MUM Europe 2020
prompt
Mikrotik: RouterBoard RB1100AHx2 - CRASH
Thu May 17, 2012 10:43 am
hello
i have this board in network like Qos bridge for max 100Mbit.
And now we discover some reboots by critical error.
It is not regular. sometime after 12hours, sometime after 4days.
In log we can see only
system critical error - system rebooted because of kernel failure
system critical error - router was rebooted without proper shutdown (case1)
After first crash a was upgrade OS. Now is installed 5.14.
I was isolate RB from other network. RB have IP which isnt in the network a have no route to the internet. (attack prevent)
But problem come again.
Is it HW problem?
janisk
Re: Mikrotik: RouterBoard RB1100AHx2 - CRASH
Thu May 17, 2012 11:35 am
generate support output file and add description of tasks your router performs and send all of that to support@mikrotik.com
normis
Thu May 17, 2012 11:45 am
Upgrade to v5.16, some important changes happened between these versions.
OrCAD
Sat Jun 02, 2012 8:58 pm
many Kernel Failure every days... with ROS 5.17 and all interface Queue in only-hardware-queue
rapid solution is welcome.
Thanks in advance..
MTCNA - MTCRE - MTCTCE - MTCINE
ste
AW: Mikrotik: RouterBoard RB1100AHx2 - CRASH
Sun Jun 03, 2012 12:30 am
Try to use only port1-10. We see problems with the upper ports.
OrCAD
Sun Jun 03, 2012 5:06 pm
I've disabled ether13, now is 24h not stop...
I hope MikroTik engineer can be made stable this router.
Thanks..
c0d3rSh3ll
Long time Member
Long time Member
Mon Jun 04, 2012 12:42 am
reinstall RouterOS 5.16 with netinstall
I had a similar problem and was solved witn netinstall.
nothing
OrCAD
Mon Jun 04, 2012 5:17 pm
48h and don't stop (with ether13 disabled)
maximoraban
Tue Jun 05, 2012 5:35 am
yes rb1100ahx2 crash pppoe client, please solution...............
mistiq
Mon Aug 20, 2012 12:14 pm
Similar problem in a lot of RB1100AHx2.
admin@MSK_1100AH2_GW00_1] > system routerboard print
       routerboard: yes
             model: 1100AHx2
     serial-number: 319E02C82211
  current-firmware:
  upgrade-firmware: 2.39
[admin@MSK_1100AH2_GW00_1] /file> print
 # NAME        TYPE        SIZE CREATION-TIME
 0 skins        directory        jan/01/1970 04:01:40
 1 pub        directory        jun/18/2012 11:46:56
 2 routeros-powerpc-5.19.npk        package        18 068 470 aug/20/2012 06:18:09
 3 autosupout.old.rif        .rif file        332 786 jan/02/1970 04:00:41
 4 autosupout.rif
Upgrade to 5.19 are failed.
In logs:
(130 messages not shown)
jan/02/1970 03:00:02 system,error,critical System rebooted because of kernel failu
re
re
aug/20/2012 11:42:02 system,error,critical login failure for user root from 95.31.
12.61 via ssh
aug/20/2012 11:42:04 system,error,critical login failure for user root from 95.31.
12.61 via ssh
re
re
re
re
I have similar problem in different party of RB1100AHx2.
I have a solution to fix this problem?
K.i.s.S.
normis
Mon Aug 20, 2012 1:01 pm
You have encountered a kernel panic. Kernel panics can be caused by many things, it doesn't mean your problem is similar. Please contact mikrotik support (support@mikrotik.com) with your supout.rif file. We will see what caused the kernel panic. Some times this can even be caused by non standard configuration.
saaremaa
Tue Aug 28, 2012 11:04 pm
Similar problem with RB1100 ROS 5.20. After change Queue Type on QOS Tree to "only hardware queue" RB go to kernel panic. :(
CMDR Saaremaa (Gutamaya Sierra Alpha Alpha)
ponko
Fri Sep 28, 2012 4:38 pm
Similar Problem.... there no Fix with Kernel Failure??
Or Any Solution....
My Ticket : Ticket#2012092466000838
Users browsing this forum: Bing [Bot] and 24 guests
