MUM Europe 2020
normis
RouterOS v5.17 released
Wed May 30, 2012 2:11 pm
What's new in 5.17 (2012-May-28 12:34):
*) files - fixed problem when directories disappeared after reboot on usb or sd flash;
*) webfig - make QuickSet scan list work in Firefox v12;
*) webfig - fixed problem in QuickSet when changing country or channel-width in AP
mode would enable NV2 protocol;
*) webfig - fixed skins when hiding first tab may make other tabs inaccessible;
*) winbox - fixed packet raw data view in packet sniffer;
*) winbox - fixed problem when router could be DoS attacked through winbox port;
*) ports - add option "/port firmware ignore-directip-modem"
which will ignore modems ip interface
and modem's serial ports will be made accessible to users;
*) ipv6 pool - allow pools with prefix equal to prefix length;
*) ping times improved on Nv2 high data rate wireless links;
*) tool email - added starttls option;
*) snmp - allow multiple ip ranges for each community;
*) serial console - added channel support;
http://www.mikrotik.com/download
For RB1xx and RB5xx users (Old MIPS-LE devices): Before upgrading RouterBOARD 1xx or 5xx series devices (MIPS-LE) to version >=5.17, please upgrade your RouterBOOT firmware by uploading one of the following files to your corresponding device, and issuing command "/system routerboard upgrade".
RB1xx: http://download2.mikrotik.com/adm5120-2.18.fwf, RB5xx: http://download2.mikrotik.com/rc32434-2.18.fwf
reza.mnp
Re: RouterOS v5.17 released
Wed May 30, 2012 2:49 pm
When IDS/IPS modules (snort , psad ,fwsnort or ..) will be added to ROS?
normis
Wed May 30, 2012 2:53 pm
Thanks for the suggestion. Currently we have no plans to add them to RouterOS v5, can you clarify what features are most important to you, and give some usage examples?
cbrown
Trainer
Trainer
Wed May 30, 2012 3:47 pm
Any news on Ticket#2012030866000601? I don't know if it is related to the RouterOS version or not.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
normis
Wed May 30, 2012 3:57 pm
sorry about not following up, we replied to your ticket. issue was in branding maker, and did not come from RouterOS
reza.mnp
Wed May 30, 2012 4:15 pm
with currently filter rule in ROS can detect and prevent some of attack like DOS and DDOS
http://forum.mikrotik.com/viewtopic.php?f=2&t=54607
i suggest add new future for detect and prevent malware and suspicious traffic and ... with pattern like snort database.
slech
Long time Member
Long time Member
Wed May 30, 2012 4:53 pm
Ticket#2012052166000431 ?
Email Notification about new version ?
Thanks.
sorry for my english
slech
Long time Member
Long time Member
Wed May 30, 2012 4:58 pm
Just as an FYI - recently on the unofficial IRC channel a Vyatta developer mentioned that IPS (i.e. snort) will be deprecated in the upcoming VC6.4 release and removed in the following release.
IDS was removed from Vyatta.
Optional IDS package in Mikrotik will be very good.
wirelesswaves
Wed May 30, 2012 5:53 pm
PLEASE EXPLAIN PROCESS CLEARER
"For RB1xx and RB5xx users (Old MIPS-LE devices): Before upgrading RouterBOARD 1xx or 5xx series devices (MIPS-LE) to version >=5.17, please upgrade your RouterBOOT firmware by uploading one of the following files to your corresponding device, and issuing command "/system routerboard upgrade".
RB1xx: http://download2.mikrotik.com/adm5120-2.18.fwf, RB5xx: http://download2.mikrotik.com/rc32434-2.18.fwf"
I put file in "filelist" directory, and then from terminal session do upgrade and reboot.
But the file remains in filelist and a "sys routerbpard pr" shows the original bootloader!
avantwireless
Wed May 30, 2012 7:41 pm
About le board firmware upgrade. I just checked a system running 5.16 and it's already running a 2.18 version of the firmware... Are we good to go or is there another revision that needs to be loaded and shouldn't it be 2.19?
Thanks...
normis
Wed May 30, 2012 8:56 pm
Thanks...
Yes, you are good to go. The notice is meant for devices, which are running 2.8 or older RouterBOOT
When you upload the FWF file, put it in the root level, not in a directory. Type "/system routerboard print" before upgrade command, and check if the current firmware and "upgrade firmware" are different. If yes - the file was detected correctly, and you can proceed with upgrade command.
MrYan
Wed May 30, 2012 9:45 pm
Doesn't appear to be a checkbox in Winbox for the email STARTTLS option though it is in the command line.
Matt.
c0d3rSh3ll
Long time Member
Long time Member
Thu May 31, 2012 12:34 am
I am testing my wireless signal, and I have a difference between 5.16 and 5.17.
nothing
normis
Thu May 31, 2012 7:55 am
c0d3rSh3ll, -22dBm signal is much too strong, you could be seeing problems. Try to decrease signal to around -55dBm, and the link will improve. One dBm signal change is very insignificant, it could be caused by change in atmospheric conditions, or other factor.
pateutz
Thu May 31, 2012 9:34 am
Hi all,
i have tested the issue " *) files - fixed problem when directories disappeared after reboot on usb or sd flash;" and it's really fixed.
