nz_monkey
Feature Request: IPSEC Improvements
Thu Sep 20, 2012 4:21 am
Hi All,
The current IPSEC implementation in RouterOS is very basic, to the point that for us it is unusable. Instead of selling a Mikrotik device or licence we sell a Juniper, Cisco or Fortinet device to terminate IPSEC.
The features I see that are missing, and would like Mikrotik to implement are:
XAuth - Extended Authentication
Allows for user/pass style authentication of IPSEC connections. This would allow RouterOS to be used as an access concentrator for "Road Warriors"
Mode-cfg
Allows access concentrator to specify various parameters for "Road Warrior" clients e.g. DNS and routes
VTI - Virtual Tunnel Interfaces
This has now been added to Linux so should be trivial for Mikrotik to support see http://www.spinics.net/lists/netdev/msg200673.html
Description: Virtual tunnel interface is a way to represent policy based IPsec tunnels as virtual interfaces in linux. This is similar to Cisco's VTI (virtual tunnel interface) and Juniper's representaion of secure tunnel (st.xx). The advantage of representing an IPsec tunnel as an interface is that it is possible to plug Ipsec tunnels into the routing protocol infrastructure of a router. Therefore it becomes possible to influence the packet path by toggling the link state of the tunnel or based on routing metrics.
I have seen all of these requested on the forums and wiki in the past, but IPSEC in RouterOS has changed very little in the past 3-4 years. It seems like Mikrotik has forgotten about IPSEC.
What are your thoughts on the RouterOS IPSEC implementation and what would you like to see changed ?
Would you buy more RouterOS devices/licences if these features were added ?
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
gregsowell
Re: Feature Request: IPSEC Improvements
Thu Sep 20, 2012 4:47 am
Senior NZ has hit the nail on the head.
I will occasionally have a customer do an IPSec tunnel using a Mikrotik if it is the remote device, but seldom if it is the hub.
I've hit oddities that despite every effort I can't trouble shoot. Even the debugging messages aren't always enough...they can be somewhat lacking.
Cisco has always been my go-to due to stability and debug output. They have a vast array of features, but it really comes down to reliability.
I would LOVE to see some xauth come in also. The virtual tunnels are a welcome addition too.
I was under the impression that MTK sudo wrote their own IPSec implementation...have the packages out there not caught up yet?
With more stability I would run MTKs for tunneling all day, just not at this time.
Hit my blog for video tutorials of Mikrotik and Cacti.
Just so I look as cool as everyone else ->CCNA / CCNP / CCIE W / MCNA / MCRE / MCIE / Certified Trainer / A+ / N+ / Partridge in pear tree <- *sigh* I'll never know enough...
gsloop
Thu Sep 20, 2012 11:56 pm
IPSec policy match.
- If I helped you solve your problem ... Karma is an appropriate gift! :) -
robertfranz
Fri Sep 21, 2012 11:40 am
Hi All,
Unfortunately - no.
It would be too little, too late.
After wrestling with MT bugs for 5 years, we opted to upgrade to Cisco end-to-end.
I am waiting on some additional hardware so I can complete the move of our servers from our old colo facility to our new data center.
Once that's done, the last Mikrotik will be smashed with a sledge hammer.
Until then, I'm stuck with an ipsec tunnel that drops on a regular basis.
nz_monkey
Fri Sep 21, 2012 12:02 pm
Ouch. That is sad to hear. We have had generally very good experiences with RouterOS, certainly we find no more bugs than we find on other vendors platforms.
It is mainly the poor IPSEC support that cause us to use other products, and I still hold hope that one day soon Mikrotik will improve it.
grg
Fri Sep 21, 2012 3:13 pm
Fully agree on this one.
rjickity
Fri Sep 21, 2012 4:13 pm
Yes absolutely.
VTI +1
XAuth +1
gregsowell
Thu Oct 18, 2012 4:07 pm
*Sigh* agreed. :(
tomaskir
Trainer
Trainer
Fri Oct 19, 2012 12:38 pm
We do A LOT of IPSec site-to-site tunneling on Mikrotik, and I must say that I am happy. IPSec in Mikrotik just requires you to learn it and to do it by its rules :)
That said, Road Warrior has a lot of problems, and the features above would help out a lot. VTI would be awesome.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
mrz
Thu Apr 11, 2013 12:48 pm
We have added initial mode-cfg support in version v6rc13. If anyone wants to test and suggest other needed mode-cfg features.
nz_monkey
Thu Apr 11, 2013 2:39 pm
Thanks mrz
I will test tomorrow
nz_monkey
Fri Apr 12, 2013 1:27 am
Hi Maris,
Will the mode-cfg settings be added to Winbox ?
mrz
Fri Apr 12, 2013 10:58 am
Yes, they will be added in winbox, but currently you should use console for configuration.
bitak
Sun Apr 21, 2013 1:31 am
Has somebody figured out how to setup ipsec mode-cfg and Shrew Soft Client?
