normis
v6.0beta3 released!
Wed Aug 22, 2012 4:36 pm
What's new in 6.0beta3 (2012-Aug-22 12:12):
*) installation - use much less space in storage (works well with 32MiB flash);
*) routerboard package is now merged with system package;
*) userman - use corresponding time zone data when showing date in console;
*) gps - init-string option;
*) ipsec - kill phase1 if ipsec-sa in responder expires due to system time change;
*) ipsec - rekey phase1 before expiration;
*) ipsec - when last ISAKMP-SA is deleted for the remote host remove related IPSec-SAs;
*) ipsec - send delete IPSec-SAs on shutdown/reboot;
*) user manager - fix user's active profile end time if it has unlimited validity,
these users now won't be hidden from reports when date filters are in effect;
*) certificate validity is shown using local timezone offset;
*) fixed queue bit rate reporting;
*) fixed ipv6 firewall;
*) upgraded drivers and kernel (to linux-3.3.5);
*) added priority matcher to firewall;
*) added change-dscp from-priority and from-priority-to-high-3-bits options;
*) fixed router crash or hang when rebooting;
*) add snif-tzsp,snif-pc actions to ip/ipv6 firewall mangle;
*) traffic-generator improvements for multi core;
Download: http://www.mikrotik.com/download (click "View More" to see Beta)
napismizpravu
Re: v6.0beta3 released!
Wed Aug 22, 2012 4:59 pm
error show "Name"(enable show) package list WinBox
linek1980
Wed Aug 22, 2012 8:18 pm
i have rb333 with a damaged one lan port. Any attempt to upgrade ros6b3 the ends failure. I also tried netinsall but the effect is the same. With ros4 and ros5 works well.
alexspils
Thu Aug 23, 2012 12:42 am
ntp client dont work mipsbe
enabled: yes
mode: unicast
primary-ntp: 194.190.168.1
secondary-ntp: 0.0.0.0
dynamic-servers:
status: error
simple queue dont work (dont show traffic) without specifing targed download and upload
hapi
Thu Aug 23, 2012 12:47 am
true
paoloaga
Thu Aug 23, 2012 2:58 am
I wanted to report that NTP client doesn't work, but I see it has already been done.
I tested it on several products, it doesn't work on mipsbe (RB750, RB750G) neither on PPC (RB1100, RB1100AH, RB1100AHx2, RB1200).
wispwest
Thu Aug 23, 2012 3:59 am
one of the most important issues with beta 2, all simple queues IP are lost and change to 0.0.0.0. was this fixed??? nothing in release notes...
w0lt
Thu Aug 23, 2012 4:01 am
  • It appears that the UPS driver doesn't work in 6.0 beta3.
    The USB port doesn't show up in the UPS port selection.
    It does show up in the resources area though and recognizes the APC UPS RS1500 that I am using.
    RB751G-2HnD
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
normis
Thu Aug 23, 2012 10:41 am
simple queues work fine in beta3.
normis
Thu Aug 23, 2012 10:42 am
linek1980 and hapi, which port is damaged, and when does the error occur?
hapi
Thu Aug 23, 2012 10:59 am
all
all have link down
normis
Thu Aug 23, 2012 11:15 am
all
all have link down
Please clarify the issue a little more. If all ports are damaged, you can't install RouterOS, that's normal. Or you have all ports broken after installation? Which RouterBOARD model, which firmware and what was the previous running RouterOS version?
hapi
Thu Aug 23, 2012 12:14 pm
RB333. v5.20 is ok.
upgrade to v6.0beta3... boot is ok... dual beep ok... all ethernet is link down. Sometimes flash Ethernet cable if it is connected. Must be used NetInstall for return to v5.20.
Netinstal from v6.0beta3 for RB333 is does not work. Kernel panic. Must by used from v5.20.
That version was not tested? I do not know that you have an error come.
dude: routerboard package is missing, dude does not do the update.
janisk
Thu Aug 23, 2012 12:23 pm
starting 6.0beta3 routerboard.npk is no more. All the functionality from it is integrated into system package.
honzam
Thu Aug 23, 2012 1:00 pm
It is goog, but DUDE need routerboard package to upgrade. Will be new version of dude? For Compatibility DUDE and V6.
