MUM Europe 2020
uldis
v5.20 released
Wed Aug 15, 2012 5:30 pm
http://www.mikrotik.com/download
What's new in 5.20 (2012-Aug-15 13:04):
*) manual upgrade to NEW beta poe controller firmware v2.0 for RB750UP and OmniTIK UPA;
more info at http://wiki.mikrotik.com/wiki/Manual:PoE-Out
*) fix RB951-2n wireless issues;
*) ups - fixed resource leak;
slech
Long time Member
Long time Member
Re: v5.20 released
Wed Aug 15, 2012 7:49 pm
uldis
PPP CPU Load ?
Still have an issue with reboot of RB751 - Ticket#2012080166000114] RB751U-2HnD - Reboot
sorry for my english
Polky
Re: v5.20 released
Wed Aug 15, 2012 9:25 pm
Now that's funny. NV2 nothing. Migrate to the Airmax UBNT. Clients will not wait
honzam
Re: v5.20 released
Wed Aug 15, 2012 11:12 pm
I hope for NV2 changes, but nothing. :( :(
LAN, FTTx, Wireless. ISP operator
luhiwu
Re: v5.20 released
Thu Aug 16, 2012 1:49 am
Bravo! seems to work pretty good here.
Campano
Re: v5.20 released
Thu Aug 16, 2012 1:57 am
very good for here!
w0lt
Re: v5.20 released
Thu Aug 16, 2012 2:32 am
  • Can't seem to get the UPS to work from the USB port on a RB751G using 5.20...
    Connected ok under 5.19 but would not stay online longer than 5 minutes even if I set it to 60 minutes. UPS was online and ok.
    The UPS is a APC RS 1500.
See the image below....
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
lazuardyuq
Re: v5.20 released
Thu Aug 16, 2012 3:05 am
Very good.
problem solved at RB411AH + R52HN.
thank you very much.
regards
lazuardy
roadracer96
Forum Veteran
Forum Veteran
Re: v5.20 released
Thu Aug 16, 2012 4:49 am
Very disappointed that no SSTP fixes made it into this release.
macgaiver
Re: v5.20 released
Thu Aug 16, 2012 8:22 am
Have you actually tried it?
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
normis
Re: v5.20 released
Thu Aug 16, 2012 8:28 am
Very good.
regards
lazuardy
Hello Lazuardy! Which problem do you mean?
taduikis
Re: v5.20 released
Thu Aug 16, 2012 8:31 am
Could anyone please remind me what we're specifically talking about?
lazuardyuq
Re: v5.20 released
Thu Aug 16, 2012 9:30 am
Very good.
regards
lazuardy
ya, normis
I previously had trouble RB411ah / R52HN hangs after 6-7 hours at ROS v5.19, Downgrade v5.18 running but ccq ccq value is very small 20 % - 40 %, data rate and throuhput not good.
After upgrading to 5:20 RC1 and v5.20 released hotspot connection is stable.
The value of data rate, throughput is very good, it was ccq average 80% -90%.
Nice job :-D :-D :-D
RB411ah / R52HN AP bridge only
I using RB450G router.
hapi
Re: v5.20 released
Thu Aug 16, 2012 1:04 pm
it´s joke? no!
und3ath
Re: v5.20 released
Thu Aug 16, 2012 1:25 pm
Show column Distance
hapi
Re: v5.20 released
Thu Aug 16, 2012 3:06 pm
real max 1km.
mikrotik distance max 3km, average 1km.
sindudas
Re: v5.20 released
Thu Aug 16, 2012 3:07 pm
Upgrading to the new POE firmware (previous 1.10, and new 2.0) on RB750UP got problemes on ether5 when connecting a Rocket M5 to it.
With PoE firmware 1.10 it works well, but upgrading it to 2.0, it continously reboots de Rocket M5. We try it with two RB750UP units, and does the same.
If set "PoE Out" to auto on ether5 (nothing connected in it) and ether4 (Rocket M5 connected in it), the Rocket M5 reboots faster. And when set "PoE Out" in ether5, Rocket M4 on ether4 works fine.
normis
Re: v5.20 released
Thu Aug 16, 2012 3:10 pm
What if you set it to "forced on"?
rmichael
Forum Veteran
Forum Veteran
Re: v5.20 released
Thu Aug 16, 2012 3:25 pm
I seem to be getting better CCQ for NV2 in PtMP configuration. Can Mikrotik confirm that there were changes made to NV2? I'll not deploy until someone confirms it. Thank you.
normis
Re: v5.20 released
Thu Aug 16, 2012 3:30 pm
Minimal improvements have been done to the AR9344 Atheros driver, but mainly for RB951 and RB2011. It could have some effect on other AR9344 devices.
sindudas
Re: v5.20 released
Thu Aug 16, 2012 5:28 pm
"Auto on" or "Forced On" the same result.
