lemons
Locked out of router. Ethernet disabled...on roof..
Thu Jul 12, 2012 4:12 pm
Hiya,
OK laugh all you want, but I manage to disable the ethernet interface via the Winbox tool. My router is HIGH up on my roof in a sealed weatherproof housing.
I've tried to connect to the MAC address with Winbox, no luck. Suspect that interface is.. wait...disabled. Is there ANY way I don't need to climb onto the roof, open
the sealed box and do some form of hardware reset? It would help a LOT. I've tried power off/on.
Sorry for the sillyness. But ya, had the wrong interface selected - I am sure everyone have had that sinking feeling when your shell/GUI just freeze and you know you just screwed up big time.
Thanks,
Lemons.
janisk
Re: Locked out of router. Ethernet disabled...on roof..
Fri Jul 13, 2012 12:03 pm
does your configuration allow connections on any other interface? Like - through wifi neighbour?
SurferTim
Fri Jul 13, 2012 3:00 pm
I usually use the firewall to lock myself out, but this works with disabling interfaces also. This is what I do. The order is important!
1) I curse loudly.
2) I kick something inanimate real hard.
3) I curse again when the searing pain rushes up my leg.
4) I get my laptop and null-modem cable, then limp to my car.
The rest I bet you can guess.
I wish I had a better solution for you.
FIPTech
Sun Jul 15, 2012 1:29 pm
For critical routers, those that must never go down more than a couple minutes, even if you do a mistake, or those located on very high towers / roof use a router with a serial port available on it. Then wire a cable to this serial port so that you don't have to go on the roof, and use that for correcting your errors. You can use a serial port server, connected by Ethernet to another network. You can as well connect a GSM modem on the serial port, and use that remotely. You'll need to pay for a M2M GSM subscription, but for critical routers this is sometimes not a problem.
A good and simpler solution is to use safe mode, so that if you accendentally disable an interface or something like this, it will magically come back if the Winbox connexion is lost. This is enough in most cases. Always use safe mode when working on remote routers, and always make a configuration backup before to begin your work, so that you can restore on another router if something goes very wrong. This will save a lot of time on location where you will just need to replace the router with another one already configured in case of problem.
Another tip is to try to always have at least two interfaces available for configuration, so that if something goes wrong with the first one, you can enter with the second one. Acessing the router through a Local Loopback router address is better, because if the interface you are connected through goes down, dynamic routing (if you have that on your network) will magically reconnected you in a couple seconds through another interface, and you should not even see a Winbox session drop.
There are some rare situations, like when playing with Metarouters, where the router can fully crash with 100% CPU load. In this case it is possible to loose access even after reboot. The only way to get back connectivity is sometimes a hardware reset in those rare cases. Even the watchdog could do nothing for you in those situations. I experienced that a couple days ago, with version 5.18, trying to reduce the memory allocated to a metarouter instance on a RB750... Obviously this was a terrible idea :=) and i ended in removing the right rear RB750 pad to access the hard reset jumper... I should have read the manual saying that a Metarouter instance needs 16 MBytes minimum :=)
n21roadie
Sun Jul 15, 2012 4:06 pm
After a bad experience with OS 4.X series where a router given a instruction to reboot, shutdown instead which resulted in a long drive to site to restart the device, ever since then I install a power relay circuit switchable by GSM text to disconnect and reconnect the dc power to the routerboards also the relay circuit texts when there is a AC power outage and I have timed the duration of the batteries which if a text for AC power restored is not received I go to that site before batteries discharge.
N21roadie,
Network 100% MT for Now?
adairw
Sun Jul 15, 2012 5:25 pm
+1 for safe mode and loopback address!
FIPTech
Sun Jul 15, 2012 6:01 pm
Thanks for your +1 but i don't see it on my Karma :=(
mahnet
Long time Member
Long time Member
Sun Jul 15, 2012 7:09 pm
as of now the best bet would be what janisk said. Try to connect thru the wireless interface i hope u havent disabled that as well.
Or be prepared to go up on the roof......
adairw
Sorry can't add karma from tapatalk.
Ill be around a browser later.
Users browsing this forum: NavedMalik, sindy, subanartneha and 60 guests