Also I would highly appreciate adding the following mode-cfg features (sorted by importance):
1) dns server address
2) domain
3) split-dns
mrz
Mon Apr 22, 2013 10:57 am
DNS servers are sent automatically when mode-cfg is enabled. Later we will add wiki article how to use mode-cfg with shrew client.
mrz
Fri May 10, 2013 1:11 pm
xauth and split tunnel examples are added in the wiki
http://wiki.mikrotik.com/wiki/Manual:IP ... _Mode_Conf
nz_monkey
Fri May 10, 2013 1:17 pm
Hi Maris,
Thanks for all the hard work on the IPSEC improvements.
Can xauth use RADIUS ? And if so what attributes are relevant?
mrz
Fri May 10, 2013 1:19 pm
Currently RADIUS support for xauth is not implemented.
nz_monkey
Mon May 13, 2013 1:18 am
Hi Maris,
I know you guys are super busy, but any idea when this feature will be implemented ?
We will do some testing on the current implementation, but I would say xauth --> RADIUS is pretty important to anyone wanting to deploy RouterOS as an IPSEC concentrator.
MiKeDaDoC
Fri May 24, 2013 5:23 pm
In the wiki I think you mixed up IP ranges while creating the policy templates. SRC should be DST and vice versa.
Managed to get mode-cfg working with shrew client. Works like a charme for now (still in testing)
scampbell
Trainer
Trainer
Sun Jun 30, 2013 12:53 am
Hmmm.... Wiki update may be required here as these commands are definitely not in RoS 5.0+ :-)
selric
Tue Jul 23, 2013 3:07 pm
Any progress on the VTI implementation as well?
I'm also using the RouterOS and wan't establish IPSEC with OSPF between FortiGate and Junipers in an easy way.
selric
Sat Oct 26, 2013 7:34 pm
Nothing new on the VTI suggestions in this thread?
mrz
Mon Oct 28, 2013 11:35 am
If you want tunnel interface run ipsec in transport mode and ipip or gre over it.
afink
Fri Nov 01, 2013 2:47 pm
the current release 6.5 and also 6.6rc1 still have _sever_ bug in ipsec.
in our case we try to set up a simple point to point tunnel between two mikrotiks.
the profile matches, the policy has the two endpoints of the tunnel as source/destination (the outer IP's) and protocol=47 (which is GRE) defined. The result is the tunnel never establishes.
if you define the policy to use all protocols, then the tunnel establishes but the node to node communication is then blocked (you can not telnet from the outer IP to the other outer IP) and at key re-negotiation time the tunnel drops and stays off again.
This is heavily broken since 6.1 and it stops us from buying another pile of 10Gbit Mikrotiks
volga629
Sat Nov 23, 2013 5:33 am
VTI +1
A lot of cases were I need run Eoip though ipsec and there another tunnels to supply OSPF for router. Tunnel interface will be simplify for 100% everything. Hope this feature will be on Router OS soon.
begemoti
Wed Feb 12, 2014 12:14 pm
+ VTI
nz_monkey
Wed Feb 12, 2014 12:43 pm
Unfortunately this has low cross-vendor inter-op. VTI is common on Cisco, Fortigate, Juniper SSG, Juniper SRX, Palo Alto Networks, Vyatta.
Doing IPSEC+GRE or IPSEC+IPIP also have higher overheads, as well as more configuration steps than VTI.
_saik0
Wed Mar 05, 2014 6:52 pm
VTI++
IPSec in transport mode with a tunnel upon it, almost impossible if you are dealing with dynamic IPs on all sites ...
timk
Tue Mar 25, 2014 1:14 pm
Another vote for VTI here!
i4jordan
Tue Mar 25, 2014 1:46 pm
A good working and simple to setup ipsec VTI would stop us from selling (expensive) SonicWall SRA solutions.
The ipsec VTI should be working like an IPIP/GRE tunnel but then with ipsec security.