Trying to power the Rocket M4 in ether4, with "auto on" or "forced on" at ether5, makes power at ether4 reset faster. And if I unplug de RocketM5 from ether4, red light from ether4 blinks until I put ether5 to "off". And the "PoE Out Current" shows 1920mA in ether4.
After that, the RB750UP rebooted and, unplugging the RocketM% from ether4 and anything plugged at ether5, with "forced on" in 4 and 5 it shows 1900mA and red light blinking.
0ldman
Re: v5.20 released
Thu Aug 16, 2012 11:39 pm
RB411AR with an R52n. The R52n seems fine, but I can't choose turbo on the built in 2.4GHz card.
When did we lose 40MHz for A/G devices?
andreacoppini
Trainer
Trainer
v5.20 released
Fri Aug 17, 2012 1:49 am
Here we go again, changes to critical components and no mention of it in the changelog...
- No strings attached -
<< Please give good Karma if this post helped you. Press the + button above the Location entry
Campano
Re: v5.20 released
Fri Aug 17, 2012 3:47 am
lost my statics :S
any with the same problem?
angboontiong
Re: v5.20 released
Fri Aug 17, 2012 4:21 am
what about the RB1100AH, RB1200 port labelling issue?
normis
Re: v5.20 released
Fri Aug 17, 2012 8:46 am
Which changes do you mean? The only changes are the ones in there.
puterboy
Re: v5.20 released - also having problems with POE upgrade
Fri Aug 17, 2012 8:53 am
I seem to be experiencing similar issues as "sindudas" with the POE after upgrading.
I went from v5.18 with the 1.x firmware to v5.20.
Tried with Ubiquiti Picostation M2 (Unifi firmware), as well as Ubiquiti AirCam.
Both devices worked without issue on v5.18 w/1.x FW.
Seeing constant resets on v5.20 w/2.0 FW.
Tried 'auto on' and 'forced on' no change.
Adjusted priority from 10 to 0. no change.
Adjusted prority from 0 to 99. no change.
/interface ethernet poe settings> print
and
/interface ethernet poe settings> export
as follows.....
[puterboy@MikroTik] /interface ethernet poe settings> print
version: 2.0
ether1-poe-in-long-cable: no
[puterboy@MikroTik] /interface ethernet poe settings> export
# aug/16/2012 21:44:10 by RouterOS 5.20
# software id = G602-XFV4
set ether1-poe-in-long-cable=no
Anything else I can try to help sort this out?
Thanks!
~puter
steen
Re: v5.20 released
Fri Aug 17, 2012 9:53 am
Hello Folks!
Tonight we upgraded all our production RB333, RB450G, RB750, RB411, SXT-5D and RB600 devices from 5.19.
No customer impact and no problems at all so far and our network is heavely loaded most of the times, many ppl working from home with citrix and other critical stuff.
Again, good work mikrotik!
n21roadie
Re: v5.20 released
Fri Aug 17, 2012 11:54 am
Hello Folks!
Good to read upgrading of your entire network to v5.20 was a success but I could not take a similar approach to upgrading live networks, I have upgraded just one less critical PTP and testing so far has been positive then I will move slowly but steadily through the network, remember customers who have a choice of providers have zero tolerance to interruptions to their service.
N21roadie,
Network 100% MT for Now?
veljko
Re: v5.20 released
Fri Aug 17, 2012 12:11 pm
RB951-2n still have problem with wireless :(
But CPU now working on 400Mhz.
normis
Re: v5.20 released
Fri Aug 17, 2012 12:12 pm
What problems are you having? maybe they are related to the environment or configuration?
Make sure you use AES and not TKIP, change "distance" to "indoors", make sure you have b/g/n not only-b, try other frequencies.
eben
Re: v5.20 released
Fri Aug 17, 2012 12:18 pm
I'm not seeing that. Installed my first one yesterday. Client connects with an ipad and is getting great speed up and down.
roadracer96
Forum Veteran
Forum Veteran
Re: v5.20 released
Fri Aug 17, 2012 12:31 pm
No, but there was nothing in the changelog.
und3ath
Re: v5.20 released
Fri Aug 17, 2012 2:02 pm
Excellent job on wireless! Every single AP(RB411, RB600, RB435, RB433, ...) - PtMP and also PtP are now stable.