LAN, FTTx, Wireless. ISP operator
ToMikaa87
Thu Aug 23, 2012 2:12 pm
Are there any improvements about the Atheros 8316 switch IC? I mean the switch freeze issue on some gigabit RBs (RB435G, RB493G, RB450G).
normis
Thu Aug 23, 2012 4:09 pm
We are not aware of any freezing, unless you mean issues with Metarouter and these chips. If you have encountered any such issues, contact support with more info.
engineertote
Thu Aug 23, 2012 5:18 pm
RB 439 upgraded from 5.12 to 6.03 beta , router rebooting every 3 to 4 mins , CPU jumping to 100% for sometimes and back normal even with no load .
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
slech
Long time Member
Long time Member
Thu Aug 23, 2012 6:48 pm
 #   NAME                    VERSION                    SCHEDULED
 0   system                  6.0beta3
 1   hotspot                 6.0beta3
 2 X ipv6                    6.0beta3
 3   mpls                    6.0beta3
 4   security                6.0beta3
 5   routing                 6.0beta3
 6   advanced-tools          6.0beta3
 7   wireless                6.0beta3
 8   dhcp                    6.0beta3
 9   ppp                     6.0beta3
10   routeros-mipsbe         6.0beta3
11   dude                    4.0beta3
sorry for my english
hapi
Thu Aug 23, 2012 7:55 pm
OMG ... incredible. We all know that routerboard package is part of the system. But this dude knows. Dude says: missing routerboard package. End of story.
ToMikaa87
Thu Aug 23, 2012 8:48 pm
I did it without any success. I always got the answer that the issue cannot be reproduced. I wrote my problem on many forums and that revealed I am not the only one who ran into this bug. Many boards equipped with the 8316 switch is affected.
vadyalex
Thu Aug 23, 2012 8:56 pm
Upgraded 751UAH. I can see wireless speed improvements. It is still awful 10/5Mbps but it's much better then before 3/1Mbps :lol:
linek1980
Thu Aug 23, 2012 11:18 pm
attempt to update ends :
MikroTik Login: Oops: Kernel access of bad area, sig: 11 [#1]
RB333/RB600
NIP: 8027ae48 LR: 801db4d4 CTR: 801da350
REGS: 829b1be0 TRAP: 0300 Tainted: P (3.3.5)
MSR: 00009032 <EE,ME,IR,DR,RI> CR: 24022028 XER: 00000000
DAR: 00000000, DSISR: 22000000
TASK = 82994c60[264] 'insmod' THREAD: 829b0000
GPR00: 801db4d4 829b1c90 82994c60 829c6028 00000020 00000002 829b1c48 00000001
GPR08: 829b1c98 ffffffff 00000000 801da350 00000001 100195ac 007d552c 10010000
GPR16: 1000a645 1000a63a 853badc4 0000000a 853c51d8 853c51cc 853c51b0 83fff244
GPR24: 853cc120 00000000 83fff6f4 829c602c 00000000 82994c60 829c6028 829c6028
NIP [8027ae48] __mutex_lock_slowpath+0x34/0xc0
LR [801db4d4] mdiobus_read+0x38/0x74
Call Trace:
[829b1c90] [80339b1c] 0x80339b1c (unreliable)
[829b1cc0] [801db4d4] mdiobus_read+0x38/0x74
[829b1ce0] [801da374] get_phy_id+0x24/0x7c
[829b1d00] [853c38f0] fsl_pq_mdio_bus_name+0x3bc/0x4f0 [ucc_geth@0x853bf000]
[829b1d70] [8019251c] driver_probe_device+0x88/0x198
[829b1d90] [801926e8] __driver_attach+0xbc/0xc0
[829b1db0] [80190ac0] bus_for_each_dev+0x54/0xa0
[829b1de0] [80191d8c] bus_add_driver+0x1ac/0x27c
[829b1e10] [80192c64] driver_register+0x88/0x174
[829b1e40] [853c9014] init_module+0x14/0xa8 [ucc_geth@0x853bf000]
[829b1e60] [80003988] do_one_initcall+0x148/0x1b0
[829b1e90] [8006434c] sys_init_module+0x948/0x19ec
[829b1f40] [8000f068] ret_from_syscall+0x0/0x38
--- Exception: c01 at 0x300b1d3c
LR = 0x10001078
Instruction dump:
7c0802a6 3920ffff 81430008 bf61001c 39010008 3b630004 90010034 7c7f1b78
7c5d1378 91030008 93610008 9141000c <910a0000> 90410010 7d401828 7d20192d
---[ end trace 0fea7e4179914b19 ]---
WLAN: node=1216, buf=96, buffrag=24, dev=1480
Netfilter messages via NETLINK v0.30.
