mobile4lte
Why Huawei E5331 often sense got disconnected?
Thu Aug 23, 2012 12:18 pm
As we all know, huawei E5331 single linkage design, wifi access simple. General design can let you be clear at a glance, but my huawei E5331 display signal is full, strong. But often got disconnected, at first I thought it was a weak current problems, then I try several times are the same situation, why is this so? How to solve got disconnected problem?
kwagga
Re: Why Huawei E5331 often sense got disconnected?
Sat Aug 24, 2013 11:04 pm
Your post isn't making a whole lot of sense. Please type your question in Google Translate, in your native language, and then post the English-translated version here.
Are you trying to use your Huawei E5331 MiFi device as a 3G modem interface for your Routerboard?
Werner van Heerden
wernergvh[@]gmail.com
HNDip(IS:Network Engineering) - MTCNA - MTCWE - CCENT - MCITP - MCTS
dbld
Mon Sep 23, 2013 1:22 pm
Is this possible at all?
To use Huawei E5331 MiFi device as a 3G modem interface for the Mikrotik Routerboard?
bysard
Mon Sep 23, 2013 1:58 pm
I don't see it on compatibility list but it is still hope. If you plug it into your Mikrotik router (I assume you own a model with USB port or x86 machine), does it create a ppp-out interface automatically? If you check /system routerboard usb, do you see the device listed? What kind of RoS version are you using?
dbld
Fri Sep 27, 2013 11:56 am
Yes it creates ppp-out interface when plugged in,
Yes there is an USB listing for it when plugged in
RoS details...
/system> routerboard print
       routerboard: yes
             model: 751G-2HnD
     serial-number: 3A6502CFECC5
  current-firmware: 2.38
  upgrade-firmware: 2.38
Guess all its left is to try using it.. ;)
bysard
Fri Sep 27, 2013 3:44 pm
:) You may only need to play a bit with channels and you should be set to go.
Users browsing this forum: w32pamela and 58 guests
