MUM Europe 2020
webequipped
v5.12 RB450G routers (x3) refuse to upgrad to v5.16?
Sat May 12, 2012 5:38 pm
I have been working with RouterOS for a very long time. I have done dozens and dozens of firmware upgrades as well as license upgrades. I am not a newbe at this, however, I am an old man so my brian is slowing down :-)
Yes, I am using the mipsbe firmware. Yes, all three routers are licensed properly. Yes, I am putting the npk file into the file list location. Yes, the complete npk file is uploaded before I reboot. Yes, I have made a backup. I my fustration leeking out here, sorrrrry.
What gives with this issue, what am I missing that is so obvious?
I am I jumping to many version ahead?
Do I need get v5.13, v5.14 adn v5.15 installed first?
Any tips would be greatly appreciated - thank you.
cbrown
Trainer
Trainer
Sat May 12, 2012 5:46 pm
Sounds like you are doing it right and you should be able to jump versions. I have a few 450s at the office and I can try to replicate on Monday.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
jtroybailey
Re: v5.12 RB450G routers (x3) refuse to upgrad to v5.16?
Sat May 12, 2012 5:51 pm
Give netinstall a go, if they are easy enough to get to.
acim
Mon May 14, 2012 3:19 am
Have you tried separate packages (all_packages)?
Ham
Mon May 14, 2012 5:45 am
(silly question) but how are you rebooting the router, a power cycle I have found will not work for an upgrade.
Make sure you /system reboot for the upgrade to take place.
NathanA
Forum Veteran
Forum Veteran
Mon May 14, 2012 11:46 am
When an upgrade fails for certain reasons (invalid/expired license, mismatched platform, corrupt NPK), there *will* be a reason for the failure logged to memory for your perusal after reboot. So...what does '/log print' show?
-- Nathan
cbrown
Trainer
Trainer
Mon May 14, 2012 2:41 pm
I downgraded a 450G from 5.14 to 5.12 then upgraded to 5.16 without any problems.
Have you been pulling the plug or rebooting?
C.Brown
webequipped
Tue May 15, 2012 7:15 pm
I thank all of you for taking the time to respond. To answer a couple of your question.
Yes, I used System/Reboot as I am not at the remote locations of those routers I cannot physical power cycle them.
Also, I could have sworn I looked at the log file and did not see any error, however after checking it again, per the suggestion in this post I have found the following: system erro - broken package routeros-mipsbe-5.16.npk.
So, I am guessing that my download got corrupted.
Again thank you all for taking your time to respond.
Have a great week - Johan :-)
Users browsing this forum: Google [Bot], zhihar and 100 guests