Testing :
One HDD - 250GB ( defined as disks and shared using SMB) attached to the USB port of an RB751U-2HnD.
I have created an directory then copied an file inside that directory (using both protocols smb and ftp).
Restarted the router and the file remains where i have copied (using both protocols smb and ftp).
Thank you team great work.
Best Regards,
Daniel
elgo
Thu May 31, 2012 12:10 pm
Hourrayh!!
1 year to implement this (at least, I had no routerOS device before...)
I cant't wait 2013-2014 so we could end up seeing FQDN as smtp "server" option. Oh yeah.
RB450G - OpenWrt (so much more stable than with routerOS)
-> now: UBNT EdgeRouter Lite
(very unlikely to be MT customer again in the future)
honzam
Thu May 31, 2012 10:15 pm
Thanks...
I think that RouterBOOT 2.18 is the last for MIPSle. 2.19 for MIPSle never goes out?
Can we uninstall the package Routerboard to free more memory?
LAN, FTTx, Wireless. ISP operator
c0d3rSh3ll
Long time Member
Long time Member
Thu May 31, 2012 10:50 pm
but the ccq is 28% in 5.17 and ccq is 82% in 5.16
nothing
Chupaka
Thu May 31, 2012 11:51 pm
but decrease signal strength and look at CCQ
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
JorgeAmaral
Trainer
Trainer
Fri Jun 01, 2012 12:44 am
Hourrayh!!
/tool e-mail send server=[:resolve smtp.gmail.com] ...
taglio
Fri Jun 01, 2012 9:33 am
I've got a test link to try new thinks.
Signal is 70/70 TX/RX in the two chains. Radios are ubiquiti SR71-15. And the antennas are the wonderful Jirous JRC24 DUPLEX. Distance is ~15km. If you want more details i can give you radio mobile profile of the net.
Is a transparent link using WDS where i have got a couple of VLAN upon it.
NV2 in version <= 5.16 was TOTALLY unstable. latency and jitter simply do the link unusable.
With Nstreme enabled WITHOUT frame policy and whit polling i've got 100mbps send/receive and 50/50 both. Ping, latency and jitter is simply wonderful (1ms or 2).
I've upgraded to 5.17 to try the quoted feature. Now NV2 is true that it work better, also bandwidth test is more stable and powerful, i've got 130mbps send or receive and 65 both side. BUT this is the result of ping (BETTER THAN OTHERS VERSIONS):
X.X.X.233 56 64 4ms
X.X.X.233 56 64 10ms
X.X.X.233 56 64 34ms
X.X.X.233 56 64 27ms
X.X.X.233 56 64 26ms
X.X.X.233 56 64 9ms
X.X.X.233 56 64 25ms
X.X.X.233 56 64 8ms
X.X.X.233 56 64 4ms
X.X.X.233 56 64 23ms
X.X.X.233 56 64 19ms
Ok guys. With those results NV2 cannot be used in production environment. For me, and for anyone with a little bit of head, jitter and latency ARE MORE important than bandwidth.
Only to remark the difference with nstreme, this is the result:
X.X.X.233 56 64 1ms
X.X.X.233 56 64 1ms
X.X.X.233 56 64 1ms
X.X.X.233 56 64 1ms
X.X.X.233 56 64 1ms
sent=5 received=5 packet-loss=0% min-rtt=1ms avg-rtt=1ms max-rtt=1ms
.mhavoc world
ojsa
Fri Jun 01, 2012 11:05 am
Strange thing with "voucher generation" and "reports" under user manager. Downgraded to 5.16 solved the problem.
It seems that the report url is something like "http://192.168.31.254/userman?serviceId=UMT.Report" on 5.16 and working, but if I remember correct on 5.17 its more like "http://192.168.31.254/user?serviceId=UMT.Report", the same goes for the "voucher generation"
Running on RB751G, can make a support file AFTER my MTCUME exam today ;-)
Network professional - Certified MTCNA, MTCWE MTCTCE, MTCRE, MTCUME and MTCINE. - Wiki Profile
karina
Fri Jun 01, 2012 7:03 pm
Just installed 5.17 into my 750G. got 100% CPU usage. Checked Resources and My CPU clock speed has dropped to 100mhz ???????
mxmxmxmxmx
Fri Jun 01, 2012 7:27 pm
I have issue with graphing tool in winbox only with resources. RB433AH 5.17.
Interface graphing in winbox is OK. On www everything is OK. Every resource in winbox is 1px high.
karina
Fri Jun 01, 2012 8:01 pm
ok after reading a few posts, i have reset the cpu back to 680mhz and all is fine again.
