tbutcher
EoIP Problem
Wed Jan 11, 2006 9:07 pm
I have created an EoIP tunnel between an x86 router and a Routerboard router. They have different MACs but the same tunnel ID and I have assigned an IP to each tunnel. Both router can ping each other on the external address but can ping each other using the tunnel address. I see TX packets on the Routerboard when i try and ping but no RX packets. On the x86 router there is no TX or RX packets when pinging.
I have successfully created a PPTP connection so I know the firewalls are open for GRE.
Does any anybody have EoIP working on 2.9.10? Also how can I tell if the tunnel is successfully connected?
Tim
tbutcher
Thu Jan 12, 2006 7:20 pm
Is nobody using EoIP?
Tim
YazzY
Fri Jan 13, 2006 12:49 pm
Yeah, it's a simple tap interface that Mikrotik renamed to make it easier to understand the purpose of it. The same goes to IPIP which is a tun iface.
EoIP allways worked for me.
Did you check your input chains ?
HarvSki
Fri Jan 13, 2006 12:55 pm
I've been having trouble with EoIP, it would be good to have a status indicator to know if it is running correctly or at least something in the log.
YazzY
Fri Jan 13, 2006 12:56 pm
What RouterOS version(s) are you using on the peers?
HarvSki
Fri Jan 13, 2006 1:11 pm
I've had issues with it on 2.8.28 and 2.9.x
YazzY
Fri Jan 13, 2006 1:14 pm
Allways on the same hardware or did you try to switch your nics etc and see how it acts?
tbutcher
Fri Jan 13, 2006 8:28 pm
I have tried plugging the router together and still I can't ping using the EoIP tunnel. Do you need a certain NIC to support EoIP like you do for VLAN?
Tim
tbutcher
Sat Jan 14, 2006 12:30 am
Ok I have fixed the problem. I was dropping invalid packets, when I disabled the firewall EoIP started working as expected.
Thanks.
Tim
YazzY
Sat Jan 14, 2006 2:20 am
That's exactly what I told you to do in my first answer.
I am glad you solved it, good luck.
HarvSki
Tue Jan 17, 2006 2:15 am
Tim
Can you check http://wiki.mikrotik.com/wiki/EoIP and see if I got it right - updated it if it is wrong. We are getting some real gems of info here in Prague but forgot to ask about this one yet
:D
Harv
tbutcher
Tue Jan 17, 2006 10:47 am
The instructions look fine but I suggest you add a note that if you drop invalid connections on your firewall it will not work. Drop invalid connections is recommend in the FAQ on "Securing your router" so I expect quite a few people will be doing it.
Tim
Users browsing this forum: Majestic-12 [Bot] and 147 guests
