Usogi
Simple Queue Problem. No TX showing
Wed Sep 12, 2012 12:54 am
Hi, I have had a small script that I slap on our many many routerboards and it limits the speed of each interface to whatever I want. It worked like a charm with version 4.2 and 5.6. But now we have upgraded everything to 5.19 and it suddenly only limits RX.
We have a bridge named "Intercom" with all the interfaces on it. I can easily get it to limit upload but I cant get it to limit or see the download. under TX is just blank, nothing ever shows up.
I'v been messing with this all day trying to get it to do something else. I thought I had something by changing the queue type under Interface Queues but it seems to have only worked for a minute... or maybe It never was and I'm being crazy
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s direction=both \
    disabled=no interface=all limit-at=0/0 max-limit=5M/5M name=Backbone \
    parent=none priority=8 queue=default-small/default-small \
    target-addresses=0.0.0.0/0 total-queue=default-small
    disabled=no interface=ether1 limit-at=0/0 max-limit=512k/512k name=\
    eth1 parent=Backbone priority=8 queue=default-small/default-small \
    disabled=no interface=ether3 limit-at=0/0 max-limit=512k/512k name=\
    eth3 parent=Backbone priority=8 queue=default-small/default-small \
    disabled=no interface=2.4GHz limit-at=0/0 max-limit=512k/512k name=\
    2.4GHz parent=Backbone priority=8 queue=default-small/default-small \
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=no \
    use-ip-firewall-for-vlan=yes
I don't feel like i'm getting anywhere working on this on my own, so if anyone can help me out that would be great
Thanks!
tws101
Re: Simple Queue Problem. No TX showing
Wed Sep 12, 2012 11:03 pm
I suggest you Mangle the packets marking upload and download packets then queue tree them. Simple Queue are not specific enough.
Example from my RB
IP Firewall Mangle
add action=mark-packet chain=forward comment="Download Office" disabled=no dst-address=10.0.0.0/16 in-interface=Ether1-Gateway-TW new-packet-mark="Download Office" passthrough=no
add action=mark-packet chain=forward comment="Download Main" disabled=no dst-address=10.1.0.0/16 in-interface=Ether1-Gateway-TW new-packet-mark="Download Main" passthrough=no
add action=mark-packet chain=forward comment="Download Network" disabled=no dst-address=10.2.0.0/16 in-interface=Ether1-Gateway-TW new-packet-mark="Download Network" passthrough=no
add action=mark-packet chain=forward comment="Download Guest" disabled=no dst-address=10.3.0.0/16 in-interface=Ether1-Gateway-TW new-packet-mark="Download Guest" passthrough=no
add action=mark-packet chain=forward comment="Upload Office" disabled=no new-packet-mark="Upload Office" out-interface=Ether1-Gateway-TW passthrough=no src-address=10.0.0.0/16
add action=mark-packet chain=forward comment="Upload Main" disabled=no new-packet-mark="Upload Main" out-interface=Ether1-Gateway-TW passthrough=no src-address=10.1.0.0/16
add action=mark-packet chain=forward comment="Upload Network" disabled=no new-packet-mark="Upload Network" out-interface=Ether1-Gateway-TW passthrough=no src-address=10.2.0.0/16
add action=mark-packet chain=forward comment="Upload Guest" disabled=no new-packet-mark="Upload Guest" out-interface=Ether1-Gateway-TW passthrough=no src-address=10.3.0.0/16
Queue Tree
add burst-limit=35M burst-threshold=29M burst-time=10m disabled=no limit-at=0 max-limit=30M name="Core Download" packet-mark="" parent="Ether5-Out to Switch" priority=8
add burst-limit=6M burst-threshold=4M burst-time=10m disabled=no limit-at=0 max-limit=5M name="Core Upload" packet-mark="" parent=Ether1-Gateway-TW priority=8
add burst-limit=20M burst-threshold=14M burst-time=1m disabled=no limit-at=5M max-limit=15M name="Sub-queue Download" packet-mark="" parent="Core Download" priority=8
add burst-limit=4M burst-threshold=2M burst-time=1m disabled=no limit-at=1M max-limit=3M name="Sub-queue Upload" packet-mark="" parent="Core Upload" priority=8
add burst-limit=35M burst-threshold=29M burst-time=2m disabled=no limit-at=15M max-limit=30M name="Shield Office Download" packet-mark="Download Office" parent="Core Download" priority=1 queue=\
"Unlimited Down"
add burst-limit=6M burst-threshold=4M burst-time=2m disabled=no limit-at=2M max-limit=5M name="Shield Office Upload" packet-mark="Upload Office" parent="Core Upload" priority=1 queue="Unlimited Up"
add burst-limit=35M burst-threshold=29M burst-time=2m disabled=no limit-at=10M max-limit=30M name="Shield Main Download" packet-mark="Download Main" parent="Core Download" priority=2 queue=\
"Unlimited Down"
add burst-limit=6M burst-threshold=4M burst-time=2m disabled=no limit-at=2M max-limit=5M name="Shield Main Upload" packet-mark="Upload Main" parent="Core Upload" priority=2 queue="Unlimited Up"
add burst-limit=15M burst-threshold=10M burst-time=1m disabled=no limit-at=4M max-limit=12M name="Shield Network Download" packet-mark="Download Network" parent="Sub-queue Download" priority=7 \
queue="Network Down"
add burst-limit=3M burst-threshold=1M burst-time=1m disabled=no limit-at=786k max-limit=2M name="Shield Network Upload" packet-mark="Upload Network" parent="Sub-queue Upload" priority=7 queue=\
"Network Up"
add burst-limit=4M burst-threshold=2M burst-time=1m disabled=no limit-at=1M max-limit=3M name="Shield Guest Download" packet-mark="Download Guest" parent="Sub-queue Download" priority=8 queue=\
"Guest Down"
add burst-limit=2M burst-threshold=512k burst-time=1m disabled=no limit-at=256k max-limit=1M name="Shield Guest Upload" packet-mark="Upload Guest" parent="Sub-queue Upload" priority=8 queue=\
"Guest Up"
sjwrick
Thu Sep 13, 2012 8:25 am
I've noticed that when the queue is "default-small" I get no stats.
