ofasa
New Features in 2.9.11
Wed Jan 11, 2006 10:19 pm
Can someone please explain this? (What's trial user support?)
*) added complementary Hotspot feature (trial user support);
How do we use this?
*) added priority and min-rate fields in rate-limit attribute for
Hotspot, PPP and DHCP;
Thanks a lot.
aviper
Wed Jan 11, 2006 10:55 pm
Another Q:
*) updated RTL8169 driver;
Is it working now? :) (VLAN tested?)
*) added ability to enable & disable installed packages;
GREAT ! Now we can use Wireless and Wireless-test and switch between them with one reboot ?
*) test packages included in big upgrade package - each requires enabling to use;
This answers my Q :)
P.S. How often is ROS Documentation refreshed ?
Document revision: 3.2 (December 27 2005) <- Okey I found the A alone :). I must SEARCH before ASK :)
jarosoup
Long time Member
Long time Member
Thu Jan 12, 2006 1:12 am
What's new in 2.9.11:
*) added hotspot active users list to snmp;
Thank you, thank you, thank you. This addition is greatly appreciated! 8) One less script we have to run now.
I'd like to add a request for additional SNMP features for a future release: firewall connection count, dhcp lease count, and ip neighbor count. Keep up the good work!
ofasa
Re: New Features in 2.9.11
Thu Jan 12, 2006 2:16 pm
How do we use this?
After experimenting:
64k/64k 256k/256k 128k/128k 10/10 6 32k/32k - rx/tx-max-limit=64000, rx/tx-burst-rate=256000, rx/tx-burst-threshold=128000, rx/tx-burst-time=10s priority=6 rx/tx-limit-at=32000
Hope I'm right!
normis
Thu Jan 12, 2006 2:25 pm
if you enable this thing, it will allow hotspot users to try hotspot without entering login and password. more on this in the MUM
ofasa
Thu Jan 12, 2006 2:28 pm
Thanks. I see it now!
Alex
Thu Jan 12, 2006 3:05 pm
and what about updated RTL8169 driver? in documentation i found this:
Chipset type: RealTek RTL8169 PCI 10/100/1000Base
Compatibility:
RealTek RTL8169 Gigabit Ethernet (not recommended: may lock up the router)
normis
Thu Jan 12, 2006 4:17 pm
documentation is not updated yet
Freman
Fri Jan 13, 2006 8:32 am
What is the base mib for this? I've done a snmpwalk on my hotspot (it only has one user logged in) and it doesn't show up
glw9097
Mon Jan 23, 2006 5:24 pm
Could someone explain how to use this feature? Any help would be greatly appreciated.
Thanks,
Greg
Users browsing this forum: Bing [Bot], emblaze and 161 guests
