cibernet
Long time Member
Long time Member
What happened with topic Mikrotik User Manager (beta)??
Sun Jan 29, 2006 1:17 pm
The topic does not exist anymore :S
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
normis
Mon Jan 30, 2006 8:33 am
here it is again :)
cibernet
Long time Member
Long time Member
Mon Jan 30, 2006 8:59 am
here it is again :)
:D
uldis
Mon Jan 30, 2006 11:17 am
http://userman.mt.lv/userman
(Username:password)=demo:demo
cibernet
Long time Member
Long time Member
Sun Feb 05, 2006 10:34 pm
Any news about the manager?
Regards
José Ignacio Acosta
Mikronet
cibernet
Long time Member
Long time Member
Wed Feb 08, 2006 2:35 am
:roll: No news :cry:
José Ignacio Acosta
Mikronet
normis
Wed Feb 08, 2006 8:33 am
what news do you want? it's being made. do you have any suggestions for improvements?
cibernet
Long time Member
Long time Member
Wed Feb 08, 2006 9:42 am
some..
01. When the user almost reach the time limit, send an e-mail to the user.
02. The option to add the company logo and some other data.
03. The option to translate the user front-end (for checking time, volume balance, ect).
04. If it´s posible to show a pop-up when the user logs in (via pppoe).
05. Option to block an user and to show a billing page (customized) when the user logs in.
06. An option to create packages based on time periods (half day, night) so the user could only use his 50 hours only by the night or by the day, ect.
07. Diferent access groups, so an employee can only add o view some items of the radius.
08. On user parameters, option to add a dynamic chain on MT firewall, or an option to add diferent kinds of services (http, all, pop3 smtp, ect).
09. Reports by total daily traffic, user daily traffic.
10. Reports of total payments by user.
11. In user front-end, option to change the password, request more time-data.
12. In user, option to set his MAC address.
13. Option to create advertisements pop-ups (if it´s posible...).
14. Exporting to pdf or xls the reports, the user list, etc.
15. Backup and restore the configuration.
16. Option to set the user limit-at, max-limit, burst, queue priority and parent queue.
17. In user options add total limit value (up+down).
Regards
José Ignacio Acosta
Mikronet
cibernet
Long time Member
Long time Member
Sat Feb 18, 2006 11:49 pm
Normis, will some of the suggestions be added to the userman?
Regards
José Ignacio Acosta
Mikronet
wildbill442
Mon Feb 20, 2006 2:45 am
I have a suggestion... A US based server so it doesn't take 5 minutes for the page to load when trying to enter in data! :)
C:\Documents and Settings\Administrator>ping moon.mt.lv -t
Pinging moon.mt.lv [159.148.147.194] with 32 bytes of data:
Reply from 159.148.147.194: bytes=32 time=192ms TTL=42
Reply from 159.148.147.194: bytes=32 time=203ms TTL=42
Request timed out.
Reply from 159.148.147.194: bytes=32 time=193ms TTL=42
Reply from 159.148.147.194: bytes=32 time=195ms TTL=42
Reply from 159.148.147.194: bytes=32 time=191ms TTL=42
Reply from 159.148.147.194: bytes=32 time=197ms TTL=42
Reply from 159.148.147.194: bytes=32 time=194ms TTL=42
Ping statistics for 159.148.147.194:
    Packets: Sent = 16, Received = 15, Lost = 1 (6% loss),
Approximate round trip times in milli-seconds:
    Minimum = 191ms, Maximum = 203ms, Average = 194ms
Control-C
^C
Anyway we can improve this? :) I'd love to start using this service if it were more responsive.
normis
Mon Feb 20, 2006 8:20 am
i already sait that the `userman` will not be based anywhere. it will be a package for RouterOS
wildbill442
Mon Feb 20, 2006 9:08 am
Oh maybe I'm mistaken I was refering to the hotspot manager - http://moon.mt.lv/radius
Or is this a beta test for the RADIUS server you eluded to in other posts?
normis
Mon Feb 20, 2006 9:14 am
that project has been replaced by the user manager.
this will be a package on routeros and has more features than the old hotspot manager
pedja
Long time Member
Long time Member
Tue Feb 21, 2006 11:46 pm
- option to set hostname for user to produce DNS entry when he gets IP to allow user to be accessibel not just by an IP but memonic address
- options to add custom fields for users
- option to access user database from outside, to allow using it for custom applications
- option to add user's IP to specific Address list
- option to create simple queue (even if usermanager is used just to set ip address to user) and set all properties of simple queue
freethought
Sat Apr 15, 2006 12:56 am
doesn't work in Safari Version 2.0.3 (417.9.2) Mac OS X 10.4.6 PPC :(
You can login and the left hand frame (with the menu) loads but the right hand frame never loads. Clicking any of the buttons (except logout) has no effect.
