engineertote
PPP Active connection + simple queue Script
Sun May 13, 2012 12:39 pm
Hi All
i'm trying to write script to add simple queue for each active user in PPP active with no success till now , the target is :
i have 4 service levels each level have difrent up / down limit and the required sicript is to add new simple queue once the client be active on PPP active .
Any help is highly appreciated .
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
c0d3rSh3ll
Long time Member
Long time Member
Re: PPP Active connection + simple queue Script
Sun May 13, 2012 7:15 pm
try this script
foreach pppuser in=[/ppp active find ] do={
local ip [/ppp active get $pppuser address ]
local name [/ppp active get $pppuser name]
foreach queue in=[/queue simple find] do={
local tmp [/queue simple get $queue target-addresses]
if ($ip!=$tmp) do={queue simple add name=$name target-addresses=$ip max-limit=256k/512k
change max-limit (upload/download)
nothing
acim
Mon May 14, 2012 3:22 am
You can use RADIUS server or UserManager to reply with bandwidth limit attributes.
engineertote
Mon May 14, 2012 3:10 pm
i tried it but its didn't add any simple queue when the ppp user logged in as active user
try this script
Ahmed
c0d3rSh3ll
Long time Member
Long time Member
Mon May 14, 2012 9:52 pm
what version is runing in your routerboard??
paste in the terminal and read the output
I tested in 5.15 and work fine
nothing
engineertote
Mon May 14, 2012 11:55 pm
i tried 5.12 and 5.16 ,, i believe that there is no difference ..
when u test it is is totall same just copy and past into the script and run the script ??
Ahmed
c0d3rSh3ll
Long time Member
Long time Member
Tue May 15, 2012 5:49 am
copy and paste in the terminal.
nothing
engineertote
Wed Oct 17, 2012 4:07 am
do we need to modify the lines in red ,,bellow code
try this script
local ip [/ppp active get [color=#FF0000]$pppuser address[/color] ]
local tmp [/queue simple get [color=#FF0000]$queue target-addresses[/color]]
if ($ip!=$tmp) do={queue simple add name=[color=#FF0000]$name[/color] target-addresses=[color=#FF0000]$ip[/color] max-limit=256k/512k
Ahmed
engineertote
Thu Feb 14, 2013 1:32 am
its work for me , but if i have diffident service level , any idea how to create script for each service level ?
try this script
Ahmed
Users browsing this forum: juanma and 86 guests