We had many "reassociatings" on 2.4GHz 802.11b with old 2.4G APs, but now is everything OK.
Perfect!!!!!
meschaninovn
Re: v5.20 released
Sat Aug 18, 2012 12:18 am
When i try to add UPS - The following errors: "Couldn`t add New UPS - opening serial port failed: 2 9 (6)"
5.19 - all OK
karina
Re: v5.20 released
Sat Aug 18, 2012 1:04 am
just took a nice shiny new 1100AH out of the box and loaded 5.20, all configured nicely deploying tonight. don't anticipate any problems have great faith in Mikrotik products and software. will obviously report here if any occur. Its replacing a 1200 running 5.16 that is slightly under-powered for its job.
just one slight niggle I would have liked to seen the internal Fan pinouts on the board so I have the option to add a Fan if it got a little hot under the bonnet. It just has holes where the pinouts would go.
Can anybody at Mikrotik tell me. are those holes actually connected into the power circuit allowing me to solder in some pins if I wanted to?
napismizpravu
problem not responding routerboard
Sat Aug 18, 2012 2:34 am
5.20 uptime 2d routerboard RB433UAH (power 24V 2A) problem not responding routerboard (stop traffic, no winbox,no telnet,no wirelles, ether,no SMB, no graf statistic KO! linux) (-//-random stop v.5.18;5.19) >> power off-on = OK functional again (watchdog disable)
RouterOS 4.xx - 5.?? uptime from version to new version
hagar83
Re: v5.20 released
Sat Aug 18, 2012 5:39 am
5.19 - all OK
Same here, on 5.19 all good.
karina
Re: problem not responding routerboard
Sat Aug 18, 2012 9:59 am
I had same issue. turned out to be the dreaded green cap syndrome
karina
Re: v5.20 released
Sat Aug 18, 2012 10:09 am
RB1100AH humming away nicely on 5.20.
Just one minor issue so far:
I have DUDE monitoring CPU temp using CPU Temp [oid("1.3.6.1.4.1.14988.1.1.3.11.0")/10 (the /10 was a fix for the 1200)
It now shows The second ICE age has occurred over night reporting a temp of -273.0 :D
Mikrotik can you tell me how to correct the readout thx
Polky
Re: v5.20 released
Sat Aug 18, 2012 10:53 am
Still, I upgraded to 5.20. And I must say that it is Nstreme NV2 and more stable!
Although nothing in the changelog.
In some places, the stability improved. In some places, has not improved. Anyway, it's a step forward! Thank you.
Sorry for my English.
SimonDeLaplace
Re: v5.20 released
Sat Aug 18, 2012 11:03 am
Upgraded omitik upa and a lot of
system,error,critical System rebooted because of kernel failure
Device lost radio interface!
honzam
Re: v5.20 released
Sat Aug 18, 2012 11:58 am
Have you latest routerboot?
taduikis
Re: v5.20 released
Sat Aug 18, 2012 12:25 pm
Yesterday I was one click away from upgrading one of our UPA's when I saw some client traffic moving and postponed upgrade :) Now it kinda scares me to do it :)
slech
Long time Member
Long time Member
Re: v5.20 released
Sat Aug 18, 2012 2:58 pm
karina
Re: v5.20 released
Sat Aug 18, 2012 4:21 pm
I have RB1100AH & RB1200 I am not seeing this. But then I did configure these routers from scratch.
I did not upgrade a pre configured router.
Polky
Re: v5.20 released
Sat Aug 18, 2012 11:01 pm
Talking about this
Fortunately, I have set the client only 1 frequency AP. (scan list) To recconect took the least time.
karina
Re: v5.20 released
Sat Aug 18, 2012 11:29 pm
This seems unique to the 1100AH. I have now upgraded a RB1200 and the CPU temp is reported correcty
rado3105
Re: v5.20 released
Sun Aug 19, 2012 1:15 pm
This night, I upgraded about 10 devices. One of them I was not able to connect after upgrade....When I came to place, wireless interfaces havent been in routeros and also no wireless packages....it was rb433 and before it was there ros 5.18.....So be careful, what If I had this device in tower with bad access.....
eben
Re: v5.20 released
Sun Aug 19, 2012 1:29 pm
http://www.gsmcommander.com
I'm also rolling out 5.20 over hundreds of Routerboards. So far I've only had a problem with one RB750 not restarting. The GSM Commander saved the day as the RB750 is very far from where I am sitting.
rado3105
Re: v5.20 released
Sun Aug 19, 2012 2:46 pm
That package wasnt there, the only way how to solve it is to copy it there again or using netinstalleter. So this gsm commander can be good, but not for this case....
