baxide
PPPoE - client can't connect via bridge
Sun Jan 22, 2006 10:05 pm
Hi Everyone,
I just set up my MT today, which acts as an access point, and bridges eth1 and wlan1 to forward PPPoE packets between clients and the server.
When I try connecting to the PPPoE with my laptop's wireless card, it works perfectly, so I assume the bridging has been done correctly (was quite easy...).
But, when I use my new 5 Ghz bridge, the AC8-4 (some taiwanese stuff with Linux on it), it won't work... every packet goes through the device, no matter what I want to ping, but PPPoE (built-in client of my WinXP) simply can't connect...
The setup looks like this:
PPPoE server ------(UTP cable)----- MT ----(5 Ghz link)----AC8-4---- (UTP cable)---- LAPTOP
So in this case, PPPoE (discovery) packets won't pass through either MT, or AC8-4.
If the problem is the AC8-4 bridge, can somebody explain me briefly how to bridge the device's two interfaces, just like under MT? The device runs standard linux, I saw the commands "ifconfig", "ip route" and such are available...
Any help would be greatly appreciated!!!
savage
Tue Jan 31, 2006 5:56 am
It's possible the AP doesn't forward PPPoE through the bridge. Saw it many times before. Try a different AP, it'll more than likely work.
Chris
jager
Trainer
Trainer
Tue Jan 31, 2006 1:26 pm
The AP does not forward PPPoE packets, for sure.
I had the same situation with stupid Tellus A14 AP. It has an option, called "IP Filter" and if it is enabled, it passes only IP traffic. I can ping, etc, but no PPPoE. Turning this off solves the problem.
Baxide, look carefuly, is on your AP some similar "clever feature" enabled?