ctnetlink v0.93: registering with nfnetlink.
try to install the NetInstall :
rb-ros4-- netinstall ver 5.18
Got IP address: 192.168.1.50
resolved mac address 00:22:15:54:F5:C4
transfer started ............................. transfer ok, time=1.56s
setting up elf image... OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press CtrlOops: Kernel access of bad area, sig: 11 [#1]
RB333/RB600
last sysfs file:
NIP: 85211ae8 LR: 85211cf0 CTR: 801c3bb8
REGS: 83a45c30 TRAP: 0300 Tainted: P (2.6.35)
MSR: 00009032 <EE,ME,IR,DR> CR: 24822042 XER: 20000000
DAR: 00000004, DSISR: 20000000
TASK = 83885800[21] 'init' THREAD: 83a44000
GPR00: 85211cf0 83a45ce0 83885800 00000000 802bc758 80298b7c 801c3ba4 00000000
GPR08: 00000001 00000000 83a45bd0 801c3bb8 84822042 10028820 007d552c 02000000
GPR16: 00000000 00000000 20000000 83833d68 83833b98 80320000 83833d30 83833b08
GPR24: 20000000 00000001 00000200 00000000 83833800 8520f264 83833b14 83833b00
NIP [85211ae8] init_flow_control_params+0x1bb0/0x25c0 [ucc_geth@0x8520e000]
LR [85211cf0] init_flow_control_params+0x1db8/0x25c0 [ucc_geth@0x8520e000]
Call Trace:
[83a45ce0] [85211cf0] init_flow_control_params+0x1db8/0x25c0 [ucc_geth@0x8520e00
0] (unreliable)
[83a45da0] [801d9f80] __dev_open+0xf0/0x13c
[83a45dc0] [801da22c] __dev_change_flags+0xa0/0x198
[83a45de0] [801da3d8] dev_change_flags+0x1c/0x64
[83a45e00] [8022adc4] devinet_ioctl+0x7ac/0x890
[83a45e70] [8022c120] inet_ioctl+0xcc/0xf8
[83a45e80] [801c5cf0] sock_ioctl+0x64/0x2a4
[83a45ea0] [800a35b0] do_vfs_ioctl+0xa4/0x754
[83a45f10] [800a3ca0] sys_ioctl+0x40/0x74
[83a45f40] [800113ec] ret_from_syscall+0x0/0x38
--- Exception: c01 at 0x300b336c
LR = 0x1000796c
Instruction dump:
88e6010c 38c6010d 48001591 813c0300 7f83e378 7fa5eb78 80ff0290 38c00000
80890108 48001485 7c7b1b79 418201fc <807b0004> 38c00000 38a00000 809b00c8
-Alt-Delete to a---[ end trace cfc0e006ebff4887 ]---
bort
Kernel panic - not syncing: Attempted to kill init!
Rebooting in 180 seconds..
