MUM Europe 2020
harisagars
5.8ghz Access point Configuration Solution
Mon Jun 18, 2012 4:50 pm
Dear all
i am new to mikrotik i used Rb411AH Board in 2.4 ghz with tplinks as clients and i need help in 5.8ghz band i Want u use Rb411Ah board as AP with R52 card and client is Rb411 with R52 card as client with 24 dbi external antenna so pls help me in configuration of 5.8ghz access point configuration
sorry for my poor english
gcs
Re: 5.8ghz Access point Configuration Solution
Mon Jun 18, 2012 10:22 pm
what version of ROS are you using? There is a quick comfiguration since 5.11 I think. It is good. Try it. It will ask for most of your settings.
harisagars
Tue Jun 19, 2012 6:23 am
router os version is 2.9.38 is and more to upgradable is up to 3x
gcs
Tue Jun 19, 2012 5:00 pm
first I would upgrade to 3.30 that was a good version. if your license will allow go to 4.17. after you upgrade reply and we will see about helping you configure.
harisagars
Tue Jun 19, 2012 5:15 pm
Thanks for your reply but its upgradable upto v3x only
gcs
Tue Jun 19, 2012 5:18 pm
ok upgrade to 3.30
Users browsing this forum: bolean, mbovenka, uldise and 21 guests
