helium
web proxy
Tue Jan 10, 2006 12:11 am
Holla.
I'm trying to configure transparent proxy on mikrotik 2.9.6 but problem persist. Should someone can tell me about dest-nat config. Did i put in in-interface LAN/WAN eth.? Manual is pretty confusing...
cibernet
Long time Member
Long time Member
Wed Jan 11, 2006 1:27 am
Just add this:
add chain=dstnat src-address=(your network) protocol=tcp dst-port=80 action=redirect to-ports=(webproxy port)
ajmal
Thu Jan 12, 2006 10:50 am
FIrst you set webproxy port you may keep it 80 or 8088 etc
if you have defined port 80 add following code-
add chain=dstnat src-address=(your network) protocol=tcp dst-port=80 action=redirect to-ports=80
and if you have defined port 80 add following code-
add chain=dstnat src-address=(your network) protocol=tcp dst-port=80 action=redirect to-ports=8088
helium
Mon Feb 06, 2006 9:21 pm
tnx.
I want to set firewall rule to outbound interface, with that i want to secure webproxy server from trying using a connection (to cut secrvice on lower level).
Something like Chain: INPUT, Protocol: TCP, src Port: 8080, Action:DROP In Interface: PUBLIC
is it ok?
cibernet
Long time Member
Long time Member
Mon Feb 06, 2006 10:17 pm
tnx.
is it ok?
Use proxy access lists..
Regards
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
helium
Mon Feb 06, 2006 10:28 pm
Problem is when i using webproxy ACL i can get:
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: http://www.google.com/
The following error was encountered:
* Access Denied.
Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect.
Your cache administrator is webmaster.
i wont to secure webproxy to doesent get that page!
cibernet
Long time Member
Long time Member
Mon Feb 06, 2006 10:34 pm
ERROR
* Access Denied.
Thats because you have to allow acces to your network first...
Regards
José Ignacio Acosta
Mikronet
Users browsing this forum: Bing [Bot], CTassisF, Google [Bot], kd2pm2, wichets and 134 guests