reboot
mikroTik Login: Oops: Kernel access of bad area, sig: 11 [#1]
RB333/RB600
last sysfs file: /sys/bus/spi/uevent
NIP: 85323ae8 LR: 85323cf0 CTR: 801c3bb8
REGS: 83a59c30 TRAP: 0300 Tainted: P (2.6.35)
TASK = 83a87000[206] 'net' THREAD: 83a58000
GPR00: 85323cf0 83a59ce0 83a87000 00000000 802bc738 80298b5c 801c3ba4 00000000
GPR08: 00000001 00000000 83a59bd0 801c3bb8 84822042 100e6594 007d552c 02000000
GPR16: 00000000 00000000 20000000 83bdc568 83bdc398 80320000 83bdc530 83bdc308
GPR24: 20000000 00000001 00000200 00000000 83bdc000 85321264 83bdc314 83bdc300
NIP [85323ae8] init_flow_control_params+0x1bb0/0x25c0 [ucc_geth@0x85320000]
LR [85323cf0] init_flow_control_params+0x1db8/0x25c0 [ucc_geth@0x85320000]
Call Trace:
[83a59ce0] [85323cf0] init_flow_control_params+0x1db8/0x25c0 [ucc_geth@0x8532000
0] (unreliable)
[83a59da0] [801d9f80] __dev_open+0xf0/0x13c
[83a59dc0] [801da22c] __dev_change_flags+0xa0/0x198
[83a59de0] [801da3d8] dev_change_flags+0x1c/0x64
[83a59e00] [8022adc4] devinet_ioctl+0x7ac/0x890
[83a59e70] [8022c120] inet_ioctl+0xcc/0xf8
[83a59e80] [801c5cf0] sock_ioctl+0x64/0x2a4
--- Exception: 1043 at 0x83a59f40
LR = ret_from_except+0x0/0x14
[83a59ea0] [800a35b0] do_vfs_ioctl+0xa4/0x754 (unreliable)
[83a59f10] [800a3ca0] sys_ioctl+0x40/0x74
[83a59f40] [800113ec] ret_from_syscall+0x0/0x38
--- Exception: c01 at 0x3011436c
LR = 0x30039bf8
Instruction dump:
---[ end trace c638b39156a8e0d2 ]---
PHY: mdio@e0103120:01 - Link is Up - 10/Full
Chupaka
Sun Aug 26, 2012 3:23 am
I reported the problem for pre-beta3, but it's still not fixed:
queue should not be 'red' when avg-rate is 12% of max-limit ;)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
hapi
Sun Aug 26, 2012 1:45 pm
This is correct. 100Mbit is less than 12.3Mbit. What is the problem?
Chupaka
Sun Aug 26, 2012 3:04 pm
I don't understand your sarcasm %)
moly
Sun Aug 26, 2012 4:12 pm
After upgrade from ROS5.20, router don't boot with error Kernel panic. Picture attached.
Try upgrade from 5.20 with configuration and from 5.20 without configuration, result is the same.
Netinstall for ROS 6.0b3 not work, try on 2 various PC.
Router HW : Gigabyte EP45-DS4 , CPU Q9550 , 2G RAM , 2x Intel dual port NIC , 2x intrgrated realtec NIC
Martin Cerny
chairman of Oslavany.NET
hapi
Sun Aug 26, 2012 8:28 pm
and I what's the problem.
Chupaka
Sun Aug 26, 2012 11:09 pm
is 100 less than 12?..
if so, then 88 less than zero... :roll:
Volart
Mon Aug 27, 2012 9:31 am
Hi. I wanted fix ipsec issue and install 6.3beta.
Now i have 100%CPU on my RB 411U with 3g card and 3g USB modem. And 2 Ipsec/GRE tunnels.
normis
Mon Aug 27, 2012 9:40 am
make a supout.rif file and email support, please
Chupaka
Mon Aug 27, 2012 3:16 pm
in Terminal, exec "ip fi mangle add chain=forward action=sniff-pc", then in WinBox go to Firewall Mangle and remove the rule - voila!
tomaz_borstnar
Tue Aug 28, 2012 8:08 am
6.0beta2 always panics after reboot. So I tried netinstall with beta3:
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:21:35:B5
mac-address: 00:0C:42:21:35:B6
Waiting for installation server...
Found server at C8:2A:14:58:75:90
Reading old configuration...
Formatting disk..........
Writing back old configuration....
installed first stage
RouterBOOT booter 2.27
RouterBoard 600A
CPU frequency: 533 MHz
Memory size: 128 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
opendir: No such file or directory
ERROR: no system package found!
vincen
Thu Aug 30, 2012 9:29 am
Would someone know if that version 6 implements at least the option 60 for DHCP client ? needs that absolutely and am desperate it's not implemented yet :(
Thanks,
Vincèn
MimiFleX
Thu Aug 30, 2012 12:04 pm
Funny release :)
For support, see ticket 2011072766000267 for details (supout, pictures, details about VLANs and IP behaviour).
