MUM Europe 2020
plisken
remove switch modus
Wed May 23, 2012 7:49 pm
How can i remove switch modus on rb 493AH
kirshteins
Re: remove switch modus
Thu May 24, 2012 9:30 am
What do you mean by "switch modus"? By default RB493AH ports are not switched.
GuJack20
Trainer
Trainer
Thu May 24, 2012 1:17 pm
Maybe he is asking for the "switch chip".
No you can't remove it, but you can remove the switched ports from configuration through the winbox interface or CLI
--Do you remember that guy who gave up? Neither does anybody else!
plisken
Thu May 24, 2012 6:19 pm
Thanks for your answers.
sorry is the routerboard 493 Ah with gigabit ports
After reset the routerboard and remove basic configuration
see i that switch mode is enabled.
But i want routeren not switch.
Greatings
Plisken
GuJack20
Trainer
Trainer
Thu May 24, 2012 10:38 pm
No, the 493 has 10/100mbit ports, the 493G instead has gigabit ports.
You can always reset the config with
/system reset-configuration
And if when the system boots show a mesage to remove config, just remove it, and the router will be clean as a baby :)
plisken
Fri May 25, 2012 6:13 am
i have done, system reset-configuration
the switch mode stay enabled
Tnx fot reply
kirshteins
Fri May 25, 2012 8:05 am
Switching mode is configured by setting master-port. If master is not set there is no switching.
Users browsing this forum: No registered users and 12 guests