3000 dollars for gsm commander? Are you joking me? For that money I put much stable devices there......
jcem
Re: v5.20 released
Sun Aug 19, 2012 3:32 pm
Prices are in South African Rand $1 = ZAR8.33
:lol:
napismizpravu
current version firmware ?
Sun Aug 19, 2012 4:39 pm
current version firmware?
karina
Re: v5.20 released
Mon Aug 20, 2012 12:40 am
a little further investigation reveals my RB1100AH does not have a CPU temp sensor. Not a major problem for me but the sales brochure says it does. does my board have a fault or is it just a typo in the sales brochure?
rmichael
Forum Veteran
Forum Veteran
Re: v5.20 released
Mon Aug 20, 2012 1:09 am
Mine shows temperature and power usage -ROS 5.14
linek1980
Re: v5.20 released
Mon Aug 20, 2012 9:20 am
Statistics quickset stopped. the same situation is with ros6b3
normis
Re: v5.20 released
Mon Aug 20, 2012 9:22 am
Make sure to upgrade to final v5.20 version first. It's possible that RC1 had this issue, but Final doesn't. http://www.mikrotik.com/download
linek1980
Re: v5.20 released
Mon Aug 20, 2012 9:42 am
demo2.mt.lv of ROS on 5.20 also is blocked
uldis
Re: v5.20 released
Mon Aug 20, 2012 11:05 am
Please write to support@mikrotik.com your board Serial Number so we could check and try the board from the same batch.
karina
Re: v5.20 released
Mon Aug 20, 2012 2:45 pm
Hi
I have sent the email this morning. Curiously my board temp sensor also stopped this morning. so just in case its a software issue I also included a SUPout file.
Thanks for your attention
napismizpravu
Mon Aug 20, 2012 4:08 pm
-//- routerboard KO! >>> power off-on = OK functional again
mars
Mon Aug 20, 2012 6:59 pm
we have the same problems
abucan
Re: v5.20 released
Mon Aug 20, 2012 10:15 pm
I have a RB751G-2HnD with 5.17 software version.
When i upgraded to 5.20 and firmware to 2.41, I've noticed that every 30 to 60 seconds there are 15-20 sector writes.
I've accumulated 200 000 sector writes in a couple of days.
Then I downgraded to 5.17 and the sector writes didn't improve. When i downgraded the firmware back to 2.38, everything returned to normal. I now have 154 sector writes since reboot and that was an hour ago (this is a normal value after reboot).
Is anybody else having the same issue?
Zavi
Re: v5.20 released
Tue Aug 21, 2012 12:00 am
I was watching writes for a while and here are results
ROS 5.20 was installed at midnight, there are some file uploads and config changes before 21:30
 9 899 @ 21:30
10 315 @ 22:30 -  7 sw/min
10 383 @ 22:35 - 14 sw/min
10 419 @ 22:40 -  7 sw/min
10 455 @ 22:45 - 7 sw/min
10 491 @ 22:50 - 7 sw/min
10 539 @ 22:55 - 9 sw/min
So i have more than 400 sector writes/hour without any config changes or logging. Graphs are stored every 24 hours.
Total writes 340 644 / 13 days (all with firmware 2.41 and ROS 5.19 until today).
RB751G with OS v5.20 and firmware 2.41
RB751G-2HnD & RB2011UiAS-2HnD-IN at home
n21roadie
Re: v5.20 released
Tue Aug 21, 2012 1:59 am
http://wiki.mikrotik.com/wiki/Manual:Ro ... bad_blocks
Since RouterOS v5.18, NAND is refreshed every few minutes which increases sector writes by ~32 per refresh. At first this may seem very much but it is implemented that refreshing writes 1 write cycle to NAND per week. As the manufacturer of the NAND chip guarantees 100'000 write cycles to the NAND sectors, NAND life is about 100'000 weeks.
Is this really a issue or just the way MT have refreshed sector writes and should we be concerned by this?