One to watch there. Somehow the upgrade to 5.17 reset the CPU back to 100mhz RB750G was on 5.3
Chupaka
Fri Jun 01, 2012 10:04 pm
CPU graphing is broken since at least v3
I don't know why they don't fix it :)
NetworkPro
Sat Jun 02, 2012 7:35 am
:lol: yeah I know right, Funny.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
jandafields
Sat Jun 02, 2012 6:46 pm
Aren't these "version release" posts normally stickied? It still shows 5.16 at the top of the forum.
daviddem
Mon Jun 04, 2012 10:00 am
good stuff, hopefully this fixes the disappearing micro-sd cards: http://forum.mikrotik.com/viewtopic.php?f=13&t=46144, will give it a go.
I sent a detailed bug report about this problem a few months back, but other users had been complaining about it for a long time.
elgo
Tue Jun 05, 2012 12:27 pm
Totally irrelevant and useless.
Unless you think people usually fills this field with a random IP address for fun? :shock:
sergejs
Wed Jun 06, 2012 8:52 am
mxmxmxmxmx, thank you very much for the report, we will try to fix the problem in the next RouterOS version.
WirelessRudy
Wed Jun 06, 2012 11:26 am
What happened with e-mail notification of new versions? It's only its mentioned in another post that I became aware this new version is out... its the 6th of June now.... :(
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
WirelessRudy
Wed Jun 06, 2012 11:38 am
What is exactly done to improve the ping times? A bit more technical background on what has actually done by technicians would be helpful to understand how and when this help ping times and if I really need this upgrade.
Does it mean the link as a whole is improved? Or is icmp protocol filtered and given high priority?
ping is only a package, so if ping is improved are other packages traffic improved too? If only ping is improved than that's useless. Ping is used to see how a link performs. If ping now is stable where the rest of the link still would suffer latency and jitter the tool is useless and I see no reason for this improvement if only gimmick.
Please an explanation.
Rudy R. Puister
uldis
Thu Jun 07, 2012 9:54 am
The Nv2 rate tx algorithm has been tuned to support better ping times.
karlos
Thu Jun 07, 2012 10:24 am
I agree, the ping time are better on interfaces with some moderate traffic. But still very big jitter, when with very low or no traffic. But this is the problem with waiting for some data to send just one big packet istead of few smaller.
I can also agree to improovments on stabilising transfer rates and speeds. It does not improove the maximum trafer rate too much, but it seems to be more stable, so more predictable version to version.
ohara
Thu Jun 07, 2012 11:21 am
In ptmp is it essential to upgrade both AP and stations to 5.17 to take full advantage of the benefit? Or is it enough to upgrade either AP or CPE only?
WirelessRudy
Thu Jun 07, 2012 11:32 am
I hope this means this helps latency and jitter as a whole. Ping is only a measurement tool.
Rudy R. Puister
petrn
Fri Jun 08, 2012 3:14 pm
Vyatta FAQ states reason:
http://www.vyatta.com/files/pdfs/Vyatta ... _Final.pdf - performance, stability and need for frequent updates, IPS/IDS requires quite a lot CPU/memory so i can imagine to have it on new 36-core routerboard platform, but definately not on current boards. And if you need to run RouterOS on x86, then another box running just IPS/IDS is better idea.
Petr
omidkosari
Trainer
Trainer
Sat Jun 09, 2012 11:38 am
What happened to following ticket
[Ticket#2012033166000201] remote-ipv6-prefix-pool problem with pppoe
Nobody replies in mikrotik support . good time for sleep :lol:
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
weber
Mon Jun 11, 2012 11:41 am
Added a new static DNS entry and it appeared as regexp.
Why is it? As you can see the old ones are not regexp.
sergejs
Tue Jun 12, 2012 3:40 pm
weber, please post your /ip dns export compact.
omidkosari, I will check what is wrong with your ticked and why you didn't get reply.
weber
Wed Jun 13, 2012 1:55 pm
sergejs, it is strange but it's ok now. Probably, webfig/browser cache issue...
omidkosari
Trainer
Trainer
Thu Jun 14, 2012 6:21 pm
Thanks . Still waiting :wink:
synnest
Mon Jun 18, 2012 5:23 pm
had no problems with 5.17 on 700-series but also tried it on a rb493 - it totally screwed switch setup, also wan throughput went almost to 0, downgrading to 5.16 solved the problem, now I'm afraid to use it on 493 series (and I have a lot of them)
edit: switch setup was - eth3-eth8 - masterport eth2, eth2 in bridge1, vlan id=2 on bridge1, eth9 in bridge2, ros5.17 didn't allow eth2 in bridge1 and disabled it, after removing masterport from eth3-eth8 and adding eth2-eth8 to bridge1 wan throughput went to 0
mxmxmxmxmx
Tue Jan 15, 2013 1:51 am
Which version fixed it?!
sergejs
Tue Jan 15, 2013 3:18 pm
v6.x has fix for the problem.
5.23 version will have fix for Winbox graphs menu.
mxmxmxmxmx
Thu Jan 17, 2013 3:32 pm
:) I've asked which version fixED it, because it is already working on 5.22!! :)
Edit: 5.21 doesn't work; 5.22>>works fine, so i've got my answer.
sergejs
So it means 5.22 fixed it.
Users browsing this forum: Google [Bot], matze1708, Spotegg, Zacharias and 94 guests