For us the situation is worst on x86 + Intel network chipsets than ROS4-5 or 6beta2 as :
- I'm unable to use VLANs AT ALL : data is transmitted, but not received over a
vlan interface. The used MTU was 1500 both for physical and vlan
interface. Ping size where small. It's not a problem of MTU but of
VLAN/Driver implementation. Nothing appears in logs, using debug topic.
- Deleting VLANs coming from the previous system version config (after
upgrading from 6.0beta2 to 6.0beta3 on an already configured with VLANs system) causes
Kernel Panic.
- When using a fresh blank config (after system reset), some very weird
things appear with VLANs. Something may be wrong
with internal indexes and the way IP addresses are attached to these
indexes.
- Launching a supout file generation causes a kernel oops about the
traffic_gen process with a NULL pointer dereference.
I also tried to disable MPLS and multi-cpu, without any improvement,
even after reboot. Note that disabling multi-cpu support throws an error
saying that changing this setting was unsuccessful.
Regards,
vincen
Thu Aug 30, 2012 1:38 pm
Why is there still no way in that new major release of os capability to control Mode 60 feature of DHCP client ?
Thanks,
Vincèn
wispwest
Thu Aug 30, 2012 6:05 pm
NOPE. Just took a RB/493AH from 5.20 to 6.03 and ALL simple queues IP address's are now 0.0.0.0!
Uploaded with ImageShack.us
pospanko
Fri Aug 31, 2012 12:21 pm
MetaRouter won't boot on RB450G...
Internet, Mikrotik & Network solutions
http://www.pro-ping.hr
sloth
Fri Aug 31, 2012 2:32 pm
Is there any ETA / timeline for 6.0 final?
slech
Long time Member
Long time Member
Fri Aug 31, 2012 5:44 pm
As 5.20,
ROS 6.b3 - RB751U + 3G modem - reboots and hangs
Ticket#2012083166000504
Inssomniak
Sat Sep 01, 2012 4:52 am
Oooh I think its a long way off.
I have it running on a couple sites, APs, nothing doing anything major and seem to work good on RB's, but x86 beta2 was a train wreck
linek1980
Sat Sep 01, 2012 1:27 pm
demo2.mt.lv already on RC1
vincen
Sat Sep 01, 2012 2:25 pm
and still no capability to customise mode 60 in DHCP client :( that's really not cool :cry:
Chupaka
Sat Sep 01, 2012 7:37 pm
have you written to support@ about that, instead of complaining on community forum? we cannot develop RouterOS, we can help with current functions
vincen
Sat Sep 01, 2012 8:04 pm
Excepted that support is not avalaible for customers having bought Mikrotik products from resellers so it looks like I have no right to contact directly Mikrotik :(
Chupaka
Sat Sep 01, 2012 8:07 pm
okay, even in that case: have you contacted your reseller? ;)
p.s. write to support@!!!
vincen
Sun Sep 02, 2012 12:10 pm
Done ;) sorry for disturbance !
linek1980
Sun Sep 02, 2012 8:01 pm
Today I tested ROS6 in a RB133. I tried 6B3 and 6RC1. installation via FTP and netinsall. Installations end successfully but RB does not start.
"mikroTik 5.20
MikroTik Login:
Rebooting...
Stopping services...
verified routeros-mipsle-6.0rc1.npk
Restarting sys
RouterBOOT booter 2.18
RouterBoard 133C3
CPU frequency: 175 MHz
Memory size: 16 MB
Starting...
Resuming upgrade...
installed routeros-mipsle-6.0rc1
Generating SSH DSA key...
Starting services...
^C^HkroTik 5.20
MikroTik Login:
Rebooting...
Restarting sys
RouterBoard 133C3
Memory size: 16 MB
Starting...
Resuming upgrade...