I change my queues to queue=default/default total-queue=default
Should be an easy adjustment. See if hat helps.
Rick
RK
Long time Member
Long time Member
Thu Sep 20, 2012 7:09 pm
You are not doing anything wrong as far as I can tell.
I just noticed the same problem. I am going to open a ticket with Mikrotik.
Usogi
Sun Sep 23, 2012 3:24 am
good to know I'm not just doing something silly.
I struggled using the que tree but using mangle to add a connection mark lets me add them to simple ques again. One que for download, one for upload. They both show up as tx but hey, aslong as its working.
Thanks for the help
Dimitripietro
Thu Oct 11, 2012 4:55 pm
I have the exact same problem. Not sure exactly since when exactly. Have you beeen able to find a solution ? I have no tx in simple queue when I use the 750GL as a bridge.
Thx !
Dimitripietro
Sat Oct 13, 2012 4:57 am
I have downgraded my 750GL to routeros 5.7 and with the exact same config, it's working perfectly. There must be something broken in the latest revison but I'm not sure since which version.
RK
Long time Member
Long time Member
Sun Nov 25, 2012 7:47 am
Problem still exists in 5.22.
Bug report 2012092066000612 is still open.
macgaiver
Mon Nov 26, 2012 3:54 pm
You can close it. It is not a bug.
use-ip-firewall was fixed to work correctly with firewall features around 5.6-5.8 version. Your problem is that in one direction use-ip-firewall is registering packets incoming into actual interface ether2, (that is bridge port), but on opposite direction routing don't know anything about interfaces that are in the bridge, routing table is just saying that packets need to go to bridge interface - so for TX traffic out interface is not ether2, but bridge interface, so your simple queue in HTB global doesn't capture this traffic by interface matches.
Simple queues are for simple setups - as soon as you enable use-ip-firewall it is not simple setup anymore. You have 2 choices.
1) disable use-ip-firewall and use bridge interface for limiting
2) remake your simple queues based on IP addresses not on interfaces.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
RK
Long time Member
Long time Member
Mon Nov 26, 2012 4:49 pm
This is a bit absurd.
You break a perfectly good feature, that has been around for years, and claim that it is "by design"?
Using a routerboard as a basic switch (by utilizing the bridge function) and limiting traffic per interface is as "simple setup" as it gets.
I realize routeros is not for idiots, but do you really have to make it so complicated to do something as basic as limiting traffic on an interface?
macgaiver
Tue Nov 27, 2012 12:58 pm
I for one expect this feature to work exactly as it is working on my other Linux boxes - affecting only bridged traffic. That has been so since that 5.6-5.8 version. And yes, i was one of the clients that asked for that fix.
I have strong suspension that RouterOS just uses Linux Kernel code 1:1 for this feature now - there is no need to reinvent wheel again and add confusion.
So stop whining and adjust your setup, to the new features. maybe start with v6.x all together - simple queues have some heavy changes there also.
RK
Long time Member
Long time Member
Wed Nov 28, 2012 5:05 pm
Are you sure about this?
I just tested 5.14 and it works the way that I want.
Could it be that your change is not actually related to my problem?
nsnidanko
Sat Dec 01, 2012 8:37 pm
It worked like a charm. Mikrotik has to update wiki definitions for queue types and what features it supports.
Thank you.
Users browsing this forum: adamojonathan, csalcedo, DottorT86, JosipTopic, nick7, norg, Rietrot, spr41178, und3ath and 153 guests
