MUM Europe 2020
braidiano
PPPoE on central router OR on each tower
Tue May 29, 2012 2:10 pm
do you have the PPPoE server (NAS) at a central router in your NOC, or a small one to each tower? What are the pros and cos?
I think that is better to a central place, so you have 1 point for authenticate the user and do traffic logging.
The CONS are:
1) you have to encapsulate the traffic from each tower to the NOC on the PPPoE Tunnel, so QoS are more difficult.
2) you have to route much more big packet (EoIP or VPLS) to route L2 from each tower to NOC, because the pppoe works on L2
any other opinion?
wildbill442
Re: PPPoE on central router OR on each tower
Thu May 31, 2012 12:46 am
Currently we have centrally located NAS/PPPoE servers (we have multiple) and it works well. I'm looking at pushing them further out into the network and using OSPF for the core/distribution layer of the network and using PPPoE to handle the access layer. That way it's just layer 2 from the AP to the customer, and routed layer 3 the rest of the way.
Makes it easy for failover and load balancing across links using a dynamic routing protocol like OSPF vs trying to bond or use other layer 2 protocols to accomplish the same thing.
William Burnett
Network Engineer
braidiano
Thu May 31, 2012 7:46 pm
I agree. Now I'm the same architecture. I want to move to a full routed layer 3. I'm looking for a way (if exists) to distribute the public IPs from the central POP. If you use OSPF i think you have to segment the IP class and route a single segment to each AP/Tower (wasting some IPs.).
wildbill442
Thu May 31, 2012 10:54 pm
You could use a central based NAS and run MLPS on top of the OSPF network and tunnel the traffic back to the central NAS ...
I've seen a few posts of people doing this, I'm not sure what the impacts from added overhead are... but it's one way to have your cake and eat it too.
Also look into /32 routing (similar to Cisco's unnumbered interfaces)... I use those instead of /30's to eliminate wasted IP's for PTP links.
William Burnett
Network Engineer
riggerman
Thu May 31, 2012 11:43 pm
Hi There,
While both methods are certainly possible we typically use the following rule of thumb when providing our consulting as part of our core network platforms (http://www.neology.co.za).
Relevant to Both
  • Have a decent monitoring platform and make sure it dials you PPPoE platforms to ensure its running
  • Move your AAA to the core - this allows for effective billing and IP block allocations
  • Make sure you plan your subnetting/IP allocations and use an intelligent Radius (AAA) to do this - allocate IPs from correct pools based on customer sites etc
  • Think about inter-customer traffic - do you want to keep 'edge' customer away from your precious backhauls - do you plan to offer end-to-end VPNs for customers (and should this traverse your core
  • Dynamic Routing protocols for the win - but try not to have too much flapping going on (more on this later)
Centralised
  • Appropriate during initial stages with a few sites or in situations where remote sites are possibly prone to vandalism or theft
  • If limited field staff are available centralising makes is easier to fix/maintain
  • If the backhaul is not your own you may have limited VLAN/MTU/privacy and want to encapsulate all traffic
  • Inbound traffic that you wish to block (eg torrents) get stopped at the core - instead of pushing all the way down to the edge sites
  • Two customers on same tower would have to backhaul all the way to the core to communicate - not ideal if that often happens
  • Single point of failure - but you can build some decent resilliance/failover if you are decently monitoring and AAA
MultiSite/Distributed
  • Each individual site is self-contained meaning customer sessions terminate close to the customer
  • Bandwidth management, QoS tagging etc can be done at the edge
  • Inter customer traffic does not have to go to the core - depends on your routing architecture
  • If a all backhauls fail the customer may be left with a connected system but no internet - script and redirect customers on failures
  • Multiple internet breakouts can be effectively used
  • A customer that sees multiple towers can fail over in case of a failure on one highsite
Routing and architecture comments
  • Would recommend OSPF only for the connected backhaul links
  • iBGP between sites internally
  • Configure subnets/aggregates based on site locations to keep the entries required to a minimum
  • Consider MPLS if you want to do backhaul hiding and some nice engineering
  • Keep in mind that any tunnels you build adds overhead and potentially adversely affects performance
Hope this provides some food for thought. Maybe a last link of relevance from one of my business partners regarding the value of PPP (TheRodent) - Open Access Networks, or “PPP” is not dead
Regardt
braidiano
Fri Jun 01, 2012 3:18 pm
can you point me to some documentation about how to manage /32 routes in RouterOS ?