N21roadie,
normis
Re: v5.20 released
Tue Aug 21, 2012 9:53 am
abucan, this is the v5.20 topic, but you run v5.17.
in the next version, this issue with NAND writes was fixed, so please upgrade to v5.20
v5.18
*) fix bad block count not to increase on Samsung K9F1208U0C nand;
abucan
Re: v5.20 released
Tue Aug 21, 2012 11:29 am
v5.18
I just wanted to point out from witch version I did upgrade to 5.20. I have no problem with 5.17.
As I can read from Wiki, from version 5.18 sector writes are a feature and not a bug "Since RouterOS v5.18, NAND is refreshed every few minutes which increases sector writes by ~32 per refresh."
I didn't know that.
Thanks.
normis
Re: v5.20 released
Tue Aug 21, 2012 11:58 am
Sorry if I misunderstood you. We have updated the text to be more readable: http://wiki.mikrotik.com/wiki/Manual:Ro ... bad_blocks
c0d3rSh3ll
Long time Member
Long time Member
Re: v5.20 released
Wed Aug 22, 2012 5:25 am
bug in sstp??
Ticket#2012082266000094
nothing
napismizpravu
Re: v5.20 released
Wed Aug 22, 2012 8:01 pm
RB433UAH CPU 100%
Something is prepared for metarouter ?
metarouter.net
metarouter.com
eben
Re: v5.20 released
Wed Aug 22, 2012 8:56 pm
Mikrotik Support
Please pay urgent attention to the following support incidents:
2012082266000638
2012082066000356
I think I may have discovered a bug in 5.20 802.11 2.4GHz wireless.
jrl
Re: v5.20 released
Thu Aug 23, 2012 9:15 am
We are having mixed results with POE ports on rb750UPs since we upgraded to 5.20.
Basically we upgraded a number of rb750ups setup with a bridge between ports ether1 and ether2 as a master port. Effectively we are using them a POE power supply/switch with the ability to reboot connected APs.The firmware, the routerboard and the poe firmware were all upgraded. All seem fine given that they have only been upgraded a few days ago.
The other popular configuration we use is to separate ether5 from the ether2 master group and power the radio feed (either a Mikrotik or a Ubiquity unit) off that port. We then configure routing between ether2 and ether5, vpns etc. Sometimes we power a local wifi access point from one of the ports ether2, ether3 or ether4. Of five rb750UPs in this configuration when updated four don't maintain poe on port ether5 to the radio. All had been running reliably before. The quick fix was to insert a POE injector between ether5 and the radio.
We took two unused rb750UPs, updated them by updating the main firmware, then the routerboard and finally the poe firmware. We set them up ready to replace a pair of the problem units and tested the poe on port ether5 with a Nanostation. All looked good until we tried replacing the problem routers.
Does anyone know how the poe sensing really works? I am wondering whether we may have a cabling issue that doesn't cause problems with a poe injector or with the earlier firmwares, but does now. All the affected customers are running vpns between offices and won't tolerate an outage on a system that is running to satisfy our curiosity.
normis
Re: v5.20 released
Thu Aug 23, 2012 4:06 pm
Please give us some more info:
1) whether port 5 does not power-on at all?
2) whether forced-on mode helps?
3) output of
/interface ethernet poe print
/interface ethernet poe monitor [find] once
roadracer96
Forum Veteran
Forum Veteran
Re: v5.20 released
Thu Aug 23, 2012 8:45 pm
bug in sstp??
Ongoing.
Happens a lot on my RB1000 w/ ~200 clients. Other times, the SSTP service just bombs out and nobody can connect until its restarted. Been waiting on a fix for a looong time.
BelWave
Re: v5.20 released
Fri Aug 24, 2012 12:31 am
Same here. v5.19 UPS package works fine, but not in v5.20. Put everything back to v5.19 and UPS is good and working. Need this fixed!
Thanks!
Brad
5.19 - all OK
pavlan
Re: v5.20 released
Sun Aug 26, 2012 12:50 am
There is a bug in 5.20 bridge !!!
I checked several boards running 5.20 and all of them show strange results in bridge host table.
i.e.
this is from a 750G
   BRIDGE                                                      MAC-ADDRESS       ON-INTERFACE                                                      AGE
  bridge-vlan32                                               00:0C:42:1D:xx:yy vlan32-eth3                                                       0s
L bridge-vlan32                                               00:0C:42:72:xy:xy vlan32-eth3                                                       0s
...                               -> vlan32-eth3 is not in bridge-vlan730 !!!???