We now use IPIP or GRE tunnels with ipsec transport security.
This works but is not easy to setup and specially GRE+ipsec has a huge performance penalty.
Please look also at: http://forum.mikrotik.com/viewtopic.php?f=1&t=81317
We also have asked for IKEv2 options on ipsec tunnels.
jollis
Tue Mar 25, 2014 10:20 pm
has anyone come across a way to make IPSEC use multiple CPUs in routerOS?
i4jordan
Wed Mar 26, 2014 12:37 am
@jollis
No,
I also have seen that ipsec uses 1 CPU on my CCR1036 :(
So 1 CPU very busy, 35 doing almost nothing.
mrz
Wed Mar 26, 2014 11:55 am
Maybe there is not enough traffic to utilize more than one core?
It works in my setup:
ros code
ipsec                     0         8.5%
ipsec                     1         1.5%
ipsec                     2           0%
ipsec                     3           0%
ipsec                     4        29.5%
ipsec                     8           0%
ipsec                     9           0%
ipsec                    12           1%
ipsec                    19         0.5%
ipsec                    20           0%
ipsec                    21           0%
ipsec                    23           1%
ipsec                    25         0.5%
ipsec                    27         0.5%
ipsec                    29         0.5%
ipsec                    30          24%
ipsec                    35           0%
megasohaib
Sun Mar 30, 2014 2:30 pm
Hello Team, I hope you are all fine.
I have some problem with my Ipsec vpn between multiple sites. my 5 sites are connected with same ISP through MIKROTIOK ROUTER IPSEC TUNNEL. sites are a,b,c,d,e. a site is my head office and b,c,d,e sites is my clients(branches). all clients are connected with head office (a) through ipsec tunnel and working properly.But problem is that (b) not connected to (c,d,e) and (c) not connected to (b,d,e) and (d) not connected to (b,c,e) and (e) not connected to (b,c,d). Other words is (b,c,d,e) are not connected to eachother. All sites have different subnets.
Kindly give me some help that what i do work on my head office mikrotik router (a).
Although i was add subnet on routes opetion of my branches. but issed are same.
Regards
Sohaib
ziegenberg
Tue Mar 17, 2015 3:43 pm
I'm also strongly in for Radius enabled XAuth and VTI! So:
+1 XAuth with Radius
+1 VTI
bajodel
Long time Member
Long time Member
Wed Mar 18, 2015 5:21 pm
+1 XAuth (radius)
+1 VTI
bjornpost
Wed Jun 17, 2015 2:35 pm
+1 on adding VTI support
cobusv
Wed Sep 30, 2015 11:13 am
cbabcock
Fri Oct 16, 2015 5:08 am
VTI +1
chechito
Fri Oct 16, 2015 5:36 am
+1 for VTI
until that iPiP over IPSEC works very very good for me
bajodel
Long time Member
Long time Member
Fri Oct 16, 2015 8:36 am
agree, probably MT just need to "put them together" and call it VTI :lol:
andriys
Fri Oct 16, 2015 10:49 am
Nope, that's a different beast. People also want VTI interoperability with other vendors.
Basically, what people usually call VTI is a semi-separate IPsec stack bound to a virtual interface (hence VTI = virtual tunnel interface). The VTI IPsec policies are always 0.0.0.0/0 -> 0.0.0.0/0 and (contrary to the classic policy-based IPsec) the traffic to encrypt is selected by routing (what's going out the tunnel interface) rather then policy (because VTI IPsec policy matches everything).
pe1chl
Sat Oct 17, 2015 9:24 am
Isn't that just GRE over IPsec transport?
That can be very easily configured, especially when you have no special requirements for the IPsec parameters.
andriys
Sat Oct 17, 2015 11:56 am
The end result is similar in both cases (with the only exception GRE+IPsec will lead to a slightly lower tunnel's MTU as compared to IPsec VTI), however GRE+IPsec will not interoperate with, for instance, Cisco VTI, some cloud providers and other VTI implementations. To my knowledge, what people often call VTI has never been standardized, but still is relatively widely used, nevertheless.
pe1chl
Sat Oct 17, 2015 5:46 pm
Ah I thought that GRE over IPsec was a Cisco invention and quite often used in Cisco configs.
Apparently they have again switched to something else.
Of course when you configure IPsec policies and set the "tunnel" checkmark, what in fact happens is very similar to an IPIP tunnel, including the protocol value field.
