nosovk
Feature Request: WINS Server
Mon Jun 11, 2012 12:24 pm
It would be good idea to add WINS server in ROS, it will boost small office networks.
Now you need to make metarouter from openwrt to create wins server on ros. It's not easy and buggy way.
Campano
Re: Feature Request: WINS Server
Mon Jul 16, 2012 6:34 pm
I like that idea :D +1
Defensor
Mon Jul 16, 2012 9:21 pm
+1 It's a very useful thing.
Sanity
Wed Jul 18, 2012 12:06 am
-1. Not needed anymore? Is there any case where a decently modern windows still falls back to WINS?
nosovk
Sat Jan 18, 2025 5:08 pm
Unfortunately yes. For example if you merge different office locations within OSPF over p2p wire guard links. In that case you have different networks in most cases, and to get for SMB share, printers etc to live across offices you still have to rely on WINS.
Larsa
Sat Jan 18, 2025 5:37 pm
WINS is a 31-year-old, obsolete Microsoft legacy service and an implementation of the NetBIOS Name Service (NBNS) that was needed for MS Windows 95 and earlier versions. Starting with Windows XP in 2001, newer versions switched to using DNS, so WINS isn’t really necessary anymore.
Since it’s no longer supported, Microsoft recommends decommissioning WINS: https://learn.microsoft.com/en-us/windo ... s/wins-top
Amm0
Sat Jan 18, 2025 7:40 pm
Or use Active Directory (either MS or Samba). If it's just browsing file shares and printers, you should be able to use a GRE or EoIP tunnel over your WG P2P links, and enable Mikrotik's newer /ip/dns's mDNS repeater over GRE.
Now, ideally, you'd be able to make static entries for DNS-SD - which also allow SMB browsing – but Mikrotik's DNS server does not support static PTR records, which are need for "static mDNS" (which is called DNS-SD). But DNS-SD records in DNS server is actually more similar to WINS's LMHOSTS approach - but that isn't an option.
ConradPino
Sat Jan 18, 2025 7:47 pm
Cosnider Active Directory, Domain Master Browser service.
https://en.wikipedia.org/wiki/Domain_Master_Browser
Larsa
Sat Jan 18, 2025 10:11 pm
FWIW, one should at least be aware that WINS has several security vulnerabilities that Microsoft hasn’t and won’t patch. If possible, I’d avoid WINS altogether.
That said, it’s possible to run WINS in parallel while implementing IP-based name resolution using, for example, Samba as an Active Directory Domain Controller or Microsoft Active Directory Domain Services (AD DS)
