wispwest
WHY are the Sextants and Metal S5HPn's pre-configured!
Wed Aug 15, 2012 8:54 pm
I've been throwing these up for PtP links, and I'm noticing they have PRE-CONFIGURED
- DHCP Server
- DHCP Client
- NAT Firewall filter settings
WHY are these coming pre-configured!?!?! Anyone that's ever used Mikrotik does all the programming from scratch. Now I have to and "undo" every radio I get in, removing all the pre-configured settings. Is there anything else that is pre-configured I have to go find?
So I figured I'll just do a system-reset. NOPE! A system reset "should" erase all settings to default right? I resets everything back with DHCP Client, Server, Firewall filters...
InoX
Re: WHY are the Sextants and Metal S5HPn's pre-configured!
Wed Aug 15, 2012 9:37 pm
Remove configuration.
wispwest
Thu Aug 16, 2012 1:16 am
is there anything they "sneaked" in there that is configured that I don't know about. and what is the command to remove the configuration?
savage
Thu Aug 16, 2012 9:42 am
/system reset-configuration if memory serves me right.
Regards,
Chris
DiabolixZA
Thu Aug 16, 2012 10:03 am
/system reset-configuration no-defaults=yes
normis
Thu Aug 16, 2012 10:46 am
When you first connect to these devices, all of the preconfigured stuff is shown to you, with two buttons "Keep" and "Remove"
wispwest
Thu Aug 23, 2012 6:07 am
that works, thanks
Users browsing this forum: No registered users and 25 guests