I have never tested it, but I would not be suprised when an IPIP tunnel over IPsec transport would be compatible with having that VTI on the other end.
It may be more difficult when the other end has automatic policies or strict policy checking.
Anyway, I remember the days when IPsec in Linux was implemented with separate virtual interfaces like ipsec0.
I also found this much more convenient and clearer e.g. when configuring iptables rules.
But, it was deprecated and then abandoned as happens so often in the Linux world. The developers have an opinion and all the users in the world have to follow it. Maybe it was done because Cisco (at that time) did it the same way.
As it is now, the way it works in a MikroTik is the way it works in Linux, and I can fully understand when MikroTik is not going to make changes so deeply in the system. Maybe it is better to first try to convince the Linux developers to change this, and then MikroTik probably will enable it in their RouterOS as well (as it then becomes just a config item, which is what their product is already doing).
nz_monkey
Sun Oct 18, 2015 8:32 am
pe1chl: ahh, Linux has had VTI support for quite a few years now. There are links above to the mailing list posts for the original commits. There is no real reason not to support it these days.
Srv02
Thu Jan 12, 2017 10:23 pm
VTI +2 (me and a friend of mine)
nz_monkey
Thu Jan 12, 2017 11:53 pm
Mikrotik have done an extensive amount of work on IPSEC in RouterOS recently, adding features like xauth, IKEv2 and RADIUS authentication.
Once development and bugfixing on these features has settled down, we will hopefully get VTI support :)
bedior
Fri Jan 13, 2017 4:57 pm
Is ability to configure IKEv2 tunnel as client to Strongswan in RouterOS 6.38?
ziegenberg
Fri Jan 13, 2017 5:16 pm
IKEv2 is in RouterOS 6.38
bedior
Fri Jan 13, 2017 6:02 pm
How configure it as client?
ziegenberg
Fri Jan 13, 2017 6:07 pm
Are you talking about a roaming client or a site-to-site VPN? You can find all the necessary information here in the wiki.
bedior
Fri Jan 13, 2017 6:08 pm
About site-to-site
onnoossendrijver
Wed May 17, 2017 2:44 pm
IPSec VTI +2 here also :)
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
zontor
Fri Sep 22, 2017 12:52 pm
IPSec VTI +1
beside other advantages it's the simplest way to create non-split tunnel ipsec vpn for some interfaces/networks of the router
pe1chl
Fri Sep 22, 2017 2:30 pm
When you just need the VTI functionality and not the compatibility with another manufacturer's implementation, you
can just use IPIP or GRE tunnel over IPsec transport. It has the same advantages as VTI. And it is very easy to
configure, at least when you have fixed external IP addresses. Just make a tunnel interface and enter the IPsec secret.
zontor
Fri Sep 22, 2017 4:13 pm
I've read about that. But in our main site we are using a fortigate and considering an incresing scenario with multiple vpn's to main office, and will be simple with VTI than manage several subnets just for gre/ipip
As we use a proxy to access the web in the ipsec range tunnel i can set the nat rul to 0.0.0.0/0 to block the split-tunnel and the web access needed goes by the proxy. But will be nice a simple and compatible solution for interface like VTI.
migacz
Tue Aug 07, 2018 4:16 pm
IPSec VTI +1
pls :?
TaBo
Thu Jun 20, 2019 12:43 am
IPSec VTI +1
One of the usefull feature
nicksniper2
Thu Jul 11, 2019 8:21 am
IPSec VTI +1
Sometimes you can't understand why your devices sell badly. The secret is very simple - you have no required (must have) functionality...
0daymaster
Sat Oct 19, 2019 4:54 pm
VTI++
nz_monkey
Tue Oct 22, 2019 6:56 am
Mikrotik support have stated in the past that they could not add IPSEC VTI support due to kernel limitations, and that they would reconsider once RouterOS v7 was out.
Well, v7 beta is now out.... Hopefully Mikrotik find the resources to add IPSEC VTI support. It is sorely missed from RouterOS and as you can see from this forum topic (and many others) it is widely requested.
valsily
Mon Nov 18, 2019 3:50 am
Add VTI support please.
0daymaster
Tue Dec 17, 2019 6:30 am
GRE over IPsec transport doesn't work for the purpose of running OSPF with pfSense or Cisco on the other end.
pe1chl
Tue Dec 17, 2019 1:59 pm
Why not?? That should be no problem!