L bridge-vlan730                                              00:0C:42:72:xy:xy vlan32-eth3                                                       0s
L bridge-vlan112                                              00:00:00:00:00:00 vlan112-management                                                0s
433AH
Flags: L - local, E - external-fdb
  bridge1           00:00:00:00:00:00 wlan1                  0s
RB333 again running on 5.20
  bridge1          00:00:00:00:00:00 ether2-other-AP       38s
L bridge1          00:0C:42:1D:........ ether2-other-AP       0s
Mac addesses from interfaces not belonging to a particular bridge, appear in its host table.
Otherwise things seems to be working ... no loss of connectivity. But.... ?
Anyone else ?
kgninfos
Re: v5.20 released
Sun Aug 26, 2012 7:53 pm
i just upgraded m RB-750GL and Rb433 to V5.2 and no issues
krakenant
Re: v5.20 released
Tue Aug 28, 2012 7:46 pm
Pavlan how many ports do you have on your bridges?
BelWave
Re: v5.20 released
Tue Aug 28, 2012 7:51 pm
Any update on the UPS Package being broken in v5.20? You can select usb1, but it hangs and/or gives an error. Dropping back to v5.19 and all is good.
Thanks!
Brad
w0lt
Re: v5.20 released
Tue Aug 28, 2012 9:17 pm
Thanks!
Brad
Bump.....
MTCNA - 2011
pavlan
Re: v5.20 released
Wed Aug 29, 2012 10:24 am
On the 750G - two corresponding vlan interfaces. But its not config issue.
I've seen these strange readings in host table on various devices.
Especially mac addresses appearing as 00:00:00:00:00:00.
spire2z
Long time Member
Long time Member
Re: v5.20 released
Wed Aug 29, 2012 2:49 pm
The NV2 wireless on long distance is more stable now in my opinion giving much more reliable throughput and not dropping or giving poor performance occasionally. I think it may now have more issues on shorter distance links now though as I see our shortest links now having occasional disconnects where they didn't on previous versions but some of out long ones had some minor issues on previous versions are now better.
yogii
icmp filter problem
Thu Aug 30, 2012 11:49 am
hello Mr.normis, Mr.uldis.
my ip address is 192.168.2.7 connected to RB750GL(ros version 5.20) through vlan, i'm trying to block icmp from other src ip address, so i have rule
chain=forward protocol=icmp src-address=!192.168.2.7 action=drop
the rule above is no interface defined, and then i'm trying to ping mikrotik.com from ip address 192.168.2.7, result is RTO. but when i set in-interface=vlan-local icmp is Reply.
i'm trying this problem too using my RB433AH(ros version 5.20) but client not through vlan interface (through ether1), with same rule i ping mikrotik.com and result is Reply.
why that rule won't works without vlan interface defined?
thank you in advance Sir..
slech
Long time Member
Long time Member
Re: v5.20 released
Thu Aug 30, 2012 6:03 pm
RB 433UAH - 100% CPU Load - PPP - SSTP
Ticket#2012083066000695
wispwest
Re: v5.20 released
Fri Aug 31, 2012 4:08 am
Had to replace an RB/493 today.
I had (2) 493AH's in stock, brand new in plastic.
1. I powered the first one up, noticed it had 4.17 on it. Was going to take it to 5.20, but I remember what happened with the GL's, so instead I took it to 5.15 first then > 5.20
2. Dumped the backup file on.
3. Installed/replaced old one at tower.
4. Worked PERFECT for 1 hour.
5. All LAN traffic on bridged ports 2-9 COMPLETELY stop.
6. Rebooted, no fix
7. Downgraded firmware back to 5.15, and routerboard firmware, no fix.
8. Took back to 4.17, no fix
9. Un-brigged all the ports, and assigned the IP block to ONE port, still no talk to the AP on the same subnet!
10. RESET CONFIGURATION, re-build the config from scratch. NO FIX.
11. Went back to office, opened up my 2nd RB/493AH spare, brand new. LED Lights Power up and STAY ON, DOES NOT BOOT!!
12. Replaced with RB/433AH + Switch (since it only has 3 ports, I need all 9) = Worked PERFECT. Running 5.20.
Am I just having bad luck lately with Mikrotik or what!!?!?!?!?
normis
Re: v5.20 released
Fri Aug 31, 2012 8:19 am
wispwest, once again, please send us serial numbers from the affected units. We tested a lot of RB411GL yesterday, and could not find any problems with upgrade (from stock v5.11 to v5.20). Maybe there is something special about you boards, different batch or something like that.
steen
Re: v5.20 released
Sat Sep 01, 2012 1:21 pm
Hello Folks!