Freethought Internet Limited - Hosting and communications
Freethought Internet Limited registered in London No. 5862996. Registered office: The Old Church Hall, 2A Cromwell Street, Lincoln, LN2 5LP. VAT number GB 987 0952 66.
normis
Tue Apr 18, 2006 9:44 am
now only if we had a mac here :( we will try to do something, sorry for the problem.
dolf
Tue Apr 18, 2006 2:25 pm
Do you have a date you are expecting to release the mikrotik radius server?
I need it urgently and don't want to waste time setting up and learning freeradius if Mt's is due soon.
normis
Tue Apr 18, 2006 2:31 pm
a few weeks (maybe at the mum...)
airstream
Sat Apr 22, 2006 11:28 am
Hi there,
Will the User manager have the ability to control PPPoE clients useage based on data not time connected. Say 256K up and down untill they reach total data of 1gb for that month cycle, then either disconnect them or slow them to a lesser throttled speed say 64k up and down. Email notification would also be good
Cheers.
uldis
Mon Apr 24, 2006 2:43 pm
Hi there,
Cheers.
Yes, such feature is on the to-do list.
freethought
Tue Apr 25, 2006 4:06 am
I will help as much as possible to test, feel free to ccontact me using the e-mail adddress in my profile or PM
csickles
Tue Apr 25, 2006 6:39 am
And I just sent one to the scrap heap.....
(Apple server)...
Oh well...
Things that make you go "Hmmmmmmmm"...
Craig
normis
Tue Apr 25, 2006 9:06 am
arrrgh, send it to me, quick before it's gone !
normis
Wed May 10, 2006 3:47 pm
we've got a few macs now, we identified the problem, and probably will fix it.
freethought
Wed May 10, 2006 6:39 pm
Probably :shock: :wink:
Are they Intel macs? Can you confirm whether WinBox and the dude works under WINE? (I seem to remember it being mentioned that they work but are slow and slightly buggy?)
We are going to be deploying all internal workstations as iMacs and it will be a PIA if we have to reboot to use WINE/The Dude.
Any chance of a native version by linking against WINElib?
balimore
Forum Veteran
Forum Veteran
Fri Jul 14, 2006 2:22 pm
some..
Regards
hi all
RESTORE point
i did try it USERman, and done create user and login hospot with radius and backup it, if do restore [reload] with that backup file all config at USERMAN is gone, on above description for me RED COLOR priority or i did mistake...bla..bal..bla..............
Peace all
BalimoreDOTcom
normis
Fri Jul 14, 2006 2:41 pm
winbox works and dude kinda works too. this is on an intel mac, in the darwine enviroment, as described on our wiki. you also have the possibility to use Parallels.
balimore
Forum Veteran
Forum Veteran
Wed Jul 19, 2006 9:11 am
some..
Regards
hi all
RESTORE point
Peace all
BalimoreDOTcom
To. Sergejs, Mr.
can let me know how do reload without missed last config, only userman not restore or just beta, or next generation...fixed it
[if make backup and reload it]
Thanks for your cooperation...
Hasbullah.com
----------------------------------------------------------------------------------[/b]
balimore
Forum Veteran
Forum Veteran
Wed Jul 19, 2006 4:09 pm
Thanks alot Sergejs and MT Team
we will continue....and wait more features..
Nice for cooperation.
Regards,
BalimoreDOTcom
mac86
Re: What happened with topic Mikrotik User Manager (beta)??
Sun Aug 19, 2007 10:10 pm
What about next...
16. Option to set the (.....) and parent queue.
Userman support it ? or will be ?
balimore
Forum Veteran
Forum Veteran
Mon Aug 20, 2007 4:22 am
Hai fren
yes, you can add creation queues by that parameters as dynamic one every users.
regards
Hasbullah.com
What about next...
Users browsing this forum: No registered users and 10 guests
