MUM Europe 2020
wh450g
"All in one" box possible?
Tue May 22, 2012 5:36 pm
I'm trying to build a solution for my testlab with the following option:
- run as a WLAN client to the outside
- run WLAN AP on the inside
- hide nat outgoing traffic
- span (mirror this traffic to a wired interface)
(troughput speed is not an issue)
(e.g. running a network 192.168.1.0/24 on the inside on WLAN and 2 wired ports, and span the traffic to the 3rd wired port. The second WLAN miniPCI card should connect to the internet, a hotel hostspot for example)
My understanding right now, this should be possible. A routerboard 433, equipped with 2 x miniPCI WLAN cards should do this, or am i wrong?
thanks,
Wolfgang
taduikis
Re: "All in one" box possible?
Tue May 22, 2012 6:39 pm
Yep, you're right. 433 is perfect for that. If you need more ports - 493 then.
wh450g
Tue May 22, 2012 7:02 pm
Great!
Can someone confirm that i"m able to mirror traffic from the two WLAN ports and one wired port to a single wired port?
Or are they some restrictions?
Thanks!
wh450g
Wed May 23, 2012 3:53 pm
Hmm, does anyone know whether one can mirror traffic from a miniPCI WLAN card to one of the wired ports on a RB433?
I have not found a description for this, just for mirroring a wired port.
Thanks, Wolfgang
GuJack20
Trainer
Trainer
Thu May 24, 2012 1:23 pm
What do you mean by "mirroring"? Normally everything is possible
--Do you remember that guy who gave up? Neither does anybody else!
wh450g
Sun May 27, 2012 10:36 pm
Mirroring (or span) -> duplicating the traffic from one ( or more ) interface to another (e.g. to analyse the traffic)
kirshteins
Mon May 28, 2012 8:58 am
It is not possible to mirror traffic from Wlan port to ethernet port. You can mirror traffic between switch chip:
http://wiki.mikrotik.com/wiki/Switch_Ch ... troduction
http://wiki.mikrotik.com/wiki/Switch_Ch ... _Mirroring
If you are routing or bridging traffic from Wlan interface to ethernet interface of the switch chip, you can mirror this traffic to another ethernet interface.
normis
Mon May 28, 2012 10:40 am
Can't you use CALEA? It will mirror all traffic to another RouterOS machine (CALEA server):
http://wiki.mikrotik.com/wiki/CALEA
Use TZSP format - for reception with Wireshark.
Users browsing this forum: No registered users and 36 guests