SNMP -> 100% CPU again....
We have had problems now and then with 100% CPU, it has always been traced down to SNMP, disable and enable it and it works for some time.
It hits back to the following devices in our environments only)
RB333 about every 3:rd month
RB450G about every 5:th month
SXT5D every month
This happens as well on ros5.20 as it does in older versions in ros5.x no worse none better.
What can this be ?
slech
Long time Member
Long time Member
Re: v5.20 released
Sun Sep 02, 2012 7:57 pm
RB433UAH 100 % CPU SSTP - does not respond to system reboot
> system reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
Without effect.
djdrastic
Re: v5.20 released
Mon Sep 03, 2012 12:29 am
Steen I've been facing that same problem some 450's.Do yours sometimes lock up in unison or are they hanging separately ? I wonder if there's a way to write a script to restart the SNMP service on a regular basis to see if that doesn't eliminate the problem ?
nz_monkey
Re: v5.20 released
Mon Sep 03, 2012 12:51 am
Hello Folks!
SXT5D every month
What can this be ?
I am also seeing this issue. I thought it was specific to RB750GL and RB750UP but we appear to be seeing it on RB2100 as well. I have a ticket logged Ticket#2012081366000093 but Mikrotik are taking a very long time between responses.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
helectro
Re: v5.20 released
Mon Sep 03, 2012 6:11 am
Beware rb450g just upgraded one of the version 4.17 to version 5.20 and stopped responding, this team is at 52km away, on a mountain to raise in 4x4
sorry for my bad English
muriachi
Re: v5.20 released
Mon Sep 03, 2012 9:59 pm
Thanks!
Brad
5.19 - all OK
The same problem to me
erebusodora
Re: v5.20 released
Tue Sep 11, 2012 2:33 pm
On RB 450G too many FCS Errors, Align Errors and ethernet ports limiting 5mbps !!. Back to 5.18 ALL OK.
becs
Re: v5.20 released
Wed Sep 12, 2012 10:35 am
Please write to support@mikrotik.com about this problem with attached v5.20 supout.rif file.
erebusodora
Re: v5.20 released
Wed Sep 12, 2012 4:00 pm
It is very risky because of that RB450G I have 150 clients and do not want to risk to put 5.20 again.
rto
Re: v5.20 released
Thu Sep 13, 2012 12:12 pm
RB951-2HnD using 5.20
With quickset in ap/cpe mode using router mode. When i set dns server, after apply , setting of DNS server back to empty. I check over export compact, or in /ip dns show empty. This is bug or i missing something ??
gluetea
Re: v5.20 released
Thu Sep 13, 2012 12:33 pm
I have RB450G and RB493AH, all this time upgraded without any problem, but this time i try from ROS 5.17 jump to ROS 5.20, problem appear :
1. RB 493AH, Simple Queue dissappear completely, but i solve it with restore last backup file before upgrade, now it's fine.
2. RB450G, PPP menu dissappear, PPP client still functions but when open it to configure, only have General and Traffic Tab, nothing else to input, No Dial Up Tab.
3. RB450G, /system/routerboard menu and /routing menu at winbox dissappear too.
I cannot solve RB450G problem even with restoring last backup before upgrade.
Anybody got same problem?
steen
Re: v5.20 released
Mon Sep 17, 2012 5:38 pm
Hello Folks!
100% CPU again, devices affected SEXTANT and SXT all other devices RB411, RB750, RB450G, RB333, RB600 is not affected.
It was all tracked town to SNMP, I have now disabled it (not good monitoring is affected) to see if it helps.
This isssue has been around for a long time now, I fist observed it at this level with reboots every third week or at least one time per month, when we started to use SXT and SEXTANT devicess
Is there any solution ?
bambangs2komputer
Re: v5.20 released
Tue Sep 18, 2012 6:52 pm
Has anyone have issue in ROS 5.20 configuration PCC like in wiki. I mean if we create pppoe-client use usermanager or not and in mangle PCC after disconect pppoe client "red mark" like my picture. Test with RB1200 & RB450
gluetea
Re: v5.20 released
Wed Sep 19, 2012 5:54 am
After test why my 450G got problem when upgraded from ROS 5.17 to ROS 5.20, i'm successfully fix it, by downgrade to ROS 5.17 (the problem still same, missing PPP) then upgrade to ROS 5.18 then ROS 5.19 then upgrade firm from 2.39 to 2.41 then upgrade to ROS 5.20 then load my last stable configuration backup while i was ROS 5.17. It's done perfectly no problem. My PPP appear again.