Starting services..."
and dasn't start. :(
normis
Mon Sep 03, 2012 8:03 am
This is not correct, MikroTik support will always answer an email, however, your first first line of support should be your local reseller. If they can't help, then you can contact MikroTik directly.
vincen
Mon Sep 03, 2012 8:48 am
Thanks for clarification :) as it's a feature request I guess it's better to send it directly to Mikrotik :)
Xymox
Mon Sep 03, 2012 1:24 pm
RB450 > Netinstall > 6b3 > Kernel panic, rebooting | cant net install
RB450 From 6b2 > drag over 6b3 npk + ntp6b3 npk = Menu options in winbox for packages not installed + NTP Error
On 6b4 will Metarouter fix thats on 5.21 be included ?
AnRkey
Tue Sep 04, 2012 12:34 pm
I've installed 6 b3 to a VM on Hyper-V and it still doesn't show the virtual interface despite the changelog showing that we on kernel 3.3.5.
Have the kernel modules been excluded or disabled?
See this thread for the history: http://forum.mikrotik.com/viewtopic.php ... 31#p332331
MTCNA
Xymox
Tue Sep 04, 2012 2:02 pm
6B3 is most odd...
I did a serious purging of my RB450G. NAND format.. Then again did a Netinstall of 6B3.. This time install went fine !?
However,,, weirdness occurred. NTP was dead, with "error" Then I noticed that I was not getting any data thru the router. While all the firewall rules looked OK something was truly astray. I did not spend enough time to sort thru exactly what was wrong. Sorry, but I needed the router back up.
I was copy pasting a config. The one I always use..
Moving to 6B2 or 5.20 all was fine...
This is the first beta ive seen from Mikrotik in a long while that was really wacky, but this one is acting a bit like H.A.L 9000. Maybe putting the routerboard in with the system has made it too intelligent..
Clearly as I approached it to plug in RS232 it went "Just what do you think you're doing, Dave?" "Stop Dave"
And then as I configured my laptop IP address and started up Netinstall with 5.20 ready, "I know everything hasn't been quite right with me, but I can assure you now, very confidently, that it's going to be all right again. I feel much better now. I really do."
That was when I needed the beep script for the song Daisy...
http://www.youtube.com/watch?v=c8N72t7a ... re=related
Im sure the issues will be fixed and we will have 6B4 shortly and be back to really stable betas as I have become used to from Mikrotik.
readycool
Thu Sep 06, 2012 3:37 pm
If IP address is over ether interface then I can ping between two SXT's.
If I change interface over VLAN interface then I can not ping them anymore.
Edit: Even if I can not ping SXT's one to other I can ping end device
add bridge=bridge1 interface=wlan1
add address=192.168.10.10/24 comment="default configuration" interface=\
vlan10
/interface vlan
add interface=bridge1 l2mtu=1596 name=vlan10 vlan-id=10
MimiFleX
Fri Sep 07, 2012 12:16 pm
Good to know that I'm not the only one having problems with VLANs, even with a RouterBoard hardware.
More over, the support asked me to try the 6.0rc1 (yes there's a RC even if the last beta seem to be unusable as a potential RC). Here my comments (sent to support) :
- USB is not working anymore : no devices detected such as the USB
keyboard. /system ressource usb pr does not display anything.
- Using a serial cable console, I was able to perform a system reset. No
more success on everything previously tested on 6.0b3 after system reset : same bugs on vlan and ip addresses, unable to generate a supout file...
- This time, running the supout CLI command causes the terminal session
to be reset, without displaying anything on the VGA terminal except the
initial login prompt (unusable as the keyboard is not detected).
maxeschm
Fri Sep 07, 2012 12:17 pm
Anybody else noticed that the Usermanager database is corrupted?
I can't LogIn to the admin-area (http-interface), get the message user/password incorrect.
No Load/Save ... possible, always the message - database is corrupted
rg
maxeschm
maxeschm
Fri Sep 07, 2012 12:20 pm
Only Upgrade from 5.20 to 6.0 Beta3 is possible.
Direct installation via netinstaller (with format NAND) result in a message:
kernel panic not syncing attempted to kill init
rg,
maxeschm
maxeschm
Fri Sep 07, 2012 12:29 pm
There is a big problem with user authentication and payment. The user can login and use internet access without payment - only by choosen a profile. For details:
http://forum.mikrotik.com/viewtopic.php ... 07#p332707
The same problem in 6.0.3 (using x86 version - this works fine, without kernel problem and without corrupted um-database)
rg
maxeschm
paka
Fri Sep 07, 2012 12:56 pm
Hi Normis,
v6.0beta3 hat a bug. The database of User Manager is not found. Error message says "Database is corrupted"
Checked for device RB400 series.
