:45 pm
I too just setup an omnitik with sxt using nv2. Very slow speeds over 2km link nothing in the way .
No one else on the same frequency as me
Huge snr of about 40b
Have tried turning power down but no luck
Any other suggestions
Will try replacing the omnitik tomorrow wit an sxt to see if that fixes anything.
brosky
Thu May 24, 2012 8:41 pm
solved my problem, i had to force NV2 protocol.
davidw
Thu May 24, 2012 9:51 pm
So what speeds are you getting now ?
Can summarize your settings ?
Channel
Band
Wireless protocol
Mode
Ht chains
Etc etc
Distance between aps
brosky
Thu May 24, 2012 11:25 pm
sure,
the setup was needed to go around a hill.
1st client
[admin@txCodor2] > interface wireless print
 0  R name="wlan1" mtu=1500 mac-address=00:0C:42:84:6F:55 arp=enabled
      interface-type=Atheros 11N mode=station-bridge ssid="ap-codor"
      frequency=5180 band=5ghz-onlyn channel-width=20/40mhz-ht-below
      scan-list=default wireless-protocol=nv2 wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=yes bridge-mode=disabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 hide-ssid=no security-profile=default
APOmnitk , as the 'relay' point
[admin@AP Codor] > interface wireless print
 0  R name="wlan1" mtu=1500 mac-address=00:0C:42:DC:88:D7 arp=enabled
      interface-type=Atheros 11N mode=ap-bridge ssid="ap-codor" frequency=5180
      band=5ghz-onlyn channel-width=20/40mhz-ht-below scan-list=default
      wireless-protocol=nv2 wds-mode=dynamic wds-default-bridge=bridge1
      wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=default compression=no
2nd client, as the endpoint
[admin@rx_CodorCapat] > interface wireless print
0  R name="wlan1" mtu=1500 mac-address=00:0C:42:87:E0:9D arp=enabled interface-type=Atheros 11N
mode=station-bridge ssid="ap-codor" frequency=5785 band=5ghz-a/n channel-width=20mhz
scan-list=default wireless-protocol=nv2 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
I need only 10mbps, but i got 38mbps duplex, 80mbps udp, 50mbps tcp.
signal is -55/-57 (300/150mbps) for the 300m link
and -62/-60 (117/117mbps) for the 1km link
davidw
Thu May 31, 2012 11:43 pm
All fixed - spectral scan showed interference - selected a different channel
Now getting 100mb
gio
Tue Jun 05, 2012 1:31 pm
Hi brosky, please can you explain to me ( i have the same installation 1 OmniTIK 2 SXT) what you mean force NV2 protocol where i will find this? and must i do the same to the SXT's or only on the omniTIK?
(hope you understood, because of my bad english) :)
have a nice connection!
thanx in advance!
brosky
Thu Jun 07, 2012 1:04 am
force maybe is a too strong word.
I used before as wireless protocol "any", then i change it to NV2 to all devices (2 cpe + 1omnitik)
gio
Thu Jun 07, 2012 11:42 am
Hmm... thanx for the reply!
and i thought it was something else, i have choosen NV2 protocol but at this time very bad connection bzw.(german) very low speed under 200 Kbps.
I will try to update / upgrade my installation (2 SXT & 1 OmniTIK).
I have a Question about it (to everyone). Can i upgrade RouterOS and Firmware of the OmniTIK in the same way like it is shown for the SXT's in this link???
thanx!
ddd
Fri Jun 08, 2012 3:51 am
Yes
gio
Fri Jun 08, 2012 11:27 am
many thanx for the Answer!
After upgrade RouterOS and Firmware to 5.17 in the Section (via browser) from the left Menu Tools --> Bandwith Test after choosing one of the connected SXT's and setting user as admin and press the START Button i can't se anything in the Graph (like before upgrade) but the [Tx/Rx 10s Average] is ~ [7.0 Mbps/4.0Mbps] (and i think this will be OK or am i wrong?) why is nothing shown on the Graph?
Users browsing this forum: Bing [Bot], Google [Bot] and 23 guests
