NathanA
Forum Veteran
Forum Veteran
High-resolution Winbox icon
Fri Aug 10, 2012 10:46 am
Hey guys,
Could you possibly render and make available a high-resolution (512x512, say) version of the current blue spherical Winbox icon? The largest icon size embedded in winbox.exe is 48x48, and that icon looks terrible (blocky) on the Retina MacBook. ;)
-- Nathan
normis
Re: High-resolution Winbox icon
Fri Aug 10, 2012 10:55 am
Try this one. Don't have larger one.
NathanA
Forum Veteran
Forum Veteran
Fri Aug 10, 2012 11:05 am
That looks awesome! Thanks!
-- Nathan
EDIT: There is some kind of funny dithering that got applied to the included ICNS version of the image...almost like it was reduced to 8-bit color. So I took the original PNG and re-converted it, and this attached one looks better. Hope this helps!
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 22 guests