Please help me, see this problem too :
http://forum.mikrotik.com/viewtopic.php?f=10&t=61851
bbj
Fri Sep 07, 2012 6:42 pm
my rb450 Serial Number B5C01E0884F dont like this new system package..
broken package system-6.0beta3-mipsbe.npk and after uploading the whole shebang via webfig
and rebooting/system packages shows version 5.20 for everything
[admin@BBJ-MAIN] /system package> print
Flags: X - disabled
0 ntp 5.20
1 system 5.20
2 user-manager 5.20
3 dhcp 5.20
4 security 5.20
5 advanced-tools 5.20
6 routing 5.20
7 ppp 5.20
8 wireless 5.20
9 routerboard 5.20
ideas?????
Chupaka
Fri Sep 07, 2012 6:57 pm
what's in Log?
redownload files
bbj
Fri Sep 07, 2012 7:12 pm
should i do a reset configuration?in webfig? ive got an export o all my settings
Chupaka
Fri Sep 07, 2012 7:14 pm
you don't need reset for upgrade
Campano
Fri Sep 07, 2012 8:21 pm
Normis, please put attention in SSTP server, in both version (5.20 and 6.0 B3) the cpu is 100% after user disconnect
bbj
Fri Sep 07, 2012 10:04 pm
sing the reboot option in webfig is/was semi useless, :? i had to powercycle the device.another part of the fix was to d take the npk option on the mikrotik download site. this gives you the routerboarrd .npk filei noticed this in the log though
03:00:19 manager,error,info,debug database is corrupted and now my packages look like this
[admin@BBJ-MAIN] /log> /system package print
Flags: X - disabled
0 user-manager 6.0beta3
1 X ipv6 6.0beta3
2 ntp 6.0beta3
3 wireless 6.0beta3
4 mpls 6.0beta3
5 routeros-mipsbe 6.0beta3
6 dhcp 6.0beta3
7 ppp 6.0beta3
8 routing 6.0beta3
9 hotspot 6.0beta3
10 security 6.0beta3
11 advanced-tools 6.0beta3
12 system 6.0beta3
Chupaka
Sat Sep 08, 2012 2:08 am
yep, it was already reported that 6beta3 brokes UserManager database
kobuki
Sun Sep 09, 2012 2:39 pm
I thought I report this. Happening in a VMWare Workstation 9.0.0 build-812388. See attached screenshots (same error in 2 pics). Fresh install, was just about to set up an IP address. Issued a print statement under /ip address.
wispwest
Mon Sep 10, 2012 4:48 am
Just noticed another MAJOR problem with beta3.
Aside from all the simple queue IP addresses being lost, I just upgraded a PtP bridge. Data rates are 300/300. UDP throughput went to 211Mbps before I did the upgrade. AFTER upgrading to 6.0beta3, it never hits even 100! sticks at around 80-90mbps!!!
Chupaka
Mon Sep 10, 2012 11:29 am
btw, it's still actual for 6.0rc1 from Sep/06/2012
normis
Mon Sep 10, 2012 11:34 am
chupaka, we can't repeat it. are you on x86?
Chupaka
Mon Sep 10, 2012 11:36 am
yep, ESXi v5
MimiFleX
Mon Sep 10, 2012 11:49 am
I'd similar dumps on x86 physical hardware too, including about traffic_gen, for 6.0b3.
However I'm unable to see any dumps on rc1 (Sept/06/2012) and today version, I only have console reset/disconnect sending me back to the login prompt instead of the dump.
I'm unable to produce supout files for this reason.
Tickets opened and screenshots sent to support.
kobuki
Tue Sep 11, 2012 12:51 am
Please excuse my ignorance, but where can I download RC1 for testing? Public pages show only 6.0b3 download links.
normis
Tue Sep 11, 2012 10:27 am
You have to sign up for pre-release testing, and have to agree that some of these releases are alpha-quality. They can and will crash. Send email to support if you agree to test this.
vincen
Tue Sep 11, 2012 10:32 am
Sorry but where do you sign up for pre-release testing ?
normis
Tue Sep 11, 2012 10:40 am
This:
vincen
Tue Sep 11, 2012 10:52 am
This:
:D
kobuki
Wed Sep 12, 2012 12:19 am
Thanks. For a beta/RC it's pretty normal.
