ajaywi
Winbox wont always connect, usaully can still HTTP
Mon Sep 17, 2012 11:34 pm
For the last few week almost daily I have 2 out of 7 RouterBoards that will not respond to Winbox. I can usally still use IE and open the web page. But at times they stop responding to those connected to the hotspot on them.
What more is strange I have 1 of the 2 in the middle of this line of 7. so Im bridging 2 backhauls over it, and yet when the hotspot stops working, and Winbox wont let me login, I can still winbox into the next rb on the otherside of it?!
I dont know where to look for the problem, even changed out the RB and the new one started doing the same.. ARP issue?
What can I use to look for the issue?
cbrown
Trainer
Trainer
Mon Sep 17, 2012 11:44 pm
Are you trying to connect to the mac address or the ip address?
C.Brown
cbrown[at]cbrown.co
Telegram: @chris4brown
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
ajaywi
Re: Winbox wont always connect, usaully can still HTTP
Tue Sep 18, 2012 5:30 am
by IP.
sparrow
Tue Sep 18, 2012 4:38 pm
I have the same problem but with x86 server.
I can't acces to it using winbox by means of IP, but only using webfig.
So if I try to access using MAC with winbox I have not problem.....
I've sended a support output file to mikrotik and I'm waiting their answer..
cbrown
Trainer
Trainer
Tue Sep 18, 2012 4:47 pm
Could you post /export compact
C.Brown
cbrown[at]cbrown.co
sparrow
Tue Sep 18, 2012 4:59 pm
thanks so much for you answer, I'm apologize but I can't post the configuration, there are a lot of sensitive data...
I've posted my experience so if someone had the same issue can explain the solution.
Thanks so much too
ajaywi
Tue Sep 18, 2012 5:37 pm
I have the same issue, there is too much private info that comes from that.
I have 7 RouterBoards on the same bridged network. all are setup the same but different IPs everything worked fine for the longest time. then all of a sudden 2 started spazing out.. And its so far been the same 2, I changed out the Mikrotik hardware and it happened again. I even changed the IP thinking maybe my Fiber provider screwed with the routes or somthing but same issue.
sparrow
Tue Sep 18, 2012 5:40 pm
Do you have requested the mikrotik support?
ajaywi
Tue Sep 18, 2012 5:44 pm
sparrow : When yours does it, does the RB ever lock up for the users connected to it? Mine are complaining their connection just stops.
sparrow
Tue Sep 18, 2012 5:58 pm
No, this is not my scenario, I haven't access only to server using winbox with IP....the users continue to surf good...
sparrow
Tue Sep 18, 2012 6:04 pm
Hey......I'm solved the problem just now ahahahahha.......amazing....
Now thinking how could I make to find a solution......and I found it.....
Just disabling via web the "service" winbox and enabling before....I solved it....unbelievable :lol: :lol: :lol:
sjwrick
Tue Sep 18, 2012 6:44 pm
I just started experiencing the same issue on a 450G running ROS 5.19.
Remedied by disabling winbox service in Webfig interface the re-enabling.
What ROS are you guys running?
Rick
ajaywi
Tue Sep 18, 2012 7:49 pm
I have both 5.19 and 5.20.. issue with both.
Are you using Ubiquiti radios at all in your network?
I did do an Disable/Enable but within a day it was doing the same thing.
sjwrick
Tue Sep 18, 2012 10:04 pm
Yes we are using Ubiquity. A couple of Ubiquity NS M2's and an Outdoor Unifi with other Unifis behind another MT Router on that network.
Sorry to hear it repeated the issue. Will keep a watch put for it.
Rick
ajaywi
Wed Sep 19, 2012 5:05 am
Are you using 5.5.2 firmware? Im wondering if its a problem with UBNT's new firmware. Seems about the same time I started seeing the problem
sigmasquared
Wed Sep 19, 2012 12:33 pm
Getting the same on an RB750, winbox freezes, webfig still available, however now and then the passwords stop being accepted in webfig as well. Have to reboot the board before I can access again.
Will be upgrading to 5.20 this evening, on 5.11 at the moment, but nothing in the changelog referring to this so it's a shot in the dark.
ajaywi
Mon Oct 15, 2012 5:30 am
anyone noticing your free memory is being depleated daily? seems once it gets down near 2m the router locks up. Anyone else noticing this?
NetworkPro
Mon Oct 15, 2012 11:16 am
WinBox not working - try this http://forum.mikrotik.com/viewtopic.php ... 18#p337918
memory is consumed - turn off Web Proxy and use latest stable relese version. If prolem still happens - make supout.rif and send to support as "memory leak bug report".
rgrds
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Users browsing this forum: tomikaco and 125 guests