(of course assuming you can configure the other end to the same settings)
0daymaster
Thu Feb 20, 2020 5:25 am
No clue. I've tried countless times to run OSPF over GRE between MikroTik and pfSense. Ultimately the routers will form full adjacencies but the routes never gets installed in the routing table on the MikroTik end.
mrz
Thu Feb 20, 2020 10:21 am
It works if you do not use IP unnumbered (at least on Cisco)
msatter
Thu Feb 20, 2020 11:17 am
Can we have automatic root certificate check so that public certificates (IKEv2) have not to be manually imported in the store?
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta58 / Winbox 3.27 64bits / MikroTik APP 1.3.15
mrz
Thu Feb 20, 2020 1:59 pm
That would require to store large CA database on the router.
pe1chl
Thu Feb 20, 2020 2:15 pm
Of course it is standard that a certificate should be imported including all its signing certificates up to the root.
The fact that many client systems don't require it because they have their own cert store where they cache those certificates does not mean it is correct to import only your own cert.
(any SSL checking site on internet will point it out when you import only your own cert into your website and have it checked)
So it is not at all unusual that "all certificates" have to be imported, MikroTik or other system. It could be possible to have an optional package containing root certs and often-used 2nd level certs (like that Sectigo cert, the Letsencrypt cert, etc) but it would be only for convenience and should be optional as it requires storage that not everyone may want to waste on it.
msatter
Fri Feb 21, 2020 11:15 am
If the certificate database is big, even if it has a selected number of root certificates is it an idea to make the database to be "side-load" as a dedicated file? If it is present the router can use/import the correct certificate and the user does not have track down the right certificate.
Running:
Sob
Fri Feb 21, 2020 3:53 pm
First problem with certificate database is where to get it, there isn't one universally trusted, OS or browser manufacturers decide what CAs they include. I doubt that MikroTik would be interested in maintaining own list at same scale. Of course they could just use someone else's list (for example curl uses CAs from Mozilla). It's not prohibitively big, 220kB PEM could be even smaller in some different format. Although when imported to RouterOS (quick test with CHR), it currently takes ~600kB, which is probably too much to include by default, with just 16MB flash in so many devices.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
pe1chl
Fri Feb 21, 2020 4:08 pm
That is what I mean, it could be an optional package.
But then:
- it will remain mostly unused (because of the cumbersome method to add optional packages to a router. there should be a selection list in the package menu to add an optional package with a couple of mouseclicks, but it is not there)
- it appears that MikroTik is backing out of the idea of having optional packages, in v7 most of the optional packages have been put in one single big package
Also note that the CAs from Mozilla would not be large enough of a list, it should be like the CAs included in Windows by default.
Certs like that Sectigo 2nd level cert are not in the Mozilla list, which mostly contains only trusted root certs. Windows includes such 2nd level certs as well.
(that is why sometimes certificate validation fails on Firefox and Linux when certs are incorrectly installed on websites, while Windows IE/Chrome has no problem at all)
ThomasLevering
Sat Feb 22, 2020 10:25 am
Here a Root Certificate Collection in PEM
http://wiki.overbyte.eu/wiki/index.php/ ... oot_Stores
https://www.magsys.co.uk/download/softw ... undles.zip
apple.pem - 174 Certificates
google_aosp.pem - 137 Certificates
microsoft_windows.pem - 289 Certificates
mozilla_nss.pem - 137 Certificates
openjdk.pem - 88 Certificates
oracle_java.pem - 88 Certificates
akoznov
Tue May 19, 2020 11:02 am
+1 for VTI
OlofL
Wed May 20, 2020 12:33 pm
Guys calm down, first we need to finish openvpn over udp.
You need to wait another two decades until alpha version of vti is available.
Kamaz
Thu May 28, 2020 12:40 pm
VTI +1
XAuth +1
mytrix
Thu Jun 11, 2020 3:22 pm
We have multiple IPSec tunnels with our partners which use Cisco products and "patch" with GRE tunnel is not possible, because they don't accept it.
ErikCarlseen
Thu Jun 25, 2020 2:45 am
+1 for VTI support, so that we can do dynamic routing against Cisco ASA clusters in datacenters.
techlord
Thu Jun 25, 2020 11:31 pm
+1 to VTI because policy based ipsec is so limited....
alex32c
Fri Jun 26, 2020 1:22 am
+1 for VTI
silkscale
Mon Jul 13, 2020 12:42 pm
yes it should be implemented in the next update !
Users browsing this forum: No registered users and 246 guests