MimiFleX
Thu Sep 13, 2012 5:06 pm
Hi all,
great news from our side using the latest rc1 build (X86 NPK MD5 =a370f0926e29250c530c81597c247447 downloaded on 2012-09-12) :
Difference from 6.0b3 :
- VLANs are working (I can ping something else !)
- USB is working (I can use my keyboard for the VGA console).
- No more bugs on Ethernet Running/Ready flags
Differences from 5.X and 6.0beta
- L2TP server is now working when Ethernet interface is set with a >1500Bytes L2MTU (no crashes, ppp link OK instead of "invalid packet" in the logs).
However, and good to know, for my Intel NICS : L2MTU is displayed for some chipsets as >9000 bytes, but one have (as usual) to set manualy the MTU to have a L2MTU=MTU+4Bytes (for MPLS, QinQ, and so on, ...).
I hope to see the next beta or better the first stable release in several days to test with more packages and features enabled.
For support, all these good news have been sent for each opened ticket.
For remaining problems on our side :
- unable to produce a supout file from console (OK with Winbox).
- we can't quickly test if we have random crashes for EoIP (when using >1504Bytes MTU on Ethernet ports) as this occured randomly on massive EoIP usage (in production situation only, nether in lab). This was a big problem on all the 5.X versions for us.
Regards,
linek1980
Thu Sep 13, 2012 11:21 pm
uninstall ip6 package
111111
Mon Sep 17, 2012 5:17 pm
@linek1980
is there a reason to put full package an not only individual and needed ones
rb133 memory is little less to do that
In God We Trust. All other must submit X.509 certificate!
readycool
Mon Sep 24, 2012 12:10 pm
There's no bold frequencies on the frequency list as before.
readycool
Mon Sep 24, 2012 3:16 pm
Still has problems with VLAN...
I'm using cisco switch and SXT p2p link to the PC.
A SXT's has IP address over interface VLAN 100.
This is configuration of Cisco switch:
interface GigabitEthernet1/16
 description Mikrotik-test
 switchport access vlan 100
 switchport trunk encapsulation dot1q
 switchport mode trunk
 spanning-tree bpdufilter enable
 spanning-tree guard loop
end
With this configuration I can ping 192.168.1.2 and .3, and can not ping .4 (as I would expect).
ping 192.168.1.2 -t
Pinging 192.168.1.2 with 32 bytes of data:
Reply from 192.168.1.2: bytes=32 time=12ms TTL=57
Reply from 192.168.1.2: bytes=32 time=9ms TTL=57
ping 192.168.1.4 -t
Pinging 192.168.1.4 with 32 bytes of data:
Request time out.
Request time out.
show mac-address-table inter gi 1/16
Unicast Entries
 vlan   mac address     type        protocols               port
   1    000a.xxxx.xxxx   dynamic ip                    GigabitEthernet1/16
   1    000c.42xx.xxxx   dynamic ip                    GigabitEthernet1/16
   1    000c.42yy.yyyy   dynamic ip                    GigabitEthernet1/16
 100    000a.xxxx.xxxx   dynamic ip                    GigabitEthernet1/16
 100    000c.42xx.xxxx   dynamic ip                    GigabitEthernet1/16
 100    000c.42yy.yyyy   dynamic ip                    GigabitEthernet1/16
But when I change native VLAN
switchport trunk native vlan 100
I would expect to ping both of them (SXT and PC).
And I do.
However, after some time (several Replies) it just stop ping SXT's and keep ping PC.
ping 192.168.1.4
Reply from 192.168.1.4: bytes=32 time=9ms TTL=121
Reply from 192.168.1.4: bytes=32 time=7ms TTL=121
Unicast Entries
There are mac table entries but I can not reach SXT so I need to undo native vlan command to reach SXT's.
(I think it's with SXT's.. However, if you see problem with configuration please let me know so I can check).
Users browsing this forum: No registered users and 12 guests