I'm using this via EoIP PtP link between tower and NAS, but I have much overhead in latency and fragmentation (the latency is like 2ms over the wireless link and 60ms inside the EoIP tunnel over the same wireless link). I have to give a try to VPLS, maybe it is better than EoIP.
It is a very interesting approach. Does the network is running now, or is it a closed project?
wildbill442
Fri Jun 01, 2012 10:19 pm
/32 -- http://wiki.mikrotik.com/wiki/Manual:In ... _addresses
I've heard VPLS is much faster in comparison to EoIP. Haven't played with it much, but again I've seen a lot of good things about it on these forums.
William Burnett
Network Engineer
n21roadie
Sat Jun 02, 2012 5:05 pm
Question - I am using /30 on my PTP's and OSPF, how do i use /32 address + Ospf network config ?
example
PTP side one
address=10.100.0.21/30 interface=wlan1 network=10.100.0.20
address=10.100.0.17/30 interface=ether1 network=10.100.0.16
/routing ospf network
area=backbone network=10.100.0.16/30
area=backbone network=10.100.0.20/30
PTP side two
address=10.100.0.22/30 interface=wlan1 network=10.100.0.20
address=10.100.0.25/30 interface=ether1 network=10.100.0.24
area=backbone network=10.100.0.24/30
N21roadie,
Network 100% MT for Now?
Luth
Sun Jun 10, 2012 11:18 pm
The CONS are:
any other opinion?
Have look to my recent post, you can see an architeture that provide vpls from tower to core (NOC). You can have two vpls from each tower to 2 centralized pppoeserver.
Thanks to ospf, the pubblic ip address assigned to pppoeclients are routed becouse there is another ospf annunce between routerboard with pppoe-server and routerboard (core router) that is linked to upstream internet provider with BGP transit.
So pubblic ip are always reachable and if one pppoe fault in automatic all pppoe-client connects to other pppoe-server and dynamic routing of ospf permit reachable!
I hope this help! Sorry for my poor english!
Bye,
Luciano
Luciano Talarico
TLCWEB Srl - Italy
Visit Mikrotik topics on our Linux by Myself website at linuxbms.com
davey
Wed Jan 31, 2018 7:28 pm
Hello Guys,
Resurrecting this old thread....I'm looking to carry my pppoe with ibgp. Anyone who's tried this? How do you summarize the /32s? I suppose redistribute connected routes into bgp and route filter what you don't want bgp to advertise. But then how to supernet the many /32s? Any help very much appreciated.
Aye!
Dave.
¦ MTCNA MTCRE MTCTCE MTCINE ¦ CCNA-RS CCNA-SEC CCNP-RS ¦ CWNA
shaoranrch
Fri Feb 02, 2018 5:49 pm
Hello Guys,
Aye!
Dave.
I'd not use redistribution, if you planned well the allocations per tower/site you could do something like this:
1.- Create a blackhole to the subnet allocated to the site (say it's 172.16.0.0/24)
ip route add type=blackhole dst-address=172.16.0.0/24
or
(optional, but suggested) tag your 172.16.0.0/24 prefix with a community representing where it is, so you can filter or do other neat things with it in the future
ip route add type=blackhole dst-address=172.16.0.0/24 bgp-communities=XXX:XXXXX
2.- Then publish this route using BGP
routing bgp network add network=172.16.0.0/24 synchronize=yes
3.- Make your customers get a /32 from this subnet and don't redistribute anything
This way your network only sees a /24, and the site itself is the only one seeing /32s. When traffic reaches the router on the site, if there's no /32 active (meaning no customer active using that IP) the router will just blackhole the packet (discard it)
Rafael Carvallo
Telecommunications Engineer
Need consultation?
Need a hotspot with facebook integration?
Send a PM!
Hablamos español, atendemos el mercado de latinoamérica visita nuestra página web:
http://www.tuproximosalto.com
sri2007
Fri Feb 02, 2018 9:40 pm
Hello, from my experience the best way of doing this is by handling PPPoE Servers on each tower, but it really depends the amount of subscribers, because if you're trying to queueing 2000 of subscribers per router, then it'll experiment some high cpu peaks in a massive event (as example, some providers used to increase the bandwidth at midnight), but on the other hand, it's easiest to admin a CORE PPPoE server than severals PPPoE servers.
MikroTik Soporte y Consultoría - Español / English +593 98 709 3502
https://www.safenet.ec/consultoria.html/ soporte@safenet.ec
Users browsing this forum: sjdurand and 7 guests