My conclusion : Next time i will upgrade ROS by sequential version, not jump over.
ludvik
Re: v5.20 released
Fri Sep 21, 2012 8:20 pm
Same here. APC Smart-UPS 620I on RS232 in RB450G
Thanks!
Brad
5.19 - all OK
helectro
Re: v5.20 released
Wed Sep 26, 2012 10:37 pm
I update one 493AHG, now I can not add an APC ups, please someone could send me the link where you can download 5.19
Thanks for your help
aaguilar
Re: v5.20 released
Fri Sep 28, 2012 9:51 pm
UPS doesn't work with 5.20.
With 5.19 it works very well.
Is there something wrong?
"Couldn't change UPS <ups1> - port's channel is already in use (6)"
The same configuration but with RouterOS 5.19 works fine.
Can you help me?
Thanks.
aaguilar
Re: v5.20 released
Fri Sep 28, 2012 9:54 pm
Thanks!
Brad
5.19 - all OK
The same error here, with 5.19 all works fine.
I need help.
Thanks.
napismizpravu
v5.20 released
Sat Sep 29, 2012 5:47 am
uptime 23d RB433UAH (power 24V 2A) error DHCP pool - this is only used pool1 for all IP (default pool2+pool1) + does not load from the table Leases IP > reboot OK
sonny
Re: v5.20 released
Sat Sep 29, 2012 4:07 pm
Compared to 5.16 and 5.17 cpu load has doubled with 5.20.
RB411AH wirelss NV2 30 Clients going up from 20-40% to 50 and more even by 4Mbit throughput
And ehternet port flapping is back.
has anyone the same expierence?
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
erebusodora
Re: v5.20 released
Sat Sep 29, 2012 5:29 pm
Many correctly. Example - RB450G with a Sextant-5HND ROS 5.20 . There are many errors FCS, Align error and ethernet flaping
dschulz
Re: v5.20 released
Mon Oct 01, 2012 5:01 pm
I'm also having problems with the UPS (APC SmartUPS RT 3000). Has been working without problems before 5.20.
Is there any news on this issue?
rado3105
Re: v5.20 released
Mon Oct 01, 2012 5:13 pm
UPS doesnt work in 5.20, mistake of one of the best mikrotik programators....
You must wait till next release....
ludvik
Re: v5.20 released
Mon Oct 01, 2012 10:03 pm
It's probably typo in source code. Small error - Why mikrotik not issued the new package? Why do we have to wait for the new full ROS release?
toni17
Re: v5.20 released
Tue Oct 02, 2012 1:37 am
Did you know what happend to my rb450g after one year awesome performace in hotspot 5.14 , after upgraded to 5.20 then reboot ! Boom ,no dhcp, no static dhcp leases , no 100 hotspot users . Happend like someone deleted them. :shock: What a catastrofe .....
JanezFord
Re: v5.20 released
Tue Oct 02, 2012 9:54 am
I've been running my RB450G for weeks with 5.18 and upgraded to 5.20 ... after second reboot all graphing data was lost ... so I guess there is something wrong with 5.20 firmware - it deletes data.
rado3105
Re: v5.20 released
Tue Oct 02, 2012 3:54 pm
I have here some unregular shutdowns on my rb450 devices...
justinmiller
Re: v5.20 released
Thu Nov 15, 2012 2:11 am
I seem to be having some problems with the POE controller 2.0 firmware. On a 750UP, I upgraded to 5.21, and then manually upgraded the POE controller to 2.0. I'm only using POE out on ether5. Now, whenever ANYTHING is plugged into ether3, ether5 POE cycles power on and off, rebooting the connected Groove every 10 seconds or so. This happens both when ether5 POE is set to auto, or on. Ether3 POE is set to off.
Unfortunately, I updated the POE controller on 6 750UPs before I noticed the problem. They all show this behavior. They did not show this behavior with the 1.1 POE firmware.
Users browsing this forum: Bing [Bot] and 70 guests
